| Sparkss |
 Sparkss Nova Slayer
 Posted: 13:09 - 16 Oct 2013 Post subject: chain oil for seaside town |
living about 150 ft from the sea my last chain whet orange but I only used engine oil. (ACF 50 has protected the rest of the bike brilliantly )
I've just fitted new sprockets and a chain and I was wondering f anybody could recommend me something decent. ____________________ R1 |
| Islander |
 Islander World Chat Champion
 Posted: 13:15 - 16 Oct 2013 Post subject: |
EP90 gear oil. Cheap, recommended by chain and bike manufacturers alike, thick enough not to fling if its applied correctly.  |
| Mark65 |
 Mark65 World Chat Champion
| mudcow007 |
 mudcow007 World Chat Champion
| DrDonnyBrago |
| Entertwainer |
 Entertwainer Trackday Trickster
 Posted: 12:24 - 17 Oct 2013 Post subject: |
unless you have a full chain guard, i'd make it a regular maintenance job to clean and relube the chain, thats the only way you're going to stop it from getting a nice shade of Towie orange
the salt in the air will get to it no matter what oil you use.
i should know, i live in Brighton. my bicycle chains dont last long - even with the amount of anal cleanliness i subject my bikes too.
my CG is ok for the most part as it has one of those sexy fully enclosed chain guards.
its just one of those things for living so close to the coast.
i would think though, that a wax type chain lube would be better - the spray i got with my DID chain and sprocket set goes a milky waxy white colour once its set. that seems to provide a good moisture shield..... ____________________ Honda CG 125 W - Turkish - 1998 - 2015 RIP |
| tahrey |
 tahrey World Chat Champion
 Posted: 12:56 - 18 Oct 2013 Post subject: |
I use a mix of leftover 75/80 and 80/90 gear oil on mine, it's still a little thinner than I'd ultimately like (especially in summer) but it seems to last OK. And it seems to resist saltwater quite nicely, I've ridden in salty slushy snow a few times and whilst it attacked various other exposed parts of the bike, the chain (and bits of the rear rim which got spattered by the oil over time) has now come off the bike for routine replacement without hardly any sign of rust at all... in fact the replacement looks worse, having sat in a supposedly-but-actually-not-very well sealed factory bag in a damp garage for a few months!
And it has that nice Moly Sulphide smell, mmmmmm
However, the wax-lube idea also sounds quite good considering your location, and it did used to be a fairly standard concept for bike chains anyway. Put the wax in a pot, warm it up until it just goes fluid, take it off the heat, drop in the chain, schwirly whirly until it starts to solidify again, and pull it out. Should be fairly impervious to anything the environment throws at it so long as you can be bothered with the whole "clean, remove, wax, refit" rigmarole. Obvs this is only practical if you have a springclip fitting, or a decent chain breaker and a ready supply of rivet clips.
Though they probably make spray-on wax now for all I know. I'd just be skeptical of it permeating into all the places it needs to go if it's put on whilst cold. Might want to go half gear oil, half wax if so.
Or just get a Scottoiler. |
| _Iain_ |
 _Iain_ Banned
 Posted: 14:27 - 18 Oct 2013 Post subject: |
Chain cleaner/parrafin, scrub w/toothbrush, apply chain wax from can using half a milk bottle to prevent overspray. Repeat every 200 miles or so. ____________________ Please be aware that the above post may be full of complete nonsense.
| gavcarter |
 gavcarter Could Be A Chat Bot
| Sparkss |
 Sparkss Nova Slayer
 Posted: 18:56 - 20 Oct 2013 Post subject: |
Thank's for the suggestions. I've gone for the EP90, it hasn't arrived yet and already I'm seeing orange
Admittedly I didn't clean my old chain. I've been using a mini wire brush to get crud off in the past, if you've found any effective methods please share  ____________________ R1 |
| Islander |
 Posted: 20:37 - 20 Oct 2013 Post subject: |
Paraffin or diesel and a washing up brush or something similar. Use a piece of card or an offcut of thin ply or similar to protect the wheel and tyre from cleaner flicking off of the brush.  |
The last post was made 12 years, 363 days ago. Instead of replying here, would creating a new thread be more useful? |
