Kink/Stiff joint in chain.
Beehive Bedlam This post is not being displayed because it has a low rating (Boring). Unhide this post / all posts.
andym
PostPosted: 23:43 - 07 Nov 2013    Post subject: Reply with quote
Have you tried removing the links? Maybe get the same garage that welded up your front sprocket to weld the chain back together too Thumbs Up
SQL
PostPosted: 23:47 - 07 Nov 2013    Post subject: Reply with quote
chain off in pot of engine oil boil for 1hr.
Ariel Badger
PostPosted: 00:06 - 08 Nov 2013    Post subject: Reply with quote
Replace the chain. Replace the sprockets. As you have been a nob and welded your crankshaft replace that as well.
PostPosted: 00:07 - 08 Nov 2013    Post subject: Reply with quote
Kill yourself. Thumbs Up
pdg
PostPosted: 11:07 - 08 Nov 2013    Post subject: Reply with quote
If the link is really actually kinked like that then:
Your chain is slack.
I bet your subframe is bent too.
P.
PostPosted: 11:46 - 08 Nov 2013    Post subject: Reply with quote
I said you'd ruin the Varadero. Laughing I wasn't wrong.
Replace chain and sprockets.
P.
PostPosted: 12:02 - 08 Nov 2013    Post subject: Reply with quote
Weld another one on the crankshaft and leave a spacer out to make up for the alignment mismatch. Question
arry
PostPosted: 12:04 - 08 Nov 2013    Post subject: Reply with quote
Blau Zedong wrote:
But he can't because someone has stick welded the front sprocket on Laughing Laughing Laughing
Is that for real? Seriously? Hahahahaaahaha Laughing
Islander
PostPosted: 12:16 - 08 Nov 2013    Post subject: Reply with quote
Oh he's bound to leave spacers out at some point...
P.
PostPosted: 13:09 - 08 Nov 2013    Post subject: Reply with quote
MilfHunter wrote:
I've unkinked the links doesn't feel as clicky/jumpy when coasting.
@Paddy, hardly ruined it when I've done some 6000 miles in four and a half months of ownership try wear and tear.
20,000 miles in 11 months, just replaced the sprocket set.
Wear and tear Wink
Islander
PostPosted: 13:20 - 08 Nov 2013    Post subject: Reply with quote
Wear and tear doesn't cover welding a sprocket on to the end of the output shaft. That counts as ruining it.
Oh and 6000 miles? That's not even halfway through a normal chain and sprocket set life span. Stuck links indicate poor maintenance. I'm not surprised though.
I'll give you five ponds for it. Laughing
P.
PostPosted: 13:22 - 08 Nov 2013    Post subject: Reply with quote
MilfHunter wrote:
Chain already had miles on it when I bought it. Wink
Mine also did, unsure of point. Laughing Had 27,000 miles from a GSXR750 chain and sprocket set, still wear and tear?! Laughing
YBR Ric
PostPosted: 17:50 - 08 Nov 2013    Post subject: Reply with quote
19,000 miles on my OEM YBR chain & sprockets, recently moved the adjusters onto notch number 3 of 8.
Inadequate maintenance, pure and simple.
https://i162.photobucket.com/albums/t245/portisheadric/P1000824_zpsb35e62a6.jpg
andym
PostPosted: 20:07 - 08 Nov 2013    Post subject: Reply with quote
Sorry but you are dealing with a brain dead moron who seems to maintain his bikes in the worst possible way (eg swarfega is a good chain lube Thumbs Up type moron).
The little shit has been given more than enough advice from the BCF masses and has constantly disregarded and/or thrown it back in their faces, claiming it's his own expert knowledge (maybe a few can prove me wrong on this case), and even going as far as charging his 'friends' for help.
He is a twat, through and through
ian505050
PostPosted: 20:24 - 08 Nov 2013    Post subject: Reply with quote
_Iain_ wrote:
Apparently according to Charloam, the guy who I sold my YBR to managed to knacker the fresh C&S set i put on it before sale in sub 2,000 miles to the extent where he claimed that the chain actually fell off whilst riding. I'm really not too sure what could potentially make a chain fail that quickly unless you soaked it in salt water every night, never lubed it & tightened the chain up to zero play every time you rode it anywhere Laughing
TBF i bought a cheap chain from Brookes Barn for a ybr125 and it stretched about 5mm every 100 miles and had to be replaced in less than 2000 miles. It was only used in the dry, well loobed and the wheel alignment and cush drive were fine.
andym
PostPosted: 23:38 - 08 Nov 2013    Post subject: Reply with quote
MilfHunter wrote:
I've been taking it to the garage once every three week for a quick inspection free of charge everything is tickety boo.
Confused
MilfHunter wrote:
...has quite a significant kink in the chain I can feel it clicking/vibrating at low speeds...
Rolling Eyes
arry
PostPosted: 08:32 - 09 Nov 2013    Post subject: Reply with quote
Point is if that's the case you've managed to kink the chain in 2 weeks and still don't think you've ruined your bike and it's all just down to wear and tear
Face it, it needs more than maintenance now - a new owner would help
The last post was made 12 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 135.79 Kb
