LEDS indicators on a suzuki gn125
Jamie Ecorz Campbell
PostPosted: 20:03 - 01 Dec 2013    Post subject: LEDS indicators on a suzuki gn125 Reply with quote
Ive put four led indicators on my suzuki gn125 1994 plus the relay for the indicators but only three of four flashes and the three flashes at the same time, can someone help me please
RhynoCZ
PostPosted: 20:13 - 01 Dec 2013    Post subject: Reply with quote
Swap cables from the one that does not work, that should sort that out. LEDs won't work both ways, I mean +- /-+. You've got to have it right. Thumbs Up
But, I'm quite clueless about the all three (four) working at the same time. Thinking
davebike
PostPosted: 08:45 - 02 Dec 2013    Post subject: Reply with quote
If your bike has One indicator follower light not separate ones for left and right indicators You will have to do a lot of mods to it to make the indicators work with LED units
Disconnect both wires connect both feeds to the light
reconnect to one side each via it own Diode 1Amp 50volt will do
connect the other side to -ve ie bike's earth
Try again if a unit doesn't work swap the wires around LED only work one way around unlike bulbs
DAve
Dave
NC750Xdct + others at work !
[email protected]
Teflon-Mike
tl;dr
PostPosted: 15:53 - 02 Dec 2013    Post subject: Reply with quote
Do you have a 'tell-tale' lamp in the speedo that flashes when the indicators are on?
The thing is that if you only have one tell-tale to say when either indy is on, rather than one for each direction; then the chances are that its a 'balenced circuit'... the 'tell-tale' connected between the two circuits for left and right indicators, so when you put 12v on the Left indy circuit, you get 12v at one side of the tell-tale bulb, and it 'earths' through the right hand circuit, relying on the 21W indy bulbs in the side not switched on, to have enough resistance in them that they dont light up from the current going through them.
Of course... having fitted LED inicators, that now draw mA, the tell-tale is probably sucking more amps than they are, and the LED indies WILL light up from the few mA thats left over after volts have gone through the tell-tale in between the two circuits.
Pull the tell-tale out the speedo, pop the bulb out and try again; see if both circuits flash independently.
If they do; then you will either have to go without indy tell-tale... its not actually required for MOT provided you can see the front indicators from saddle.... OR you will need to wire in a diode-bridge and earth to the tell tale lamp, so that it gets volts via a one way diode from either left or right indy circuit, that cant 'back-flow' through the 'off' side, and then earths directly.
If you use the forum search function; somewhere there is a How2 to do this I wrote a few years back, with scematics and probably e-bay links for the penny components you'll need.
Add on Edd:-
Anomolies with LED Lamps, & Indicators
PostPosted: 01:37 - 07 Dec 2013    Post subject: Reply with quote
what do you tell tales , im still new to electrics
WD Forte
PostPosted: 02:23 - 07 Dec 2013    Post subject: Reply with quote
Heres a quick and dirty pic I put on my photobucket account
soem time ago for a guy elsewhere
who fitted led lamps and had single tell tale
light with similar problems to you
If you want to use an led instead of the original bulb,
you'll need to get the polarity right and use a
current limiting resistor in series.
I always find a 1K is ample for idiot light/tell tale purposes
and thats what I use on all the panel/idiot light leds on my bike and they're plenty bright enough.
those diodes are just some chunky ones I had on my desk
at the time.
Something like a couple of 1N4001 will do, dirt cheap orf the bay.
Maplins will want about 50p each for them
https://i115.photobucket.com/albums/n302/reggiecx/idiotlighst_zps5ff22d39.jpg
bikers smell of wee
WD Forte
PostPosted: 16:57 - 07 Dec 2013    Post subject: Reply with quote
Course, another way to do it is have the tell tale powered up on one side when the bike gets switched on and have its ground connected to the cable from the flasher unit to selector switch.
this will work on a lot of bikes but not all and if the light is part of a cluster with a common ground, there may be practical difficulties in doing this.
The simplest solution is usually the best.
bikers smell of wee
Teflon-Mike
tl;dr
PostPosted: 19:41 - 07 Dec 2013    Post subject: Reply with quote
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/LD07%20Clocks/imag0991.jpg
These three lamps in the middle of a CB125 'dash-board' for example.
Hi-Beam
Turn
Neutral
Lamps that 'tell' you something is doing something, rather than a lamp thats iluminating something else, like the speedo back-light, or common, but not on this instrument cluster, the lamps that tell you that there's no oil pressure or no charge going into the battery.
There is a gap of 1 year, 33 days between these two posts...
carkifelek
PostPosted: 22:20 - 09 Jan 2015    Post subject: Reply with quote
Jamie, this is a typical wiring issue. A simple way to get around such a problem once you come across it is to simply plug out the LED which isn’t working and swap it with a LED that you know worked previously and check if it works. In most situations, none of them would work and that would confirm the wiring issue. If it works, then it’s simple, you just go on replacing the faulty LED. The common issue with most wirings is the reversal of power and ground pins or improper connections. Please check them out.
pcb price
Snipet
PostPosted: 22:33 - 09 Jan 2015    Post subject: Reply with quote
https://www.rctech.net/forum/attachments/electric-road/405988d1231872828-new-protoform-r9-f-body-holy_thread_resurrection_batman.jpg
First Bike: Pulse Rage 125cc Second Bike: Kymco KR Sport 125cc Third Bike: Kawasaki ZR7-S 750cc
Forth Bike Honda VFR 750cc Fifth Bike Honda NT650 Deauville Fifth Bike Suzuki GSX650F
The last post was made 11 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 69.15 Kb
