Juddering steering...
haGGard
PostPosted: 18:23 - 20 Dec 2004    Post subject: Juddering steering... Reply with quote
Hey,
This has only started this morning but it does not do it all the time...
Sometimes when i brake the steering columb and handle bars will shake a bit, it only does this when i use the front brake.
Is this normal?
Cheers Thumbs Up Wink
jamie192
PostPosted: 18:25 - 20 Dec 2004    Post subject: Reply with quote
maybe your headset is loose if you have them on scooters. try holding your front brake on and rocking the bike backwards and forwards and see if you have any movement. There should be none.
Ride Fast, Brake hard, don't fall off!
Barker-CBR 600
PostPosted: 18:26 - 20 Dec 2004    Post subject: Reply with quote
Got ABS?
I seen that on some modern ABS bikes hard braking can cause juddering due to the 'brake release brake release' of the ABS.
Previous - Gilera DNA50 / XVS125 Dragstar/Honda CBR 600F/GSF 650 Bandit
Current - 2013 Suzuki VZ800 Intruder
'Is this a rhetorical question?'
haGGard
PostPosted: 18:27 - 20 Dec 2004    Post subject: Reply with quote
I dont think i have ABS, im only on a Speedfight 2 100 Confused
fastyan
PostPosted: 18:30 - 20 Dec 2004    Post subject: Reply with quote
either your head bearings are loose or maybe your front disc is warped (if you have them/one) - presume you've check the pressure in the front tyre as well??
mr.z
PostPosted: 18:31 - 20 Dec 2004    Post subject: Reply with quote
I think its brake related, have you had any knocks recently?
Your brake could be binding slightly on a warped disc, when your breaking the judder is from the disc warpage.
Get somebody to push down on the back when its on the stand to lift the front up, the wiggle the front wheel, if its moveing arorund side to side then it needs attention.
I'd say discs, have you changed the pads recently?
Barker-CBR 600
PostPosted: 18:32 - 20 Dec 2004    Post subject: Reply with quote
Definetly not ABS then.
Yeah check tyre pressures, flats can do all kinds of strange thing.
If you got a warped brake disc its an (expensive) pain but will need sorting.
haGGard
PostPosted: 18:42 - 20 Dec 2004    Post subject: Reply with quote
I havent chacked my tyre pressure recently but ill test it tomorow.
Ive never had and knocks so i dont think its warped disks, its only done under 4000km as well.
Ill test the headstock bearings tomorow as well.
Barker-CBR 600
PostPosted: 18:44 - 20 Dec 2004    Post subject: Reply with quote
Might just be a flat spot that your only noticing when lowering the revs by braking... unlikely but possible. Bike would start to vibrate alot more and generally feel uncomfortable.
But then again when you say juddering... sounds too violent to be a flat spot.
Robby
Dirty Old Man
PostPosted: 19:08 - 20 Dec 2004    Post subject: Reply with quote
Classic warped disc, juddering under braking. If you had headstock trouble the handling would be off too, feeling very loose and floppy if they are loose, and feeling notchy and not wanting to change direction at low speed if they are worn.
Would be unlikely for headstock bearings to wear out in 4k, quite easy to warp a brake disc in that time though, particularly with an auto.
haGGard
PostPosted: 21:56 - 20 Dec 2004    Post subject: Reply with quote
Hmm, sounds like its gonna cost me an arm and a leg Confused
binge
Emo Kiddy
PostPosted: 22:13 - 20 Dec 2004    Post subject: Reply with quote
Nope not at all mate!
All speedfights do it. Because of the inverted front suspension system when the front brake us being used, the front end likes to shake unles the back brake is equil or more on than the front...
Ive had it on all 3 of my speedfights, Its nothing to worry about mate...
Just use your back brake a bit more than the front...
<|Binge|>
askew
PostPosted: 10:50 - 21 Dec 2004    Post subject: Reply with quote
That was lucky... saved by the binge. Smile
What's ya name? What av' ya taken? Chase the lasers, safe as f*ck!
jamie192
PostPosted: 11:18 - 21 Dec 2004    Post subject: Reply with quote
binge to the rescue again, then he should know hes had what 3 is it now?
nick.h
PostPosted: 11:36 - 21 Dec 2004    Post subject: Reply with quote
i could never have 3 of the same bike, i'd just get bored..
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
binge
Emo Kiddy
PostPosted: 13:14 - 21 Dec 2004    Post subject: Reply with quote
Hehe! They wernt the same bike tho Wink
One was a bog standard 50cc X race...
Two was a 50cc frame with a SF100 lump in it...
three is a tuned to the testicles SF1 70cc Mr. Green (With custom key scratches Evil or Very Mad )
<|Binge|>
The last post was made 21 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.16 - MySQL Queries: 15 - Page Size: 87.17 Kb
