| metalangel |
 metalangel World Chat Champion
 Posted: 04:00 - 04 Nov 2013 Post subject: A unique way of making extra lanes for rush hour |
https://www.youtube.com/watch?v=dl0Q2bDnBUc&feature=player_embedded
No need to widen the road or drive on the shoulder (like the M42), just buy one of these... things... ____________________ Previous: 2002 Honda CB500 (sold), 2007 Suzuki SV650SK6 (crashed), 2005 Yamaha FZ6 Fazer (sold). Currently bikeless
"A faired bike will get you 10x more clunge than a unfaired one." -Marlboro Matt |
| Derivative |
 Derivative World Chat Champion
| Teflon-Mike |
 Posted: 06:08 - 04 Nov 2013 Post subject: |
I had to sit through a video about US safety barrier design to get my 'learners permit' when I was 14... so a few decades ago; but even then what they were using was WAY ahead of the 1950's 'Armco' railings we use; that are essentially just a rigid, physical barrier, you hit one side ways you slide, wrecking your car; hit it head on, and it'll bend, but probably stop you. They ent high-tech.
US Safety Barriers are cleverly shaped blocks of concrete; they have a ramp, so if you side-swipe one, before the door starts scraping, the wheels have to go up the ramp, tilting the body away from the barier and tending to steer the car back down and onto the lane... cleaver, hugh?
Where you are likely to hit a barrier head on, or where lanes split, they then use 'energy absorbsion barricading'... you have probably seen them in the movies or you-tube bad driver clips.... plastic oil drums full of water... you hit it, and its heavy enough to slow you down, but doing so will displace the water inside... dissipating energy, so you aren't brought to a sudden neck snapping stop.
They also have 'cable' barriers; big multi-strand spring-steel cables, like a push-bike brake-cable but bigger, strung through water-butts and anchored at the ends with movable concrete blocks; again; hit the fence, you tug the cable, cable pulls concrete block into however many water-buts it takes to make you stop.
I suspect that's a similar principle, and the individual barrier sections are water-filled polyethylene, strung together with steel cable, so that if they get hit, they bow and absorb impact energy. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| daemonoid |
 daemonoid World Chat Champion
 Posted: 08:13 - 04 Nov 2013 Post subject: |
You may be confusing technically advanced with cheap...
Concrete barriers are the cheapest 'acceptable' risk. We've actually taken a huge step back in the UK by switching from flexible and semi-rigid Armco. And worse still, are you really a motorcyclist advocating the use of cheese wire barriers?
Worth also noting that the concrete blocks are also Armco barriers... ____________________ current: ducati monster 750
@thomasgarrard | www.straitjkt.com | www.racingseven.com |
| bikertomm |
 bikertomm World Chat Champion
 Posted: 15:15 - 04 Nov 2013 Post subject: |
For some reason I'd like to see that machine get jammed. ____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
| DrDonnyBrago |
| Benno |
 Benno World Chat Champion
 Posted: 15:49 - 04 Nov 2013 Post subject: |
I bet that woman on the right is absolutely hideous without the 764lbs of makeup she is wearing.
Either that or she is a plastic animatronic doll.
| Quote: | It moves really slow |
| Quote: | Like, 8 miles an hour slow |
Lol murrikan TV is so dumbed down
| Quote: | It gives motorists more flexibility |
| Quote: | That might help the speed of commute |
The obsession with soundbites goes deep in American culture ____________________ I'm autistic. That means I'm smarter than you. |
| Ariel Badger |
 Ariel Badger Super Spammer
| The Disapproving Brit |
 The Disapproving Brit World Chat Champion
| hmmmnz |
 hmmmnz Super Spammer
| Mungel |
 Mungel Scooby Slapper
The last post was made 12 years, 326 days ago. Instead of replying here, would creating a new thread be more useful? |
