car electrics people
grant965
PostPosted: 22:29 - 03 Nov 2013    Post subject: car electrics people Reply with quote
Hi, after getting some of those aftermarket heated seat pads for the car. Could I connect the 12v cigarette lighter type ones to a switch on the dash then to a battery or is it not that simple? I.e. cut plug end off - switch - battery. Ive wired a amp in twice before so figured it wouldnt be much different. How is it possible to wire it to the ignition? Could I use the ignition lead that also tells the amp to power up?
Thanks, Grant
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
jimspeed
PostPosted: 22:32 - 03 Nov 2013    Post subject: Reply with quote
you could mate yea, but you would need a relay to switch them when the ign is on if they draw a bit of power so it doesn't overload whatever you power it from, if you already have an ign fed amp then use the same feed to switch the relay, simple enough and a couple of quid for the relay and some terminals etc.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Fisty
Wire it to a relay/ignition. There is a guide by stinkwheel on here somewhere on how to do it.
Fatter and faster than Fret
grant965
PostPosted: 22:50 - 03 Nov 2013    Post subject: Reply with quote
Thanks guys. If I had two heated pads can they both be connected to a single relay but with 2 switches to allow them to be operated individually or do they need a seperate relay? Any risks of drawing too much power if I run 2 heated seats + an amp in a 1.4 petrol peugeot 206?
To conteol temperature will I just connect up some kind of variable resistor or is it not needed? Will only be cheap £10 ebay pads.
Thanks
The last post was made 12 years, 353 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 40.28 Kb
