| eddie011 |
 eddie011 Two Stroke Sniffer
| jeddy11 |
 jeddy11 Traffic Copper
 Posted: 11:06 - 03 Dec 2013 Post subject: |
Fronts sprokets are designed to have play in them so they wont bolt on solid or the inpput shaft could be damage if everything isn't lined up properly..
When you renew the sprokets and chain make sure everything is lined up and on the right way round and tension of the chain is correct..  ____________________ Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!! |
| Marmalade |
 Marmalade World Chat Champion
 Posted: 11:08 - 03 Dec 2013 Post subject: |
The sprocket slips on, the plate goes on and twists to stop sprocket coming off and you put the bolts in to hold plate in place
These always wobble a little bit but not a great deal.
Best to take it off and look for wear on the shaft or sprocket.
best to replace either if worn but hopefully sprocket out of either as they cost very little. ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky |
| map |
 map Mr Calendar
 Posted: 11:12 - 03 Dec 2013 Post subject: |
FWIW WEMoto tells me with that retainer it'd be a Morini engine - click here for parts.
As said above should be straightforward. Only difference is use of the retaining clip and bolts.
Also FWIW motorcyclenews.com did an article on replacing chain/sprockets - click here for article. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| eddie011 |
| CaNsA |
 CaNsA Super Spammer
| YBR Ric |
 YBR Ric Spanner Monkey
 Posted: 17:25 - 03 Dec 2013 Post subject: |
Mine's held in place with a massive nut and 132Nm of torque, definately not wobbly  |
| 331X2 |
 331X2 Crazy Courier
 Posted: 22:00 - 03 Dec 2013 Post subject: |
Just don't weld it on like one of our less mechanically sympathetic members  |
 Posted: 22:08 - 03 Dec 2013 Post subject: |
No, don't weld it
Do grease the splines though to reduce wear. ____________________ a.k.a 'Geri'
| 331X2 |
 331X2 Crazy Courier
| Polarbear |
 Polarbear Super Spammer
 Posted: 00:47 - 04 Dec 2013 Post subject: |
If you rub two pieces of dry metal together, they will wear each other out. If they are lubed they won't. Always grease the splines. ____________________ a.k.a 'Geri'
| Hugh Farking Cant |
 Hugh Farking Cant Scooby Slapper
The last post was made 12 years, 215 days ago. Instead of replying here, would creating a new thread be more useful? |
