NSR 125-F 1998 CLUTCH PROBLEM!
ste.cameron25
PostPosted: 20:26 - 15 Nov 2013    Post subject: NSR 125-F 1998 CLUTCH PROBLEM! Reply with quote
Hello after some messing about with my clutch plates I finally got new plates and friction plates also springs. After fitting then as manual said to do so my clutch does not work as soon as I put clutch in and knock it into 1st it stalls I have tried and tried...starting to give up it just seems as if the clutch wasn't ther and Iam pulling the clutch lever for nothing I have had help off alain followed his instructions and still no joy anyone here can tel me what Iam doin Rong or if I have missed something cheers
If you carnt make it then buy it..
stirlinggaz
PostPosted: 20:40 - 15 Nov 2013    Post subject: Reply with quote
hi,
did you put the new plates in just like the old ones?
most clutches i have done, the last plate should be off-set, unlike all the other ones,
cheers,
GAZ
ste.cameron25
PostPosted: 20:45 - 15 Nov 2013    Post subject: Reply with quote
Hello I soaked then in oil and followed the manual on how to install them it seen as if iam missing something
bypass2
PostPosted: 21:49 - 15 Nov 2013    Post subject: Reply with quote
any play in the cabble or not enough or to much. or the release lever engine end
ste.cameron25
PostPosted: 22:07 - 15 Nov 2013    Post subject: Reply with quote
No free play I have tried everything slack tight medium and still no joy
Nobby the Bastard
Harley Gaydar
PostPosted: 22:14 - 15 Nov 2013    Post subject: Reply with quote
Did you replace all the bits that you took out? Sounds like that the clutch isn't working because something is missing.
Triumph Sprint ST 1050
ste.cameron25
PostPosted: 22:16 - 15 Nov 2013    Post subject: Reply with quote
Yes everything
Nobby the Bastard
Harley Gaydar
PostPosted: 22:20 - 15 Nov 2013    Post subject: Reply with quote
In the right place?
ste.cameron25
PostPosted: 22:21 - 15 Nov 2013    Post subject: Reply with quote
Yes as the manual suggested for installing new clutch
bypass2
PostPosted: 22:32 - 15 Nov 2013    Post subject: Reply with quote
what about the correct fitting of the anti-judder spring
ste.cameron25
PostPosted: 22:34 - 15 Nov 2013    Post subject: Reply with quote
Yes I have done that example if you can understand my little way off describing them. \|
bypass2
PostPosted: 22:41 - 15 Nov 2013    Post subject: Reply with quote
the way i see it in the ns125 book is this way i/
ste.cameron25
PostPosted: 22:58 - 15 Nov 2013    Post subject: Reply with quote
This is how I done it image below
bikenut
PostPosted: 11:55 - 16 Nov 2013    Post subject: clutch Reply with quote
check with cmsnl just to be sure.........not seen pics.............is there a ball in the mech on this bike, suspect not as suspect clutch release system all on the clutch side rather than cable mech on opposite side?? as i said i've not seen the pics
so clutch release all, on clutch side........check all your work, spacer missing from behind clutch or tween baslet and drum??
re check all your work.
nuts about bikes
ste.cameron25
PostPosted: 12:18 - 16 Nov 2013    Post subject: Reply with quote
Tried that and reinstalled the clutch 4 times nothings missing everything's placed as its suppose to be am really lost on this one...
bypass2
PostPosted: 14:18 - 16 Nov 2013    Post subject: Reply with quote
is it a bike you have recently brought. or have you used it regular and it gone like it. did you use the proper grade oil
ste.cameron25
PostPosted: 14:21 - 16 Nov 2013    Post subject: Reply with quote
It's a project iam doin the engine has been sat for a while engine fun perfect just the clutch that's been a bitch!! I will take photos off the steps iam doin to assemble the clutch try and make it easy just in case I have missed something cheers everyone
bypass2
PostPosted: 14:32 - 16 Nov 2013    Post subject: Reply with quote
not sure about yours i brought a bike been standing and the bar behind the release mechanism was missing called the pusher peice it was doing what yours is. also show some pics on the clutch cabble release engine end
ste.cameron25
PostPosted: 18:14 - 17 Nov 2013    Post subject: Reply with quote
Problem solved
Terns out I needed a extra washer on my clutch hub but thers oready one on the back manual says nout about that big thanks for everyone's help
bikenut
PostPosted: 15:49 - 19 Nov 2013    Post subject: Reply with quote
is it shown in cmsnl???????????????????????? :karma:
nuts about bikes
ste.cameron25
PostPosted: 16:01 - 19 Nov 2013    Post subject: Reply with quote
Where the clutch gos into the hub I needed a extra washer for some reason
The last post was made 12 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 2.38 - MySQL Queries: 13 - Page Size: 100.92 Kb
