Front sprocket securing help!
eddie011
PostPosted: 10:54 - 03 Dec 2013    Post subject: Front sprocket securing help! Reply with quote
Ok so I have a sachs x-road 125 08 model
I notice to hear a funny sound coming from the engine
I thought it was the gear box slipping
But it took my chain to snap while I was riding it to notice the front
Sprocket is wobbly and moves about is there anything I can do to secure this and can someone explain how to take off and fit them properly
Iv attached a pic of the sprocket and other part
That comes with it
jeddy11
PostPosted: 11:06 - 03 Dec 2013    Post subject: Reply with quote
Fronts sprokets are designed to have play in them so they wont bolt on solid or the inpput shaft could be damage if everything isn't lined up properly..
When you renew the sprokets and chain make sure everything is lined up and on the right way round and tension of the chain is correct.. Thumbs Up
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
Marmalade
PostPosted: 11:08 - 03 Dec 2013    Post subject: Reply with quote
The sprocket slips on, the plate goes on and twists to stop sprocket coming off and you put the bolts in to hold plate in place
These always wobble a little bit but not a great deal.
Best to take it off and look for wear on the shaft or sprocket.
best to replace either if worn but hopefully sprocket out of either as they cost very little.
map
Mr Calendar
PostPosted: 11:12 - 03 Dec 2013    Post subject: Reply with quote
FWIW WEMoto tells me with that retainer it'd be a Morini engine - click here for parts.
As said above should be straightforward. Only difference is use of the retaining clip and bolts.
Also FWIW motorcyclenews.com did an article on replacing chain/sprockets - click here for article.
eddie011
PostPosted: 11:26 - 03 Dec 2013    Post subject: Reply with quote
Thanks for the reply guys ,
The drive shaft seems ok no play in it I just thought front sprocket had to be solid but maybe I might be wrong in saying the chain might have to much slack and the nose is the chain bouncing and sliding along the swing arm
CaNsA
PostPosted: 11:28 - 03 Dec 2013    Post subject: Reply with quote
A front sprocket should have a bit of wobble.
It's normal.
YBR Ric
PostPosted: 17:25 - 03 Dec 2013    Post subject: Reply with quote
Mine's held in place with a massive nut and 132Nm of torque, definately not wobbly Wink
PostPosted: 20:32 - 03 Dec 2013    Post subject: Reply with quote
If it has that kind of retaining plate then I suggest putting a bit of loctite on the threads of the 2 small bolts. They don't need to be that tight, but you don't want them coming undone.
331X2
PostPosted: 22:00 - 03 Dec 2013    Post subject: Reply with quote
Just don't weld it on like one of our less mechanically sympathetic members Smile
PostPosted: 22:08 - 03 Dec 2013    Post subject: Reply with quote
No, don't weld it Smile
Do grease the splines though to reduce wear.
331X2
PostPosted: 22:47 - 03 Dec 2013    Post subject: Reply with quote
I was always under the impression you shouldn't grease splines? Or is that splines that are machined to tighter tolerances (ie car driveshaft/hub interface)?
PostPosted: 22:57 - 03 Dec 2013    Post subject: Reply with quote
Always grease splines (unless in an oil lubricated environment)
Triumph Trophy Launch Edition
PostPosted: 00:47 - 04 Dec 2013    Post subject: Reply with quote
If you rub two pieces of dry metal together, they will wear each other out. If they are lubed they won't. Always grease the splines.
Hugh Farking Cant
PostPosted: 10:30 - 04 Dec 2013    Post subject: Reply with quote
It is called "fretting", Pete.
It is what causes the rusty stains found on many parts and as you state ,is to be avoided.
The last post was made 12 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.05 - MySQL Queries: 13 - Page Size: 82.54 Kb
