help with my sinnis
supersmooth31...
PostPosted: 19:17 - 30 Oct 2013    Post subject: help with my sinnis Reply with quote
so i change the stock carb for a little bit bigger one and now it wont turn over unless the handlebar is too the side it starts fine then when i try to put my handle bars straight it just cuts out never come accross this before very strange its a sinnis apache 125cc and 13 plate
gavcarter
PostPosted: 19:46 - 30 Oct 2013    Post subject: Re: help with my sinnis Reply with quote
Choke or Throttle cable are trapped or too short, turning to it side will be releasing which ever one it is.
supersmooth31...
PostPosted: 19:51 - 30 Oct 2013    Post subject: Re: help with my sinnis Reply with quote
Thanks for the reply choke is manual and it set by lever do you mean clutch cable and the rpms dont go up when the handle bar is moved so that can be it can it?
cb1rocket
PostPosted: 20:06 - 30 Oct 2013    Post subject: Re: help with my sinnis Reply with quote
Off topic is this the one recently bought on gumtree?
On topic, it's seems the idle mixture screw isn't set correctly
gavcarter
PostPosted: 20:16 - 30 Oct 2013    Post subject: Re: help with my sinnis Reply with quote
Obviously some thing to do with the handlebars then.....
Positive throttle cable isnt too tight etc?
supersmooth31...
PostPosted: 20:34 - 30 Oct 2013    Post subject: Re: help with my sinnis Reply with quote
Wouldnt even know where to start lol any help?? What should i be looking for?
supersmooth31...
PostPosted: 21:20 - 30 Oct 2013    Post subject: Re: help with my sinnis Reply with quote
Fladdem
PostPosted: 22:07 - 30 Oct 2013    Post subject: Reply with quote
When the handlebars are straight, engine off, does the throttle return back to normal smoothly or does it get jammed?
Follow the throttle cables back and look for adjusters down the length of the cable. SLacken all of them off, so the throttle body is really loose when you pull it. Slowly, tighten some up until you get about 5mm of freeplay with the bars straight. Then test the bars at full lock to see if it still has freeplay.
Hope it helps.
supersmooth31...
PostPosted: 22:56 - 30 Oct 2013    Post subject: Reply with quote
Hope it helps.
It just cuts of like normal. ..thanks alot will try that tomorrow
The last post was made 12 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.26 - MySQL Queries: 13 - Page Size: 64.03 Kb
