My damn wrist
TomReilly
PostPosted: 08:53 - 15 Nov 2013    Post subject: My damn wrist Reply with quote
Been on the road a lot lately and my right wrist is in agony, anybody else get this?
Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. Wink
PostPosted: 08:54 - 15 Nov 2013    Post subject: Reply with quote
You just need to wank more. Great for building strength.
TomReilly
PostPosted: 08:59 - 15 Nov 2013    Post subject: Reply with quote
I assure you my right arm is alot beefier than my left, but thanks man Thumbs Up
Jefr0
PostPosted: 09:04 - 15 Nov 2013    Post subject: Reply with quote
Keep riding. It won't cause no arm Razz
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
esullivan
PostPosted: 09:07 - 15 Nov 2013    Post subject: Reply with quote
What kind of riding are you doing? I find my right hand (not wrist) aches when I'm riding through lots of difficult, inner-city traffic, which is counter-intuitive because my left is doing most of the work (slipping the clutch). I think it's mostly because I'm tense and gripping the bars too tightly. I concentrate on gripping the tank with my knees, which for some reason causes me to loosen my death grip and sit up more.
If you are mostly riding open roads and just working the throttle and brake lots, then: A) see if the brake lever is correctly aligned for you and/or B) look into what is called a "cramp buster", like one of these.
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
Bubbs
PostPosted: 09:08 - 15 Nov 2013    Post subject: Reply with quote
I got it a lot with my ZX6R, it used to have a really stiff throttle and would eventually start hurting. I eventually bought one of them gadgets that let's you use the throttle without having to twist you wrist.
Can't remember what they are called, but it's a bit of plastic that does the trick.
TomReilly
PostPosted: 09:21 - 15 Nov 2013    Post subject: Reply with quote
It's mainly long roads I ride so I work the throttle alot more than the clutch.
cbrtrxtdmvfrD...
PostPosted: 10:05 - 15 Nov 2013    Post subject: Reply with quote
Only when i had a sports-bike long after i was too old to have one!
Mind you i know a R1 rider who is 73 and just come back from Spain on it - so maybe i had a limp wrist
Right' O
PostPosted: 12:47 - 15 Nov 2013    Post subject: Reply with quote
https://images.motorcycle-superstore.com/productimages/300/0000_crampbuster_motorcycle_cruise_assist.jpg
Crampbuster, aka cruise control. They come in various styles, and really do work if the problem is that you're stressing your tendons by holding your hand in a "knock knock" posture.
I think I'd rate them as the best value-for-money gadgets that I've tried.
TomReilly
PostPosted: 13:27 - 15 Nov 2013    Post subject: Reply with quote
Might look into that!
Matt B
PostPosted: 13:37 - 15 Nov 2013    Post subject: Reply with quote
Roger, are you saying that you actually purchased (with cold hard cash) one of those? Shocked You didn't make one out of an old bit of guttering nicked from the neighbour or such like?
Can you twist it round and wedge it under the brake lever for hands free riding...?
PostPosted: 15:43 - 15 Nov 2013    Post subject: Reply with quote
Embarassed Caught me.
In my defence, the one that Ze Beemer has inherited is too big for its ickle girlish grips, so I padded the grip out with a big old mess of electrical tape. Wink
It's a real scunner that you can't use a cramp buster and muffs together, it's like Sophie's Choice choosing between them. Yes, it's literally like choosing which child gets gassed by Nazis. Folded arms
27cows
PostPosted: 18:58 - 15 Nov 2013    Post subject: Reply with quote
I have this happen from time to time. Doesn't seem related to the stiffness or otherwise of the throttle cable, so much as you hold you hand in an unnatural position sometimes, especially in cold weather. You have to consciously think about it and then make adjustments.
Need to be careful is doesn't lead to tendonitis as that's a real bastard. As I recall, it's what buggered Freddie Spencer's career.
PostPosted: 19:15 - 15 Nov 2013    Post subject: Reply with quote
What sort of position do you ride in?
Ideally your forearms should be parallel to the road with a bend at the elbows for best control.
Definitely with 'loose' wrists.
This may help relieve pressure off wrists, it'll also give you better control.
To give you an idea of the difference - ride along with straight stiff arms and try wobbling the bars (somewhere safe to do that, of course.)
No repeat with loose arms flat to the road and do the same thing again.
Old Git Racing
PostPosted: 23:50 - 15 Nov 2013    Post subject: Reply with quote
Do you ride with your hand covering the brake lever? If so look at where it is positioned.
OGR
Walloper
PostPosted: 00:19 - 16 Nov 2013    Post subject: Reply with quote
Try riding with your hand in your pocket.
Or MTFU.
Very Happy
dn38416
PostPosted: 09:37 - 16 Nov 2013    Post subject: Reply with quote
There's a stretching exercise someone posted on here in another thread that worked for me.
Move your hands into a praying position, palms against one another in the middle of your chest, so your forearms should form a straight line. Then point your hands in towards your chest as far as you can.
TUG
PostPosted: 15:46 - 16 Nov 2013    Post subject: Reply with quote
Wrist ache? New bike? It'll go away soon enough as you get used to it well it does for me when I get a new bike, the most annoying bit is the forearm ache from getting used to the new clutch and brakes.
Haz ER-5, innit!
TomReilly
PostPosted: 08:25 - 18 Nov 2013    Post subject: Reply with quote
The 'knock knock' position describes it well
Past few days I've been riding its been going away but as I'm in work now (rode to work) it's back and killing again.
I did find myself adjusting my hand position when the throttle is open to a more natural position because I had to to stop any pain
-Matt-
PostPosted: 10:18 - 18 Nov 2013    Post subject: Reply with quote
Wrists fair suprisingly well considering its a sport bike, i did however sprain my fingers from prolonged periods of clutching this summer during a lot of time bobbing around cities, got so bad i had to stop riding for a week and a half to let it recover at one point Laughing
Knees tend to lock up after about 4 hours riding also, but if i take an hours break they start to un-seize, dread to think what i'll be like by the time i reach my middle-age Rolling Eyes
TomReilly
PostPosted: 11:10 - 18 Nov 2013    Post subject: Reply with quote
I think my bike would seize up after a 4 hour ride Laughing Laughing
The last post was made 12 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 126.43 Kb
