engine noise on a VFR 06
aminonholiday
PostPosted: 16:42 - 18 Oct 2013    Post subject: engine noise on a VFR 06 Reply with quote
Hi there, I need some assistance. I have a VFR 800 2006, and recently it started to make a knocking sound at idle speed once the bike is warmed up. however if you rev it up past 2000 rpm the sound fades away.
I am really confused, short of going to garage and as i am broke this is not a option at present.
Any help would be greatly appreciated.
misscrabstick
PostPosted: 19:08 - 18 Oct 2013    Post subject: Reply with quote
Does noise change when clutch lever pulled in?
aminonholiday
PostPosted: 19:49 - 18 Oct 2013    Post subject: Reply with quote
No the noise is still there,
gavcarter
PostPosted: 20:00 - 18 Oct 2013    Post subject: Reply with quote
Can you tell which part of the engine its from? Big old screwdriver against your ear and touch the end of it to all the different casings and housings will help you narrow it down, or at least let you know what area of the engine its coming from.
Could be tappets, slight exhaust leak, valve noise, gear back lash, water pump, oil pump, Basically theres a lot of bearing and a lot of moving part of the engine can be described as "knocking " at low revs if somethings wrong.
aminonholiday
PostPosted: 22:28 - 18 Oct 2013    Post subject: Reply with quote
i did just that, and the noise is loudest by the sprocket, how ever you can also feel it where the spark plug. when you first start the bike, it sounds fine - but after riding for ten minutes the noise starts, its very prominent when you stationary, as after 2000rpm it disapears
temeluchus
PostPosted: 09:07 - 19 Oct 2013    Post subject: Reply with quote
Perhaps the throttle bodies need balancing? Out of balance throttle bodies are more noticeable with the engine idling warm.
aminonholiday
PostPosted: 18:19 - 19 Oct 2013    Post subject: Reply with quote
The milage is 51000 -
sprintster
PostPosted: 16:30 - 20 Oct 2013    Post subject: Reply with quote
Do VFR's not have gear driven cams,not chains Question
bikenut
PostPosted: 10:56 - 23 Oct 2013    Post subject: Reply with quote
:D 51,000 ....so its got 51,000 miles of wear then....how many owners and how old??
see cmsnl for the internals, make sure you are seated when looking at the prices..........
so noise the same with clutch held in, held in for say 20 seconds when hot so all rotating stuff after the clutch has stopped........or drop it in gear .............
you said you could feel it by the plug......any oil leaks or staining there...is plug loose....
but loudest by the sprocket....see cmnsl for whats by there inside......
any oil light issues and any metalics in the oil and filter at last oil change.......
you may have a big end issue.........which cylinder plug makes most noise remove plugs and watch piston movement to crank rotation for "play"............or loss of piston movement relative to crank meaning play in that big end.........the louder sounding plug cyl's piston may be different to the others.........mid stroke as well as tdc/bdc...........if bearing issue you may hear the "clunk"....on the bad one......but compare all cyls/pistons.
pin point the noise more accurately before taking it to bits....... :karma:
nuts about bikes
PostPosted: 12:19 - 23 Oct 2013    Post subject: Reply with quote
For what it's worth. The clutches can get pretty rattly on the 750 models. My last 750 had a really badly notched basket after about 35k miles. I took it off and filed the notches back but this left room for the tags to flap about a bit so it was still rattly.
I finally dealt with the problem by simply ignoring it until such time as I had a problem with the clutch, which I did not.
sickpup
Old Timer
PostPosted: 14:14 - 23 Oct 2013    Post subject: Reply with quote
Vincent wrote:
as long as you don't mind adjusting them yourself, (very easy to do), every few thousand miles.
So stripping the bike so you can get the cam covers off to check the tension of the cam chain is easy?
c_dug
PostPosted: 18:04 - 23 Oct 2013    Post subject: Reply with quote
Are you sure it's not just the exhaust leaking on a downpipe?
sickpup
Old Timer
PostPosted: 22:09 - 23 Oct 2013    Post subject: Reply with quote
Vincent wrote:
Jeez.......is it that time of the month again already?
Perhaps you can explain how to set one up then?
sickpup
Old Timer
PostPosted: 23:43 - 23 Oct 2013    Post subject: Reply with quote
Vincent wrote:
It aint what you say...............it's the way you say it.
As opposed to saying something is easy when it isn't?
bikenut
PostPosted: 14:47 - 24 Oct 2013    Post subject: Reply with quote
:D cmsnl are brilliant for the exploded views which show what type of valve clearance metyhod may be used in your ebngine, or if there are 2 cam chains for the cam shafts and you can find where the f that hidden c/case bolt is etc etc etc as well as part numbers and prices etc................a wonderfull resource if you about them and how to use the site..................didnt know wemoto, although very good, stocked c90 valve guides, be carefull putting it in and making serviceable............
nuts about bikes
Walloper
PostPosted: 15:05 - 24 Oct 2013    Post subject: Reply with quote
A man I know had a VFR that was TLC-ed to fcuk by him and the local Honda dealer.
The gudgeon pin drifted out the end of a piston, scored the bore and cost a new engine.
Whilst developing over a minute or two it produced the most hoorish sounding 'Big-End Clatter-Timing chain tensioner Rattle-Sum Ting Wong noise ever.
It required a strip down to it's underpants to find the culprit.
Most engine noise is not easy to determine unless there is prior experience or other supporting evidence such as jewellery in the oil filter.
In other words it could be a number of things or nothing but your paranoia. Very Happy
I don't even believe anyone can do much good with a screwdriver except hear the noise louder. Unless they know what to listen for.
Noise can resonate from the arse-hole to the ear-hole of an engine which illustrates nothing much.
sickpup
Old Timer
PostPosted: 23:54 - 24 Oct 2013    Post subject: Reply with quote
Vincent wrote:
What I said, while maybe a mistake, was said as part of trying to help someone out.
No definitely wrong, no maybe about it.
Vincent wrote:
IMO, what you said, was sarcastic in an attempt to belittle.
No you just took it that way as it showed you were talking rubbish.
Vincent wrote:
You could have just said something like:-
" I don't think the manual tensioners are easy to adjust" for eg.
Its not a matter of 'don't think' its a matter of I am right, you gave advice that was wrong and misleading therefore you got upset when it was shown that you don't know what you are talking about.
HTH Thumbs Up
The last post was made 12 years, 241 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 133.13 Kb
