winter riding tips
phill.c
PostPosted: 16:36 - 21 Dec 2004    Post subject: winter riding tips Reply with quote
well winter has finally come, and i know that some of us ride to work or college in the morning. so i thort it would be a good idea for people to put any riding tips or any tips what so ever on here, about riding in icy snowy (just general bad winter weather) weather.
Korn
Admin
PostPosted: 16:38 - 21 Dec 2004    Post subject: Reply with quote
Buy a car
3516 Miles, 11 Countries
Have a read of this thread.
Rob W
PostPosted: 16:48 - 21 Dec 2004    Post subject: Reply with quote
Dont think there's anything you can say other than cover your brakes and dont ride like a twat basically.
steveh
PostPosted: 16:53 - 21 Dec 2004    Post subject: Reply with quote
spiked tires Very Happy
Steve.
mr.z
PostPosted: 16:59 - 21 Dec 2004    Post subject: Reply with quote
If you can bring yourself to read it all you will be enlightened indeed...
Copeing with....
Arrow Cold
Arrow Dark
Arrow Ice
Arrow Winds
Arrow Rain
headlamp
PostPosted: 19:10 - 21 Dec 2004    Post subject: Reply with quote
The best recommendation I can make is go slower!
Using a mobile phone while driving a car should be made a capital offence!
Silver
PostPosted: 19:13 - 21 Dec 2004    Post subject: Reply with quote
...and fit stabilisers!
marc
PostPosted: 19:22 - 21 Dec 2004    Post subject: Reply with quote
i just done 260 motorway miles from Plymouth to Coalville on the R1 and I have to agree with Korn, take the car. Going home to Blackpool in the morning.
Fortuna
PostPosted: 20:00 - 21 Dec 2004    Post subject: Reply with quote
I ride my bikes all year round and don't own a car.
My advice would be:
Go easy on the throttle.
Keep warm.
Don't tense up (like you are expecting to crash).
Make sure everything is working on the bike.
Don't panic if you come across ice or slippery roads.
Short shift (lower power).
Be gentle on the brakes. (use the rear as well if going straight)
Don't be intimidated if you need to go slower but a car is up your arse.
If you can, ride in the car tyre tracks in the road as it should be clear there (more so when icy or snowing).
I find roundabouts a bit of a pain in winter and find car drivers give you no room. The trick is to keep as upright as you can and not make too much of a sharp arc. Ride as much as you can in the outer most tyre track (not right on the outside of the roundabout as there is loads of crap there) and once straight go to your lane. The only problem is car drivers will sometimes nick your space if you leave enough room even if indicating right.
Tip toe a little around roundabouts if you feel unsure, but still try to have confidence as you tend to tense up if you don't have any which actually makes your riding worse.
binge
Emo Kiddy
PostPosted: 20:46 - 21 Dec 2004    Post subject: Reply with quote
I dont tend to cover my brakes because if they are covered and you need to stop, instinct tells you to go WHAM if they are covered, whereas if you arent covering them, You have to physically move your fingers to the levers before applying them...
In wet, cold, icy, frosty weather I dont use my front brake at all, Only the back.
Ok, I put new rear pads on in october time and by feb they are ready for changing, but its better to be safe!
My advice, Ride a bit slower than you would normally and think before you make a turn, use your brakes etc...
<|Binge|>
mattsmith95
PostPosted: 21:15 - 21 Dec 2004    Post subject: Reply with quote
BUY A QUAD (unless you have to goto London, you have to pay CC for quads)
Rob W
PostPosted: 21:40 - 21 Dec 2004    Post subject: Reply with quote
<|Binge|>
Thing is, you have to take that split second to react and then apply your brakes, and that could be the decider. I only really cover the back brake, cos I can deal with the rear sliding about a bit, wouldnt like the front to go though.
K!K @
PostPosted: 02:09 - 22 Dec 2004    Post subject: Reply with quote
All true but you all missed out the main thing.
KEEP YOUR BIKE CLEAN!!!
If you dont then all the grit salt eats away at your bike.
Suzuki AY50 Katana
~Elite~Knights~
Jrod
Page 3 Girl
PostPosted: 03:24 - 22 Dec 2004    Post subject: Reply with quote
You don't use your front brake in the rain? I always do, just use it smooth and in conjunction with my back and it works a treat.
JonB
Afraid of Mileage
PostPosted: 10:34 - 22 Dec 2004    Post subject: Reply with quote
Make sure you keep your bike covered/in a garage at night cause it is so damn cold, my bike refuses to start sometimes after being left out in the cold. Once it is on let it warm up, so you get maximum response out of the engine to get yourselves out of a dangerous situation without causing too much stress to the engine. Smile
Dan 4RR
PostPosted: 11:19 - 22 Dec 2004    Post subject: Reply with quote
Ride slower than normal, espically round tight corners possibly.
Keep your eye out for any ice/slippy patches on the roads.
Keep yourself warm and protected if you do slip and fall (hopefully not.)
Suppose you could cover the brakes if you wanted to.
The last post was made 21 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 94.58 Kb
