| WULFSTAN |
 WULFSTAN World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 18:01 - 25 Oct 2013 Post subject: |
How's the tank breather and do you use fuel filter? If you use an fuel filter, then toss it away, there shall be none.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| WULFSTAN |
| RhynoCZ |
 Posted: 18:25 - 25 Oct 2013 Post subject: |
If the vacuum hose works, then I'd suspect the fuel tap itself or float valves in carburetors.
EDIT: I had the same problem, I found out the ''pipe'' where the float valve goes was grinded on 1st and 3rd carburetor, that caused the float valve to stuck because of vibrations. PRI just pushed hard enough on the valve and ''made'' it to go down again. The bike worked alright and then randomly died, like when you run out of fuel, no matter how far I got on it.
This thing:
https://i.ebayimg.com/t/Carb-Float-Valve-Kawasaki-Z250-Twin-1978-83-Motorcycle-/00/$(KGrHqN,!hsE3,H)57rtBN-OF5sToQ~~0_35.JPG ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| WULFSTAN |
| RhynoCZ |
 Posted: 19:03 - 25 Oct 2013 Post subject: |
No harm is going to be done, just don't forget to set it back on ON when you turn off the engine, to park it. Some dirt can cause the float valve blockage and the whole tank could drain into your engine. I did 5000km on PRI.
EDIT: ON means OFF when the engine is not running, that's why you should always put it on ON to prevent what I've mentioned.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| WULFSTAN |
| misscrabstick |
 misscrabstick Crazy Courier
| P.addy |
 P.addy Red Rocket
| prawny1 |
 prawny1 World Chat Champion
| WULFSTAN |
| WULFSTAN |
| map |
 map Mr Calendar
| hmmmnz |
 hmmmnz Super Spammer
| WULFSTAN |
| map |
 map Mr Calendar
 Posted: 19:17 - 14 Nov 2013 Post subject: |
| WULFSTAN |
| misscrabstick |
| map |
 map Mr Calendar
 Posted: 19:28 - 14 Nov 2013 Post subject: |
| WULFSTAN |
There is a gap of 355 days between these two posts... |
| lucidityofone |
 lucidityofone L Plate Warrior
| Casper |
 Casper World Chat Champion
| lucidityofone |
| Casper |
 Posted: 11:12 - 05 Nov 2014 Post subject: |
You trying to get an old bike back on the road again. Its all guesswork until you get those carbs out and cleaned on the inside. Sounds like your main jets are blocked or part blocked. Process of illumination and do the cheap stuff first. Not sure if UK got them but some early GT's had slode carbs. What are yours? If you have flat tops you have the vacuum ones what are almost the same as mine and easy to work on. Not the video I used but almost the same on how to strip your carbs
https://www.youtube.com/watch?v=95nlrP-yn2I |
| lucidityofone |
The last post was made 11 years, 354 days ago. Instead of replying here, would creating a new thread be more useful? |
