 inkorea Two Stroke Sniffer
 Posted: 16:09 - 16 Dec 2004 Post subject: fzr250 |
Thanks Keith,
I had the carbs cleaned and the plugs changed.
I should probably change the oil filter too....but what are the diaphaghms on the carbs
cheers |
 BlueNinja Trackday Trickster
 Posted: 18:11 - 16 Dec 2004 Post subject: |
If its been sitting for 6 years, it will need a good service.
Brake fluid, (Hydroscopic and absorbs water, will lead to Brake Fade)
Engine oil change, (run engine for 10 mins and heat up properly, then drain it all out)
Engine oil filter change, (get the old one off with a screw driver if its stuck, which it will be )
And almost certainly a petrol drain. empty out all the old 'gone off' petrol, and replace with good fuel, with an additive such as Redex to clean the fuel system, carbs etc. |
 Posted: 18:29 - 16 Dec 2004 Post subject: |
On a CV carb there is a throttle that you open. As you open it you create a vacuum before the throttle, and this is used to lift up the throttle slide. The diaphragm is at the top of the slide and it is the difference in air pressure on either side of this that lifts the slide. If it has got a hole then the air pressure difference either doesn't exist or rapidly evens itself out.
