broken indicators on a hongdou 125
matman
PostPosted: 16:51 - 19 Dec 2004    Post subject: broken indicators on a hongdou 125 Reply with quote
i recently bought a hongdou 125 as my first bike. the indicators have stopped working although the main headlight, rear light and horn still work. any ideas on how to fix this? thanks
inhalewater
nick.h
PostPosted: 17:12 - 19 Dec 2004    Post subject: Reply with quote
i pressume that you need to find out if its the indicators that have stopped working or that there is no current flowing to them. you can do this using a voltmetre, i think Thinking.
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
nick.h
PostPosted: 17:14 - 19 Dec 2004    Post subject: Reply with quote
if its the indicators that have stopped working you can buy new ones from here
should only cost you a tenner a pair.
pipnet11
PostPosted: 20:53 - 19 Dec 2004    Post subject: Reply with quote
Did all of them stop at once? If they did its very unlikely to be the bulbs. Could be, in order of likelyhood:
- Nackered switch
- Bad earth somewhere
- Dead flasher unit
Check using a multi-meter. A wiring diagram is also very useful. If you dont have a multi-meter, both conductivity and voltage checks can be done very basicly. To check conductivity you need a 9V battery, 3 bits of wire and a bulb. connect them up in a circuit with the bit you are testing in series. If the bulb lights then its connected, if it doesnt, it isnt. Voltages are similar but without the battery as the power is from the bike, make sure you use a 12V bulb though.
These tests are VERY basic and give you no idea of what resistances or voltages actually are, but at least gives you an idea. Also multi-meters can be picked up for £5 from maplin and they are well worth the money.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
matman
PostPosted: 16:40 - 12 Jan 2005    Post subject: Reply with quote
I've got it now so that the lights come on when you flick the indicator switch over, but they dont flash. Question Could it just be that my new flasher unit I got isn't compatible or is it something else?
thanks
inhalewater
There is a gap of 256 days between these two posts...
MARX-sparky
PostPosted: 17:28 - 25 Sep 2005    Post subject: Reply with quote
the flasher works you just pluged the wires backwards try switchin them round
knockout_bar
PostPosted: 09:34 - 26 Sep 2005    Post subject: Re: broken indicators on a hongdou 125 Reply with quote
I have a Chinese copy 125. The exact same thing happened to me. You need anew relay unit. Should cost you a few quid. It's a 2 pin relay and it's located under the seat. I replaced mine and it's been fine ever since.
125 trail bike, custom bars, handguards etc. - ?500.
"egg flied lice" - R6jonny (inspired by McGee) Thumbs Up
The last post was made 20 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.91 - MySQL Queries: 13 - Page Size: 52.82 Kb
