A unique way of making extra lanes for rush hour
metalangel
PostPosted: 04:00 - 04 Nov 2013    Post subject: A unique way of making extra lanes for rush hour Reply with quote
https://www.youtube.com/watch?v=dl0Q2bDnBUc&feature=player_embedded
No need to widen the road or drive on the shoulder (like the M42), just buy one of these... things...
Derivative
PostPosted: 04:19 - 04 Nov 2013    Post subject: Reply with quote
I don't really understand the point. You may as well just remove the barrier and do an Aston Expressway.
The concrete isn't anchored, surely a collision would cause huge concrete blocks to fly everywhere? Unless the interlock is really quite strong. The blocks also don't look tall enough for UK motorways.
Teflon-Mike
tl;dr
PostPosted: 06:08 - 04 Nov 2013    Post subject: Reply with quote
I had to sit through a video about US safety barrier design to get my 'learners permit' when I was 14... so a few decades ago; but even then what they were using was WAY ahead of the 1950's 'Armco' railings we use; that are essentially just a rigid, physical barrier, you hit one side ways you slide, wrecking your car; hit it head on, and it'll bend, but probably stop you. They ent high-tech.
US Safety Barriers are cleverly shaped blocks of concrete; they have a ramp, so if you side-swipe one, before the door starts scraping, the wheels have to go up the ramp, tilting the body away from the barier and tending to steer the car back down and onto the lane... cleaver, hugh?
Where you are likely to hit a barrier head on, or where lanes split, they then use 'energy absorbsion barricading'... you have probably seen them in the movies or you-tube bad driver clips.... plastic oil drums full of water... you hit it, and its heavy enough to slow you down, but doing so will displace the water inside... dissipating energy, so you aren't brought to a sudden neck snapping stop.
They also have 'cable' barriers; big multi-strand spring-steel cables, like a push-bike brake-cable but bigger, strung through water-butts and anchored at the ends with movable concrete blocks; again; hit the fence, you tug the cable, cable pulls concrete block into however many water-buts it takes to make you stop.
I suspect that's a similar principle, and the individual barrier sections are water-filled polyethylene, strung together with steel cable, so that if they get hit, they bow and absorb impact energy.
daemonoid
PostPosted: 08:13 - 04 Nov 2013    Post subject: Reply with quote
You may be confusing technically advanced with cheap...
Concrete barriers are the cheapest 'acceptable' risk. We've actually taken a huge step back in the UK by switching from flexible and semi-rigid Armco. And worse still, are you really a motorcyclist advocating the use of cheese wire barriers?
Worth also noting that the concrete blocks are also Armco barriers...
current: ducati monster 750
bikertomm
PostPosted: 15:15 - 04 Nov 2013    Post subject: Reply with quote
For some reason I'd like to see that machine get jammed.
DrDonnyBrago
PostPosted: 15:36 - 04 Nov 2013    Post subject: Reply with quote
There is a joke in there somewhere about getting your foreskin caught.
Benno
PostPosted: 15:49 - 04 Nov 2013    Post subject: Reply with quote
I bet that woman on the right is absolutely hideous without the 764lbs of makeup she is wearing.
Either that or she is a plastic animatronic doll.
It moves really slow
Like, 8 miles an hour slow
Lol murrikan TV is so dumbed down
It gives motorists more flexibility
That might help the speed of commute
The obsession with soundbites goes deep in American culture
Ariel Badger
PostPosted: 18:39 - 04 Nov 2013    Post subject: Reply with quote
Where Birmingham leads the world follows.
The Disapproving Brit
PostPosted: 18:46 - 04 Nov 2013    Post subject: Reply with quote
Sure, it looks very clever going in that direction, so both sides effectively get an extra lane. It'll grind both sides to gridlock as soon as it needs to go the other way.
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
hmmmnz
PostPosted: 19:42 - 04 Nov 2013    Post subject: Reply with quote
we have the same system in operation on the auckland harbour bridge in new zealand,
its been running since 1990,
https://upload.wikimedia.org/wikipedia/commons/f/fa/Barrier_Transfer_Machine_Auckland.JPG
it had been running the "tidal" type thing for loads of years before the moveable barrier was put in, a few too many head on crashes made the use of the concrete barrier mandatory Very Happy
the humans are dead
I kick arse for the lord
Mungel
PostPosted: 20:39 - 05 Nov 2013    Post subject: Reply with quote
Herp? Rolling Eyes
Mungel
ZZR600 (dead) - ZX9R (sold) - FZ1S
The last post was made 12 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 74.6 Kb
