| rehmh05 |
 rehmh05 Nova Slayer
| rehmh05 |
 rehmh05 Nova Slayer
| pdg |
 pdg World Chat Champion
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| P.addy |
 P.addy Red Rocket
| Aff |
 Aff World Chat Champion
| pdg |
| garth |
 garth World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 15:29 - 22 Nov 2013 Post subject: |
Unable to comprehend your return comment, please elaborate? |
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:43 - 22 Nov 2013 Post subject: |
| Paddy. wrote: |
Psst, OP is asking which of the fronts that he currently has he should put on for winter riding.  ____________________ Biking is 1/20th as dangerous as horse riding.
| P.addy |
 P.addy Red Rocket
 Posted: 16:00 - 22 Nov 2013 Post subject: |
Neither of them, the grip I want is on the front... all of those aren't gonna get good reviews in pissing rain
There, on topic  |
| DrDonnyBrago |
| pdg |
| rehmh05 |
 rehmh05 Nova Slayer
| Pie-Roe |
 Pie-Roe World Chat Champion
 Posted: 04:46 - 23 Nov 2013 Post subject: |
Still running downgeared TLR on Supercorsa SPs.
I prefer predictable front grip and negligible back grip for shitty conditions personally if you have to 'make do'
Would go for the dragon front tyre of the ones mentioned. If you aren't particularly confident, selling the two new tyres you have and putting the money towards a set of PR2s and engine bars might help.
In fact, just fit whatever tyre and engine bars and learn how to ride in winter. ____________________ Previous: GSF600, FZR600 x2, ZXR750, XT600 Tenere, CB125, CZ125, ETZ 250, ER5, CCM R30, DRZ400, RF600x4, RF900x2, GS500, VTR1000F, 640 SMC, CB250 NIGHTHAWK, GT550x3, GPX750 TE610, CB500, X11x2, SV650, ZING 125, TL1000R,CB250 Superdream, CBR1100XX |
| pdg |
 Posted: 11:44 - 23 Nov 2013 Post subject: |
| rehmh05 wrote: | Any one recommend good tyre fitters in/ around birmingham? or u reckon it can be a diy job? |
Personal opinion
DIY. I always fit my own tyres - car or bike. Go to any place that fit tyres and see if they'll sell you a tub of tyre soap - maybe cost up to about 15quid, but that's less than a lot of places charge to fit a single tyre (and a cheap paintbrush to put it on). I got tyre levers from poundland which are acceptable after filing to remove sharp corners etc.
'Breaking the bead' to remove tyres can be tricky and takes a bit of practice unless you can get or make a bead breaker. Doing it by hand, soap up the rim and bead for removal, push the tyre bead into the rim well and work it over.
For fitting, use a new valve if you can, they're only a quid or so each - or at the very least properly check the old one - cut the old one out (cut off the bit inside the tyre and it'll pull out by hand), soap the new one and pull it through from inside using something like a pushbike handpump tube as a handle. Soap up the new tyre and put it on, making sure the first part that goes on sits in the 'well' in the middle of the rim. There is usually a coloured blob on a new tyre (can wear off partworns though) and if you line this up with the valve you usually don't need to bother with balancing. Inflate the tyre until it pops into place - if you have to go above about 50psi to seat it, let the air out, apply more soap to where it's sticking then inflate again. Then adjust the pressure as required.
Once you get the hang of it, it's an easy job.
/Personal opinion
| Pyro. wrote: |
In fact, just fit whatever tyre and engine bars and learn how to ride in winter. |
And this. ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
| rehmh05 |
 rehmh05 Nova Slayer
The last post was made 12 years, 335 days ago. Instead of replying here, would creating a new thread be more useful? |
