gladihaventgotanakedbike.com
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2
PostPosted: 19:09 - 14 Nov 2013    Post subject: Reply with quote
Fitted an electric heater tube in the shed. Set to activate at 1°C. Wink
I like getting older. I have muffs too. Thumbs Up
FriendlyEllis
PostPosted: 22:00 - 14 Nov 2013    Post subject: Reply with quote
Just ordered some R&G heated grips.
Gotta fit them this weekend.
Cue the disaster!!!
I want them to be ignition controlled so understand I need a relay of some sort.
Bit reluctant to cut any wires!
Honda CB600F Hornet 2013 -> Kawasaki Z1000SX ABS Tourer 2015
Walloper
PostPosted: 08:52 - 15 Nov 2013    Post subject: Reply with quote
Cue the disaster!!!
If you are unsure:
The normal way to connect is to 'tee' into the tail light supply which on almost all bikes 6yrs old are normally 'ignition live' so if no key in the bike the power is off which save you running down the battery.
They still need a relay to power the grips but you simply connect the 'main power' to the + - posts of the battery.
So you will have main power 'circuit' to feed the grips (though a switch) which is an 'open circuit' until you turn on the ignition. The ignition powers the tail light which in turn energises the relay to close the relay and 'complete' the 'main circuit' to the grips. e viola, toasty hawns. (or not so toasty hawns if a multi-position switch).
Stinkers put a little skit together in workshop section that spells it all out for the un-informed/ham-fisted. Very Happy
FriendlyEllis
PostPosted: 23:10 - 18 Nov 2013    Post subject: Reply with quote
Cue the disaster!!!
If you are unsure:
Used stinkwheels guide...... Only had to sift through his 22,000 posts Wink
https://www.bikechatforums.com/viewtopic.php?p=2444272
And this.
https://canyonchasers.net/shop/generic/heated-grips-alt.php
Both very good.
All worked okay.
Hairspray didn't work as a fixer but on my heated grips the 'core' is hard like plastic not soft rubber so hammered the left one on.... V tight and glued the right one with a general purpose time set glue.
R&G grips are warm as toast. Yippee!!
The last post was made 12 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 43.52 Kb
