kawasaki gt 550 only runs on prime.
WULFSTAN
PostPosted: 17:58 - 25 Oct 2013    Post subject: kawasaki gt 550 only runs on prime. Reply with quote
Aright like the title says really bike will only run on prime anyone any ideas thanks.
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
RhynoCZ
PostPosted: 18:01 - 25 Oct 2013    Post subject: Reply with quote
How's the tank breather and do you use fuel filter? If you use an fuel filter, then toss it away, there shall be none. Thumbs Up
WULFSTAN
PostPosted: 18:06 - 25 Oct 2013    Post subject: Reply with quote
tank breather is fine and no fuel filter to speak of.
RhynoCZ
PostPosted: 18:25 - 25 Oct 2013    Post subject: Reply with quote
If the vacuum hose works, then I'd suspect the fuel tap itself or float valves in carburetors.
EDIT: I had the same problem, I found out the ''pipe'' where the float valve goes was grinded on 1st and 3rd carburetor, that caused the float valve to stuck because of vibrations. PRI just pushed hard enough on the valve and ''made'' it to go down again. The bike worked alright and then randomly died, like when you run out of fuel, no matter how far I got on it.
This thing:
https://i.ebayimg.com/t/Carb-Float-Valve-Kawasaki-Z250-Twin-1978-83-Motorcycle-/00/$(KGrHqN,!hsE3,H)57rtBN-OF5sToQ~~0_35.JPG
WULFSTAN
PostPosted: 18:50 - 25 Oct 2013    Post subject: Reply with quote
Is running the bike on prime going to cause any problems?
RhynoCZ
PostPosted: 19:03 - 25 Oct 2013    Post subject: Reply with quote
No harm is going to be done, just don't forget to set it back on ON when you turn off the engine, to park it. Some dirt can cause the float valve blockage and the whole tank could drain into your engine. I did 5000km on PRI. Thumbs Up
EDIT: ON means OFF when the engine is not running, that's why you should always put it on ON to prevent what I've mentioned. Thumbs Up
WULFSTAN
PostPosted: 19:16 - 25 Oct 2013    Post subject: Reply with quote
Glad you told me that ive just ran in the back garden an turned it on thanks Thumbs Up
misscrabstick
PostPosted: 19:21 - 25 Oct 2013    Post subject: Reply with quote
A Vacuum tap needs vacuum to open the fuel flow when the engine runs, a small pipe from the tap goes to the front of a carb so that the engine can suck on it, assuming the pipe is attached you probably need a rebuild kit for your tap as the vacuum diaphragm may well be split, this diaphragm opens the tap when engine vacuum pulls on it, if it is split then the vacuum is lost and the tap will not open.
PostPosted: 19:51 - 25 Oct 2013    Post subject: Reply with quote
Definitely that, my GS500 did the same.
prawny1
PostPosted: 20:28 - 25 Oct 2013    Post subject: Reply with quote
provided the float valves are in good order and are the Viton/rubber tipped ones you will be fine running on prime,
problems come if your floats don't seal or are the metal tipped ones as those seem to always pass a little fuel even when new which will dilute your oil or hydraulic lock the engine when parked up especially if you park on the side stand.
hellkat wrote:
WULFSTAN
PostPosted: 20:50 - 25 Oct 2013    Post subject: Reply with quote
Thanks guys and girls ordered a fuel tap repair kit off wemoto lets see if that sorts it.
WULFSTAN
PostPosted: 18:43 - 14 Nov 2013    Post subject: Reply with quote
So i did try rebuilding my fuel tap now fuel comes out on res on and prime i put everything back in the way it came out any ideas why its pissing out when it shouldn't.
map
Mr Calendar
PostPosted: 19:02 - 14 Nov 2013    Post subject: Reply with quote
WULFSTAN wrote:
So i did tryrebuilding my fuel tap now fuel comes out on res on and prime i put everything back in the way it came out any ideas why its pissing out when it shouldn't.
