fzr 250
inkorea
PostPosted: 15:30 - 16 Dec 2004    Post subject: fzr 250 Reply with quote
Im living in Korea and a Korean buddy of mine who owns a bike shop gave me a 1987 fzr 250.
Its in great nick cause it was in storage for about 6 years.
Anyway its taken me a few weeks of riding it to get the engine to open up but it is still very spluttery after 10,000 rpm.
But when it does eventually kick in its great. So does anyone know why this is happening and how to fix it. I really want to be able to use its full potential so any advice would be very much appreciated. Thanks in advance.
PostPosted: 15:52 - 16 Dec 2004    Post subject: Reply with quote
Would suspect the first thing to do is to give it a good service, changing the plugs, checking the valve clearances, changing the fuel filter and cleaning the carbs out. Also worth checking that the diaphragms on the carbs have not perished.
inkorea
PostPosted: 16:09 - 16 Dec 2004    Post subject: fzr250 Reply with quote
Thanks Keith,
I had the carbs cleaned and the plugs changed.
I should probably change the oil filter too....but what are the diaphaghms on the carbs Embarassed
cheers
BlueNinja
PostPosted: 18:11 - 16 Dec 2004    Post subject: Reply with quote
If its been sitting for 6 years, it will need a good service.
Brake fluid, (Hydroscopic and absorbs water, will lead to Brake Fade)
Engine oil change, (run engine for 10 mins and heat up properly, then drain it all out)
Engine oil filter change, (get the old one off with a screw driver if its stuck, which it will be Wink )
And almost certainly a petrol drain. empty out all the old 'gone off' petrol, and replace with good fuel, with an additive such as Redex to clean the fuel system, carbs etc.
PostPosted: 18:29 - 16 Dec 2004    Post subject: Reply with quote
On a CV carb there is a throttle that you open. As you open it you create a vacuum before the throttle, and this is used to lift up the throttle slide. The diaphragm is at the top of the slide and it is the difference in air pressure on either side of this that lifts the slide. If it has got a hole then the air pressure difference either doesn't exist or rapidly evens itself out.
The last post was made 21 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 44.31 Kb
