wiring issues
jimkmx125
PostPosted: 23:27 - 24 Nov 2013    Post subject: wiring issues Reply with quote
kmx 125 wiring probs ,rear brake spring heating up like a toaster element any ideas on what would be causing this to happen
stickybackbob
PostPosted: 23:56 - 24 Nov 2013    Post subject: Reply with quote
Your electrics are earthing through the spring. Check all your connections and look for broken wires
jimkmx125
PostPosted: 00:29 - 25 Nov 2013    Post subject: Reply with quote
could this mean that the earth is not connected and the shortest way to ground is through the spring or that there is a broken live connecting with the frame somewhere ?
PostPosted: 00:39 - 25 Nov 2013    Post subject: Reply with quote
Not sure of the style of brake switch on the KMX, but presume you have a spring from the lever to the switch and it is this spring that is heating up. If so it suggest that the shaft the spring attaches to on the switch is metal and is shorting out internally to the contacts for the brake light switch.
I am also surprised is hasn't popped a fuse, unless that circuit is not protected by a fuse in which case the wiring might be getting a bit toasted.
WD Forte
PostPosted: 00:50 - 25 Nov 2013    Post subject: Reply with quote
I reckon he's talking about the switch spring and not the lever return spring too.
The one in a bracket above the rear brake master cylinder on the RHS?
As said, it sounds like a contact has come loose and is shorting to
ground via the metal plunger and spring.
A cheap easy fix
Just disconnect and tape the wires up until you fit a new switch
Even found a lubberly pitcher
Its the common as muck type found for a fiver on Ebay here
https://www.ebay.co.uk/itm/Motorcycle-Rear-Brake-Light-Switch-Universal-/181230599906?pt=UK_Motorcycle_Parts&hash=item2a322f7ee2
While I'm rantin on....
If you dont set the switch up right ,this can drag the guts out of them and they do need checking from time to time as brakes wear.
https://cars-database.com/data_images/gallery/02/kawasaki-kmx/kawasaki-kmx-06.jpg
bikers smell of wee
The last post was made 12 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 43.93 Kb
