2 Bike Questions....
NSR125-Kid-UK
Attention Whore
PostPosted: 00:18 - 20 Dec 2004    Post subject: 2 Bike Questions.... Reply with quote
Well, my main beam bulb on the left has gone, so I'm asking:
Can I get LED Cluster bulbs for the NSR? just something a little brighter than what I have?
Also, I've noticed my spare brake disc is warped. Anywhere I can get it skimmed flat again?
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
tatters
Exxon Valdez
PostPosted: 00:21 - 20 Dec 2004    Post subject: Reply with quote
standard NSR125R lamps are 25w, l changed mine to 35w which worked fine and gave a good improvement in lighting
NSR125-Kid-UK
Attention Whore
PostPosted: 00:23 - 20 Dec 2004    Post subject: Reply with quote
Doesn't that mean your battery isn't charged as much by the alternator thingie?
Frost
PostPosted: 00:35 - 20 Dec 2004    Post subject: Reply with quote
Yes the brighter bulbs will consume more power, but a few watts is nothing much to worry about.
Disks can be pressed/skimmed, but you have to find somewhere able to do it, and its probably not going to be cheap.
DukeRed
PostPosted: 00:38 - 20 Dec 2004    Post subject: Reply with quote
I was just about to ask a similar question. I've been browsing google for main beam lights but there's so many choices.
Whats the best for standard 12v supply? As in brightest.
Jan
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
Jrod
Page 3 Girl
PostPosted: 00:44 - 20 Dec 2004    Post subject: Reply with quote
I run higher watt bulbs on the ZXR, never had any problems with it. The battery has been totally dead before (don't leave your parking light on for a few days Rolling Eyes) and it gets charged up fine.
PostPosted: 00:48 - 20 Dec 2004    Post subject: Reply with quote
Going up a few watts is OK and wont do any harm.
If you put much higher wattage bulbs in, you need to be carefull not to overload the wiring and set your bike on fire, best to use relays in this case.
DukeRed
PostPosted: 00:49 - 20 Dec 2004    Post subject: Reply with quote
What about xenon and bulbs like that?
PostPosted: 01:00 - 20 Dec 2004    Post subject: Reply with quote
Xenon bulbs give out a more blue light than normal ones, it is simply the type of gas they fill the bulb with. So long as the wattage is broadly similar to standard, they shouldn't cause any problems.
Jrod
Page 3 Girl
PostPosted: 01:10 - 20 Dec 2004    Post subject: Reply with quote
I hate the cars with those because they blind you, still I wouldnt mind them on my bike. Razz Where can you get them from?
Enverex
PostPosted: 01:20 - 20 Dec 2004    Post subject: Reply with quote
Does that mean you can use Hallogen bulbs too or is that another matter?
PostPosted: 01:28 - 20 Dec 2004    Post subject: Reply with quote
Providing the wattage is the same and the bulb is the same type (ie the shape of it so the reflector gives you the correct beam pattern). No problem.
Halfords springs to mind.
binge
Emo Kiddy
PostPosted: 01:32 - 20 Dec 2004    Post subject: Reply with quote
Both my SF2s had High brightness Halogen bulbs in, but my SF1 has a single headlamp bulb which has 2 thingey majigs (erm, 2 bulbs in one) and its crap!
I dont think SF2 bulbs will go in the SF either Sad
<|Binge|>
NSR125-Kid-UK
Attention Whore
PostPosted: 22:14 - 20 Dec 2004    Post subject: Reply with quote
Still don't know where to get the bulbs from, or the disc sorted...
...I can fit the bulbs when I fix the fairing.
The last post was made 21 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 83.2 Kb
