info/help on rear shock
trist077
PostPosted: 14:04 - 05 Nov 2013    Post subject: info/help on rear shock Reply with quote
as you all know i bought a aprilia shiver 2010
now i have been riding a bit i like it to be just a little lower so my question is can this be done to a certain degree via the rear shock
and as in the picture as i dont100% understand if i turn clockwise will this make the shock stiffer as anticlockise towards the top would make it more springy also going towards the top would this increase the height
also what does the dampening screw work what does it do and what sort of setting should i be looking at any info or help would be great thanks
this is by first sports bike ive always had low down cruisers
trist077
PostPosted: 14:19 - 05 Nov 2013    Post subject: Reply with quote
sorry cant put pic on dont know how to do
Hetzer
PostPosted: 14:20 - 05 Nov 2013    Post subject: Reply with quote
Then fucking google it ffs.
iooi
PostPosted: 14:33 - 05 Nov 2013    Post subject: Re: info/help on rear shock Reply with quote
NO. Except when you sit on it. If you are really heavy. Google Setting shock SAG.
Lowering kit
You can also lower a lower seat, by removing some of the foam.
DrDonnyBrago
PostPosted: 15:30 - 05 Nov 2013    Post subject: Re: info/help on rear shock Reply with quote
Better off setting it to stock, setting the sag to your weight then just getting used to it, rather than ruining the geometry by lowering it or fecking about with the suspension settings when you don't know what you are doing.
iooi
PostPosted: 15:56 - 05 Nov 2013    Post subject: Re: info/help on rear shock Reply with quote
Just lower the front by the same and all is back as it was.
TBH. My Versys. has been lowered at the back by 40 M/M. Leaving the front as it was, or dropping 50M/M down the forks makes no difference that you can feel on the road.
PostPosted: 16:43 - 05 Nov 2013    Post subject: Reply with quote
https://www.bikechatforums.com/download.php?id=84237
Read that, then tell me if you should be lowering the shock by adjusting it rather than getting the bike adjusted properly.
To be honest if you're able to ride the bike as it is then you'll get used to it soon enough.
The last post was made 12 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 54.01 Kb
