GSXR 400 engine - Question on parts/specs
m1tch
PostPosted: 20:56 - 21 Nov 2013    Post subject: GSXR 400 engine - Question on parts/specs Reply with quote
Hi all,
I am going to be using a GSXR400 engine for a project, I have been informed that its an import engine and it runs on carbs. I am unsure on the exact year it was made although doing a quick wiki search they all seem to be about the same apart from the very late model which seems to have a 7bhp drop (guessing emissions stuff).
Anyway, I was just wondering about parts for the engine, are there any parts in common with other bikes that could be swapped over? Anyone have any opnions on the engine at all? It seems to make around 60bhp and rev to 12k rpm so not too bad for a small engine. Does anyone have any technical specs on the engine eg compression ratio, valve lift etc?
Thanks in advance
lihp
PostPosted: 21:02 - 21 Nov 2013    Post subject: Reply with quote
I have a full running engine you can have with all ancillaries for 150 no restrictions in it either
m1tch
PostPosted: 21:34 - 21 Nov 2013    Post subject: Reply with quote
I already have the engine, how can I tell which year it was from?
m1tch
PostPosted: 22:01 - 21 Nov 2013    Post subject: Reply with quote
CHR15 wrote:
does it have conjoined inlet rubbers (ie. 1+2 and 3+4 are double up)
if so its a gk71f
does it have an external cannister oil filter?
if so it a gk76a
else its a gk73a which has 4 seperate carbs but an internal oil filter.
incase you were wondering , the 73a uses the same oil filter as a gs500.
Thanks for that I will give the engine a check over and see what exactly I have/am getting lol
Are there other Suzuki parts that would fit this engine?
331X2
PostPosted: 08:44 - 22 Nov 2013    Post subject: Reply with quote
So is the 73 the most similar to the Bandit then?
OP, fancy flogging me your cams? Very Happy
m1tch
PostPosted: 15:09 - 28 Nov 2013    Post subject: Reply with quote
m1tch wrote:
if so its a gk71f
if so it a gk76a
Just got the engine back, it has 2 double carbs and I can't see an external oil filter so I am guessing its a GK71F then? Hopefully its a good engine lol Very Happy
lihp
PostPosted: 16:16 - 28 Nov 2013    Post subject: Reply with quote
Engine is decent, make same power as the GK73, however, it is near impossible to tune extra power, due to the fact that jetting cannot be changed since there are no other jets available on the market for the carbs.
m1tch
PostPosted: 16:54 - 28 Nov 2013    Post subject: Reply with quote
Thanks for that, I don't really think I would need extra power from the engine, after all it is only 400cc but it revs to 12krpm which is plenty.
Are the jets removable at all? Would it be possible to simply buy another set of OEM (or simular) jets and then look at drilling them out slightly? Again, not really in the plan but I was just wondering about the options.
The last post was made 12 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 55.44 Kb
