Best glue for repairing small crack in fairing bracket?
maxp
PostPosted: 12:20 - 10 Nov 2013    Post subject: Best glue for repairing small crack in fairing bracket? Reply with quote
Hi guys,
Had the nose fairing off to replace a bulb and thought while I had it off, to repair a crack in the headlight bracket that occurred when the previous owner dropped it.
Planned to nip to B+Q at some point, but wondered if anyone could advise what glue product would be the best for this type of repair?
Off the top of my head I would probably go for one of those two-part epoxy syringe type glues, but Im really clueless on this topic!
https://i.imgur.com/D5F2Rxk.jpg
Hetzer
PostPosted: 12:24 - 10 Nov 2013    Post subject: Reply with quote
I've used a soldering iron with some scrap plastic before (make sure the scrap is the same type of plastic as the fairing, usually ABS). Glue is a waste of time unless it melts the plastic, and even then...
dansp1
PostPosted: 12:36 - 10 Nov 2013    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Q-Bond-Repair-Kit-Ultimate-Repair-System-ROCK-HARD-IN-10-Seconds-BNIB-/390697043325?pt=UK_Crafts_Cardmaking_Scrapbooking_Glue_Tape_EH&hash=item5af75bc57d
MartQ
PostPosted: 12:49 - 10 Nov 2013    Post subject: Reply with quote
Seriously, DO NOT use glue. You will only make life more difficult for yourself. Have a go at plastic welding, it's much more permanent.
A good guide is at:
https://www.kawasaki-rider.co.uk/phpBB3/viewtopic.php?f=26&t=15175&hilit=plastic+welding
This guy does it for a living and I'm sure he has posted a video on youtube, it just didn't pop to the top of the list in my search.
PostPosted: 12:51 - 10 Nov 2013    Post subject: Reply with quote
Gorilla glue, or any of the other PU brands. Or go to the double glazing shop and buy some of their CA glue, it's thick, slow setting and much stronger than the regular superglue.
Plastic welding with a soldering iron can work but most people just burn the plastic causing it to go brittle and break even easier.
Suntan Sid
PostPosted: 13:24 - 10 Nov 2013    Post subject: Reply with quote
If your going to use glue, get some thin metal sheet, cut out a piece and bend it into an "L" shape, to fit inside the plastic lug.
Glue that in place, this way you will have, at least, added more strength than the glue will have provided.
I've used this method in the past, and the repairs lasted very well!
dansp1
PostPosted: 13:58 - 10 Nov 2013    Post subject: Reply with quote
Has anybody (else) used qbond? before i used it i glued an old bit of fairing and tried to break it, it didn't break the repair it broke close to it!
stirlinggaz
PostPosted: 16:27 - 10 Nov 2013    Post subject: Reply with quote
hi,
i have tried Q-bond, plastech, & umpteen other glues including epoxy.
plastech & u-bond are both as good as each other but i usually take a piece of meccano (a 1 hole wide strip) & glue this to back of any repair. meccano is useful as it can b bent to shape & i have loads of it lying around since i was a kid Very Happy
even cheap epoxy from poundland will do, as long as you have an eye for detail, a dremel (or similar) to grind a V into the crack/split & a bit of patience.
top tip? use masking tape otherwise u might make a mess.
plastic welding should be avoided unless you have done it before,
cheers,
GAZ
Walloper
PostPosted: 16:44 - 10 Nov 2013    Post subject: Reply with quote
Plastech fuss free. Pro finish.
Or take it to a bodyshop and they will do a propah pro job for a fee. 20/30 quid ???? Not sure. But not much anyway and possibly for biscuits/beer.
dansp1
PostPosted: 17:30 - 10 Nov 2013    Post subject: Reply with quote
stirlinggaz wrote:
hi,
cheers,
GAZ
Did you use the Q bond with the powder? i have found it to make incredibly strong repairs, although it wont work on all types of plastic
The last post was made 12 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 64.97 Kb
