| CaNsA |
 CaNsA Super Spammer
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| Tungtvann |
 Tungtvann World Chat Champion
| el_oso |
 el_oso World Chat Champion
 Posted: 15:37 - 30 Nov 2013 Post subject: |
It'd be a sod.
In the absence of a chain breaker tool, I'd just push a couple of pins through using a big set of mole grips with an M6 nut over one ond of the pin or, as said, hacksaw it.
How you fitting the new one if you don't have a chain tool? You going to use the fail-link? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| _Iain_ |
 _Iain_ Banned
 Posted: 16:15 - 30 Nov 2013 Post subject: |
A lot of big bike chains come with both clip & rivet links. The idea being you can fit the clip link at home, then ride to a bike shop & they'll rivet it up for a drink.
Would definately go buy a hacksaw though...the bigger ones will munch a 520 chain in under a minuite even with a naff blade...and a fiver for a pair of em is peanuts
https://www.machinemart.co.uk/shop/product/details/cht131-2-pce-hacksaw-set?da=1&TC=SRC-hacksaw
Could theoreticly be done with a drill if you ran it through the sideplates with like an 8mm bit then hit it with a hammer or something but would be ballache and fuck up the drill bits. ____________________ Please be aware that the above post may be full of complete nonsense.
| Copycat73 |
 Copycat73 World Chat Champion
| Vincent |
 Vincent Banned
| G |
 G The Voice of Reason
| Ichy |
 Ichy World Chat Champion
 Posted: 16:54 - 30 Nov 2013 Post subject: |
| G |
| Ichy |
 Posted: 17:04 - 30 Nov 2013 Post subject: |
It's possible but will take time. I have used an air powered version at work to grind out spot welds or to shape welds used as filler on damaged panels. I'd still prefer to use a die grinder for the tube. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| G |
| CaNsA |
 CaNsA Super Spammer
 Posted: 17:51 - 30 Nov 2013 Post subject: |
I havent read much after N.E's post.
Anyways, i used an old flat blade screwy and a hammer to prise the link plate over one of the softlink rivets, then used the chain tool to push the rivet out.
New sprockets are on, which is cool, but the chain is being a complete ballache.
The chain tool just isnt doing its thing that it needs to do to the rivet.
I'm thinking that if i file the lip of the punch to an angle it should spread the rivet head right?
https://i.imgur.com/mC892BB.png |
| G |
| CaNsA |
 CaNsA Super Spammer
| G |
| Skudd |
 Skudd Super Spammer
| sprintster |
 sprintster Borekit Bruiser
 Posted: 18:20 - 30 Nov 2013 Post subject: |
There's no reason a chain tool won't work if it's used properly.The different sized punches are for different sized chains.The punch will only have broke because it was too small for the chain.Use the larger punch and it should be fine.  |
| CaNsA |
 CaNsA Super Spammer
 Posted: 19:38 - 30 Nov 2013 Post subject: |
I think you've got your chain tool 180 degrees out.
Unless I've been doing them wrong for a long time, you wind the pin back in. The bit to the left of your picture goes behind the fixed part of the split link. You screw the course thread down so it sits over the hollow end of the pin then screw the fine thread down so the pin makes contact with the hollow. Now get a spanner on the fine thread and give it another turn or two and it should roll out the ends of the split link.
You can see it here in this picture I googled, you can see the marks where the outer part of the chain tool was screwed down against the sideplate too. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Clutchy |
 Clutchy World Chat Champion
 Posted: 19:50 - 30 Nov 2013 Post subject: |
Mole grips with a m6 nut
then
Hammer/hard thing behind chain, centre punch and small hammer, finish the job so the rivet is mushroomed.
Ain't no-body got time to buy a chain riveter. ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| CaNsA |
 CaNsA Super Spammer
| Raffles |
 Raffles World Chat Champion
| MarJay |
 MarJay But it's British!
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful? |
