| aminonholiday |
 aminonholiday L Plate Warrior
| misscrabstick |
 misscrabstick Crazy Courier
| aminonholiday |
| gavcarter |
 gavcarter Could Be A Chat Bot
| aminonholiday |
| temeluchus |
| Vincent |
 Vincent Banned
 Posted: 16:48 - 19 Oct 2013 Post subject: |
Cam chain tensioner?
It can be noisier at idle.
What's the mileage  ____________________ Space Is Deep |
| aminonholiday |
| Vincent |
 Vincent Banned
 Posted: 18:39 - 19 Oct 2013 Post subject: |
CCT's can go after as little as 30K miles I'm afraid. If it is this, look into fitting aftermarket manual tensioners, they last much longer....as long as you don't mind adjusting them yourself, (very easy to do), every few thousand miles.
I think the rear tensioners tend to last longer than the front so you may find the front one has been replaced already.
Have a look on the American VFR forum.....'name escapes me right now ....you'll find all the relevant info there. ____________________ Space Is Deep |
| sprintster |
 sprintster Borekit Bruiser
 Posted: 16:30 - 20 Oct 2013 Post subject: |
Do VFR's not have gear driven cams,not chains  |
| Vincent |
 Vincent Banned
| bikenut |
 bikenut World Chat Champion
| stinkwheel |
 Posted: 12:19 - 23 Oct 2013 Post subject: |
For what it's worth. The clutches can get pretty rattly on the 750 models. My last 750 had a really badly notched basket after about 35k miles. I took it off and filed the notches back but this left room for the tags to flap about a bit so it was still rattly.
I finally dealt with the problem by simply ignoring it until such time as I had a problem with the clutch, which I did not. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sickpup |
 sickpup Old Timer
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
 Posted: 17:22 - 23 Oct 2013 Post subject: |
| _Iain_ |
 _Iain_ Banned
| c_dug |
 c_dug Super Spammer
| sickpup |
 sickpup Old Timer
| Vincent |
 Vincent Banned
| sickpup |
 sickpup Old Timer
| Vincent |
 Vincent Banned
 Posted: 11:34 - 24 Oct 2013 Post subject: |
What I said, while maybe a mistake, was said as part of trying to help someone out. From what I can make out, the conversion to manual tensioners is a popular one as the OEM tensioners were defective and have been known to start making a knocking noise shortly after installation. From what I can make out, it's a lot easier to adjust a manual tensioner once than it is to replace both tensioners several times after the same mileage. The only problem with the manual tensioners, (at least the APE ones), seems to be that the locknut can work itself loose so requires something to stop it moving on the thread.
IMO, what you said, was sarcastic in an attempt to belittle.
You could have just said something like:-
" I don't think the manual tensioners are easy to adjust" for eg.
I see lots of this on forums and, to me, people that trawl workshop forums to find mistakes and then make some sarcastic comment put themselves in a very poor light. I'm not sure the reason for it, maybe some people see it as an opportunity to make themselves look good....but somethings not right.
"Sarcasm is the lowest form of wit"....as they say. ____________________ Space Is Deep |
| bikenut |
| Walloper |
 Walloper Super Spammer
 Posted: 15:05 - 24 Oct 2013 Post subject: |
A man I know had a VFR that was TLC-ed to fcuk by him and the local Honda dealer.
The gudgeon pin drifted out the end of a piston, scored the bore and cost a new engine.
Whilst developing over a minute or two it produced the most hoorish sounding 'Big-End Clatter-Timing chain tensioner Rattle-Sum Ting Wong noise ever.
It required a strip down to it's underpants to find the culprit.
Most engine noise is not easy to determine unless there is prior experience or other supporting evidence such as jewellery in the oil filter.
In other words it could be a number of things or nothing but your paranoia.
I don't even believe anyone can do much good with a screwdriver except hear the noise louder. Unless they know what to listen for.
Noise can resonate from the arse-hole to the ear-hole of an engine which illustrates nothing much. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| sickpup |
 sickpup Old Timer
The last post was made 12 years, 244 days ago. Instead of replying here, would creating a new thread be more useful? |
