Advice
TomReilly
PostPosted: 11:24 - 02 Dec 2013    Post subject: Advice Reply with quote
Just wondering,
when I push/drive the bike forward I can hear a slight creaking metal noise coming from my chain and rear sprocket and am wondering what it could be, I think my chain is dry as I have not lubed it in a while but it is not totally dry, I gave it a clean with WD-40 and it went away for about a day, also if I roll it backwards it is silent as it should be...
so do I need a good lubin'?
Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. Wink
CaNsA
PostPosted: 11:27 - 02 Dec 2013    Post subject: Reply with quote
You have a dry chain.
You hear a squeak from the chain.
Could be pads > disc.
Could be bearings.
TomReilly
PostPosted: 11:35 - 02 Dec 2013    Post subject: Reply with quote
Wouldn't call it a squeak, more like a crackling metallic sound, creaking etc.. it eventually goes away after 3rd gear, but yeah I do think its too dry, will get hold of some lubricant soon
davebike
PostPosted: 11:39 - 02 Dec 2013    Post subject: Reply with quote
Use chain Lub not WD40
WD40 is not good for ordinary chains and kills O ring chains
You have a dry chain and possible a worn out one and worn out sprockets
Dave
Dave
NC750Xdct + others at work !
[email protected]
TomReilly
PostPosted: 11:41 - 02 Dec 2013    Post subject: Reply with quote
Installed new chain, front sprocket and rear about a month ago they're all great condition, so that's why I presumed it could be dry which I'm guessing it is
davebike
PostPosted: 11:48 - 02 Dec 2013    Post subject: Reply with quote
A month no lub Embarassed
Keep that up and you will be buying another set
Lub the chain at least once a week more in wet weather
Dave
Dave
[email protected]
TomReilly
PostPosted: 12:11 - 02 Dec 2013    Post subject: Reply with quote
Really once a week? Didn't know that Embarassed
Skudd
PostPosted: 12:17 - 02 Dec 2013    Post subject: Reply with quote
Lube up as often as you can in this weather, also wash your bike down as often as you can to keep the salt off, You may want to keep an eye on your brake callipers too.
TomReilly
PostPosted: 13:02 - 02 Dec 2013    Post subject: Reply with quote
Was planning a jet wash tonight, been putting it off for a while now
PostPosted: 13:08 - 02 Dec 2013    Post subject: Reply with quote
Lube the chain when it needs it. If the chain is dry it needs lube. Do not use WD40. Use proper chain lube from a decent manufacturer. I use Castrol Chain Wax personally. Some people swear by Wurth chain lube.
In the old days I used to use Yoshimoto 'kin good but I don't think they make that any more.
TomReilly
PostPosted: 17:24 - 02 Dec 2013    Post subject: Reply with quote
_Iain_ wrote:
Also not a particularily great idea.
Make sure the bike is left running, that you don't directly spray any wiring connectors and that you stop if the bikes idle changes even slightly. Also avoid getting anything down the exhaust.
You've got a chinese bike from memory, the connectors and waterproofing on the electrics wasn't great from the factory and prone to failiure under light rain....how do you suppose it'll react to highly pressurised water being blasted at it? Laughing
Bucket & sponge, parrafin & toothbrush to clean the chain (or better yet, chain cleaner)
Chinese bikes need constantly washing to prevent them turning into rust infront of your eyes. Putting it off is likely to see you without a useable bike very quickly, as is skimping on basic stuff like lubricating chains etc. You probbably should consider using ACF50 coming into winter too.
Basicly, once a week this;
https://www.youtube.com/watch?v=NLIWPnHJoR4
Ah cool, the more I know the better, I'll give that a watch in a bit.
The last post was made 12 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 81.78 Kb
