Is this a multimeter?
TomReilly
PostPosted: 01:24 - 15 Oct 2013    Post subject: Is this a multimeter? Reply with quote
I got a rough idea but it says 'digital automotive analyser' as you can see so it just confused me
https://i1197.photobucket.com/albums/aa430/Rilo_UK/image_zpseaa675b9.jpg
Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. Wink
recman
PostPosted: 01:26 - 15 Oct 2013    Post subject: Reply with quote
Yep and here's some how to vids.
PostPosted: 01:26 - 15 Oct 2013    Post subject: Re: Is this a multimeter? Reply with quote
Yes, it is a multimeter.
TomReilly
PostPosted: 01:30 - 15 Oct 2013    Post subject: Reply with quote
Cool.
Some of the guys on here, well a lot of them kept bugging me to get a multimeter so I found this bad boy, do some tests on the bike, not quite sure where to start though so maybe in the morning some people can help me out on here.
TomReilly
PostPosted: 01:31 - 15 Oct 2013    Post subject: Reply with quote
Nice one mate!
Hetzer
PostPosted: 10:30 - 15 Oct 2013    Post subject: Reply with quote
I have an AA one I found on the side of the road.
Brool cory etc.
angryjonny
PostPosted: 10:45 - 15 Oct 2013    Post subject: Reply with quote
Tool story bro.
TomReilly
PostPosted: 11:46 - 15 Oct 2013    Post subject: Reply with quote
angryjonny wrote:
Tool story bro.
Bro, story tool.
Christoffee
PostPosted: 12:43 - 15 Oct 2013    Post subject: Reply with quote
angryjonny wrote:
Tool story bro.
You've been flagged as abusive! You're pun has no place here!
Bike: CBF125
TomReilly
PostPosted: 13:08 - 15 Oct 2013    Post subject: Reply with quote
Thats punny man Cool
Fizzer Thou
PostPosted: 15:05 - 15 Oct 2013    Post subject: Reply with quote
This is typically a 'multimeter'
https://i98.photobucket.com/albums/l269/flynnuk/msoc/002.jpg
This device can be used for many electrical tests.I have one that I bought recently from B&Q as my old meter died.
https://www.diy.com/nav/fix/electrical/electricians-tools/digital_multimeter/B-and-Q-MS8233A-Digital-Multimeter-12758717?skuId=13269423
The OP has a device for testing diodes,DC volts,engine RPM,points dwell and circuit resistance,so is far better suited for vehicles except for AC alternator output and current leakage,amongst others.
Always have a 'Plan B'
TomReilly
PostPosted: 16:11 - 16 Oct 2013    Post subject: Reply with quote
I test circuits with them in work Cool
Carvel
PostPosted: 16:45 - 16 Oct 2013    Post subject: Reply with quote
But you don't know what a multimeter is?
CestrianX
PostPosted: 16:57 - 16 Oct 2013    Post subject: Reply with quote
So your first test is to check the voltage of the battery with the ignition OFF. Then start the bike and check the voltage again, noting the increase in voltage, that's the charging circuit putting 'juice' back into the battery.
next......
TomReilly
PostPosted: 13:15 - 17 Oct 2013    Post subject: Reply with quote
If you read what I said you'll notice why I asked.
TomReilly
PostPosted: 13:16 - 17 Oct 2013    Post subject: Reply with quote
next......
So I put the probes on both the battery 'pins'
PostPosted: 13:17 - 17 Oct 2013    Post subject: Reply with quote
I read it again.
Still can't see why someone who uses a multimeter regularly would need to ask?
TomReilly
PostPosted: 13:21 - 17 Oct 2013    Post subject: Reply with quote
There you go Smile
PostPosted: 13:24 - 17 Oct 2013    Post subject: Reply with quote
Carvel's suggestion, which seem to have flown a little high was, I believe, if you "test circuits with them in work" that you wouldn't need care what was written on it, because you would recognise that it was a multimeter.
TomReilly
PostPosted: 13:31 - 17 Oct 2013    Post subject: Reply with quote
You're missing the point, I put a picture of the device up, showing that I knew it was a multimeter, I could of put a picture of a hammer up for instance, and I was nicely asking to clarify my question that it was a MM, there could be different types for different things beyond my knowledge to this point
PostPosted: 14:59 - 17 Oct 2013    Post subject: Reply with quote
There are different types for different things.
However, if you're conversant with basic testing, you should easily be able to recognise if it has the functions you need.
garth
PostPosted: 15:29 - 17 Oct 2013    Post subject: Reply with quote
https://i.telegraph.co.uk/multimedia/archive/02001/sausage_2001253c.jpg
Is this a sausage?
PostPosted: 15:33 - 17 Oct 2013    Post subject: Reply with quote
Banger
SQL
PostPosted: 15:35 - 17 Oct 2013    Post subject: Reply with quote
Is this a sausage?
No that's clearly a fork.
PostPosted: 15:36 - 17 Oct 2013    Post subject: Reply with quote
Fork-in-sausage.
Mr. Green
The last post was made 12 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 127.04 Kb
