| theogster |
 theogster Two Stroke Sniffer
| theogster |
| theogster |
 Posted: 15:46 - 06 Oct 2013 Post subject: |
Had my first kiss the road experience a couple of days ago... ouch lol...
I was only doing around 15mph, going around a corner that I've been around hundreds of times, it had been raining so the road was wet, but i have done that corner hundreds of times without issue, however when i got up i had oil on my pants from contact with the ground, so i reckon the fall was due to this.
However, the whole Chinese shit tyre rubber is stuck in my head, which is why I'm posting. i have to admit, it's made me a little paranoid so I'll be changing the tyres before winter, will probably go for some decent nobbly rubber...
Bikes ok, my knee protected the tank from scratches (ouch) bent the gear lever, but that was an easy fix with a large pair of monkey grips, other than that it was just the left hand bar end which got scratched up, so i'll spend a fiver on a new pair, no big deal.
Also, my 37ltr top box snapped off, it's a quick release type, & it snapped the rear mounting pins off the base plate, have melted pin holes in the back of the box & threaded 4 large cable ties through & around the mounting plate, so it's safe & secure, just not quick release any more lol  ____________________ I toast, Therefore I am... |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:28 - 08 Oct 2013 Post subject: |
Physicists searching for quantum gravity should get over it and just use cable ties.
Did you report the oil spill to your local council? ____________________ Biking is 1/20th as dangerous as horse riding.
| Mark65 |
 Mark65 World Chat Champion
| theogster |
 Posted: 14:14 - 01 Dec 2013 Post subject: |
got a little bit of rust around the bolts i had to re tighten on the indicator box & left rear view mirror, so i guess the coating on the bolts is bobbins lol..
not a big deal, but i'll replace them anyway, other than that i've not had any issues, & finally got around to giving it a wash wax & a protect spray (https://www.ebay.co.uk/itm/290954101628?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649)
not exactly acf-50, but it was what i could afford, might treat it to some acf as a christmas prezzie lols
gonna get a (very) cheap alarm for it, but have been warned they kill the battery very quickly, was wondering if any of you guys have any experience with them ____________________ I toast, Therefore I am... |
| Alpha-9 |
 Alpha-9 Super Spammer
| theogster |
 Posted: 19:31 - 23 Dec 2013 Post subject: |
Not looking good, just got on the bike to nip to the shop & cant change gear, too dark to mess around with it or even check fluid levels etc, hopefully i'll be able to sort it out in the morning.
either way i'll update here, might be the usual pile of chinese crap after all  ____________________ I toast, Therefore I am... |
| Oldie |
 Oldie Brolly Dolly
| theogster |
 Posted: 21:18 - 23 Dec 2013 Post subject: |
thanks for the reply m8, just got back from the shops & it seems mostly ok now, it's going down the gears fine, but is quite difficult shifting up, but it eased of the more i shifted.
i'd checked for any play in the clutch lever/cable seemed fine, unfortunately this isnt the first time i've had this issue, i mention it in an earlier post in this thread, tho, the last time it happened it wasn'y nearly as severe as it was today,
It's booked in for a service this saturday so i'll ask them to give the gears a good checking over while they have it.
thanks again for the reply  ____________________ I toast, Therefore I am... |
| bikersupermot... |
 bikersupermot... Could Be A Chat Bot
 Posted: 22:08 - 23 Dec 2013 Post subject: |
| theogster wrote: | thanks for the reply m8, just got back from the shops & it seems mostly ok now, it's going down the gears fine, but is quite difficult shifting up, but it eased of the more i shifted.
thanks again for the reply  |
take your clutch cable off the bike and hang it up by one end and oil it with a heavy oil ( gearbox oil mebe ). refit the clutch cable and make sure its correctly adjusted with a tiny bit of play at the lever and that it disegages drive between bike and engine. you should be able to have the bike in gear with engine off, pull clutch in and be able to push the bike fairly easily. ( there may be a little bit of drag but not much ).
if your clutch cable isnt properly adjusted then you could experience symptoms close to what your describing. ____________________ tinybikes |
| theogster |
| Oldie |
 Oldie Brolly Dolly
| Rogerborg |
 Rogerborg nimbA
 Posted: 01:00 - 24 Dec 2013 Post subject: |
| theogster wrote: | i'd checked for any play in the clutch lever/cable seemed fine |
What do you mean by "fine"?
There should be play in the clutch lever, just a few mm or so before tension comes on the cable. What you want to look for is when the actuator lever on the clutch housing starts to move when you pull on the lever. You should be able to see just a little bit of slack being taken up, then the lever moves.
They do gum up, my '305 needed the actuator cleaned and lubricated where it entered the housing. Here:
https://i41.tinypic.com/judzzd.jpg
The other thing to check is whether the gearshift lever is actually clamped onto the gear selector shaft properly. It'll likely be a simple split-end and bolt, and they do work loose so that you're moving the lever but not the shaft. Remove, examine, refit.
Also: WORKSHOP, NOOB. ____________________ Biking is 1/20th as dangerous as horse riding.
| theogster |
 Posted: 20:42 - 30 Dec 2013 Post subject: |
sorry i didnt reply, i usually get a notification but must have missed it
Righto, dropped the bike of for it's service at a new local bike dealer, (New Bikerz Grove on market St Farnworth) only just picked it up today.
service done £60, had allready asked them to check out the gears, & it turns out the gear linkage was assembled incorrectly, which was causing it to move sideways a little, making it occasionally jam up against a bolt, so they stripped it down reassembled/lubed it using what they hoped where the correct looking sized bolt etc, & it now seems fine, in fact to be honest it's much better than when it was new, as the gear shifting was allways quite stiff.
& i have to recommend the shop, as many would have fleeced me (knowing how little i know & taking advantage) but they asked for no extra money.. I passed an extra £20 over as a thank you, bearing in mind i still only paid £80 in total, & the original dealer (moto centre bolton) wanted £125 for the 4 month service !!! ____________________ I toast, Therefore I am... |
There is a gap of 1 year, 335 days between these two posts... |
| beggy |
 beggy L Plate Warrior
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:26 - 01 Dec 2015 Post subject: Re: Help!! Review/information needed for Lexmoto Arizona 125 |
They don't come with an alarm as standard, so you might help yourself by explaining what you mean by "alarm blanking connector" and why you'd think it would be specific to the Arizona.
This question is relevant to the issue of BUMPing an historic thread in the wrong section. ____________________ Biking is 1/20th as dangerous as horse riding.
| MarJay |
 MarJay But it's British!
 Posted: 09:51 - 01 Dec 2015 Post subject: |
What is it with the bumping of old threads all of a sudden?  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:10 - 01 Dec 2015 Post subject: |
Google rankings.
Hmm, there is a "Lextek" alarm and a mystery "alarm blanking connector". Dealer option?  ____________________ Biking is 1/20th as dangerous as horse riding.
| beggy |
| arry |
 arry Super Spammer
| beggy |
| arry |
 arry Super Spammer
| Rogerborg |
 Rogerborg nimbA
The last post was made 10 years, 271 days ago. Instead of replying here, would creating a new thread be more useful? |
