Two silly newbie questions (Almax chain; lock thingy)
Deerhound
PostPosted: 19:19 - 20 Nov 2013    Post subject: Two silly newbie questions (Almax chain; lock thingy) Reply with quote
Sorry - two silly newbie questions:
1. After several recommendations, I've bought an Almax chain for my Yamaha SR125. The only problem is, it's so big and heavy I don't know where to attach it where it won't cause damage. Even just threading it through the back wheel is difficult because there's barely enough room between the spokes and it feels like it's putting pressure on the spokes (I know pressure is put on the spokes due to the weight of the bike and rider, but it feels like it's putting pressure in the wrong directions).
2. On the left of my Yamaha SR125, just under the seat, is a keyhole. When I inserted and turned the key, a little bar thingy slid down and forwards slightly. I don't know what this is for Embarassed It's dark outside at the moment, though, so maybe it will be obvious in the daytime, but meanwhile I'm wondering whether anyone could perhaps enlighten me on its purpose? Smile
CBT: 27th June 2013
Bike: 1997 Yamaha SR125
Andy_Pagin
PostPosted: 19:53 - 20 Nov 2013    Post subject: Reply with quote
1. It won't damage anything. Rolling Eyes Ideally wind it through the frame and/or a wheel and attach to something solid like a lamp post or whatever.
2. No idea Confused
dydey90
PostPosted: 20:02 - 20 Nov 2013    Post subject: Reply with quote
1. Does the chain not have some sort of protective sleeve over it?
2. Maybe it's something to hang your helmet on? Mine has a little steel rope at either side just for that.
Deerhound
PostPosted: 20:10 - 20 Nov 2013    Post subject: Reply with quote
Yes, but it's the weight of the thing squeezed between the spokes (VERY tight fit) and then pushing down on them (at an angle they're not supposed to have force applied to them) that I'm worried about. But if people here think it's fine, then it's probably fine Smile Sorry for the silly question Embarassed
That makes sense! Thanks Thumbs Up
CBT: 27th June 2013
Lyam
PostPosted: 20:20 - 20 Nov 2013    Post subject: Reply with quote
you can buy clear vinyl and with soap and a hairdryer cover the parts of the frame where the chaion goes through, thats what i done
Muldoon
PostPosted: 09:49 - 21 Nov 2013    Post subject: Reply with quote
It is probably a lot easier using the bulky chain on a bike with cast wheels design than spoked wheels but you should be ok if careful threading it through the widest gaps in spokes.
I think the small key operated bar is to secure your helmet on via the strap/ buckle.
CG125 then 13yr gap..
stiglet
PostPosted: 16:34 - 22 Nov 2013    Post subject: Reply with quote
What about putting the chain between the forks above the front wheel?
esullivan
PostPosted: 16:49 - 22 Nov 2013    Post subject: Reply with quote
That's what I do because I can't get the chain through any part of my frame. On the plus side, the chain is well off the ground and less susceptible to a sledgehammer attack. On the downside, if the forks are easy to change, then the thief can just undo a couple of bolts...
Of course, this also applies if it's easy to take the wheel off the OP's bike.
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
Northern Monkey
PostPosted: 23:41 - 22 Nov 2013    Post subject: Reply with quote
You need one of these.
https://securityforbikes.com/anti-pinch-pin.php
I use one poked between the gap between the engine and the bike then connected to a 16mm almax 2m chain then through a ground anchor
djrikki
PostPosted: 12:14 - 23 Nov 2013    Post subject: Reply with quote
Thats a cracking idea!
The last post was made 12 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 64.74 Kb