Confused I'd have thought res is the same as on, it just picks up fuel lower in the tank. So is the bit that fits into the tank ok? IIRC it does contain a bit of a filter but fitting an in-line one should do no harm. Just make sure it's not horizontal.
hmmmnz
PostPosted: 19:13 - 14 Nov 2013    Post subject: Reply with quote
i think your not getting any vacuum from the carbs,
the little pulse from the bike running allows the tap to let fuel through,
check that the small hose from the carbs to tap isnt blocked or doesnt have any splits or leaks
the humans are dead
I kick arse for the lord
WULFSTAN
PostPosted: 19:14 - 14 Nov 2013    Post subject: Reply with quote
Yep but fuel shouldn't be coming out when on unless the bike is running am i right? I have the fuel pipes off and when i turn the tap to on its just pissing fuel out.
map
Mr Calendar
PostPosted: 19:17 - 14 Nov 2013    Post subject: Reply with quote
Yep but fuel shouldn't be coming out when on unless the bike is running am i right? I have the fuel pipes off and when i turn the tap to on its just pissing fuel out.[/quote]
So eliminated bike running.
ON position is then like PRIME position is like the RES position = fuel always flows. Looks like the tap then? Confused
WULFSTAN
PostPosted: 19:22 - 14 Nov 2013    Post subject: Reply with quote
Yes i thought the tap myself so i bought a second hand one off ebay does the same thing but at a much slower rate. Could i have two fucked taps.
misscrabstick
PostPosted: 19:24 - 14 Nov 2013    Post subject: Reply with quote
Assuming the engine is off and therefore no vacuum to the tap, fuel should run through the tap in the PRIME position only, check your work again, you have fucked something up.
map
Mr Calendar
PostPosted: 19:28 - 14 Nov 2013    Post subject: Reply with quote
...check your work again, you have fucked something up.
I see you're using the correct engineering terms Wink Very Happy
WULFSTAN
PostPosted: 22:13 - 14 Nov 2013    Post subject: Reply with quote
Sorted kind of no longer leaking while on. But now while the bike is running its leaking from the back of the tap will have a look again tomorrow.
There is a gap of 355 days between these two posts...
lucidityofone
PostPosted: 10:42 - 05 Nov 2014    Post subject: Reply with quote
sorry to hijack thread but does the smaller hose have to be a vacuum type hose or can you use fuel type hose instead?
Also on the right hand side of the bike, there is a black / grey circle box underneath the tank with an 8mm hose inlet coming out of it. Mine has nothing connected....what could this be?
Thanks.
Casper
PostPosted: 10:59 - 05 Nov 2014    Post subject: Reply with quote
Thinner fuel hose is fine for your vacuum one. The round thing you talk of will be the base of the fuel sender unit. You are just looking at the plastic cover and overflow hose. I have the same but lost the hose years ago.
lucidityofone
PostPosted: 11:03 - 05 Nov 2014    Post subject: Reply with quote
Thanks for that. Thought it might be something that would cause my rough running problems.
would a dodgy fuel tap cause rough acceleration and cutting out at anything over 3000rpm??
Casper
PostPosted: 11:12 - 05 Nov 2014    Post subject: Reply with quote
You trying to get an old bike back on the road again. Its all guesswork until you get those carbs out and cleaned on the inside. Sounds like your main jets are blocked or part blocked. Process of illumination and do the cheap stuff first. Not sure if UK got them but some early GT's had slode carbs. What are yours? If you have flat tops you have the vacuum ones what are almost the same as mine and easy to work on. Not the video I used but almost the same on how to strip your carbs
https://www.youtube.com/watch?v=95nlrP-yn2I
lucidityofone
PostPosted: 11:17 - 05 Nov 2014    Post subject: Reply with quote
yeah vacuum carbs. Ill rip them off and give them a good clean.
When idling it almost sounds like there is an air sucking noise near the tap.
The last post was made 11 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 135.46 Kb
