Tl1000r electrical issues
GhostRider
PostPosted: 18:36 - 03 Dec 2013    Post subject: Tl1000r electrical issues Reply with quote
So bought a TL1000r couple of weeks ago, 2 days later try to start it up after work and it wouldn't fire up, had to get Tarmacsurfer to come rescue me giving me a jump start from his robin reliant Laughing
So anyway I figured it was simply a case of worn down battery, bought a Motobatt to replace it, fitted that in this Saturday just gone, have used the bike perhaps 5-6 times since then travelling 6-8 miles each time, finish work today and again will not start, it tries to turn over but seems just not enough to get it going. I tried bumping a few times then retried electric start and fortunately it fired up this time.
My limited knowledge suggests probably the Reg/Rec is fucked and so isnt recharging the battery whilst its in motion, either that or the Datatool alarm is sapping all power from the battery - though I'd be suprised if it could drain a brand new battery in 3 days.
Is there a simple way to test the Reg/Rec? What else could it be?
The cheaper the solution the better, this bike is rapidly turning into a blackhole for money, so I just want to get the issue sorted so I can sell it on, and since I will no doubt be making a loss when doing so, I've no interest in spending a lot of money sorting this problem out.
Cheers,
GhostRider
Hetzer
PostPosted: 18:40 - 03 Dec 2013    Post subject: Reply with quote
Could it be the sprag thingy? It firing up after you tried to bump it suggests something might have come unstuck and I've read the sprag thing can cause problems as it's related to the clutch/starter in some way.
V-twins have sprags...your bike is a v-twin?
sickpup
Old Timer
PostPosted: 18:52 - 03 Dec 2013    Post subject: Reply with quote
Virtually every bike that doesn't have a CV drive uses a sprag clutch on the starter motor. The sprag clutch is irrelevant to the starter motor not turning over, in fact if it wasn't functioning the starter would just spin.
More likely to be a charging problem, use multimeter to test.
GhostRider
PostPosted: 18:55 - 03 Dec 2013    Post subject: Reply with quote
Yeah its a V-twin, any ideas where I might find said Sprag or how I would identify if its the issue?
Multi meter on the battery when its running and see if it goes to around 14v when revved, if it does then the reg/rec is ok, but something has to be really wrong for a mottbatt to go flat, so my moneys on the shitty alarm.
Also lulz @ robin reliant.
At the risk of sounding stupid is there an easy way to stop the fucking alarm from working, I need to be able to ride the bike daily for the rest of the week and theres every chance at the moment that every time I stop, I have no guarantee it will start again so could be stranded in the middle of fucking nowhere, so will happily tear the thing out if I can do so in a way that will leave the bike working.
GhostRider
WD Forte
PostPosted: 19:03 - 03 Dec 2013    Post subject: Reply with quote
Assuming the battery being new isnt the cause
and as its a new to you machine.
I'd start by testing the stator first then the rectifier and
then when its running, the regulator to know if the battery is getting properly charged when running.
I reckon its a good idea to check these from time to time anyway
plus all related cables and connectors.
If they all check out OK, I'd get a meter set to read current and with the bike turned off, remove the battery positive lead and see how much, if any, current is flowing with or without the alarm connected.
I wouldnt want to see any more than say 100mA running through the alarm in its standby state.
If the battery looks OK but the starters lazy
its possible the starter brushes are worn or it has poor grounding
Dont know the TL personally but some bikes suffer from a poor grounding on the brush plate inside the motor.
Power gets down from the battery and in via the positive brush and through the armature and commutator OK but the negative brush often relies on physical contact from the brushplate to the starter body for a ground and any poor connection here can lead to arcing which develops a higher resistance as it worsens.
This can cause erratic starting.
bikers smell of wee
GhostRider
PostPosted: 19:16 - 03 Dec 2013    Post subject: Reply with quote
Checked voltage across battery before starting, was at 16-17v. Started up bike and revved up to 5k (kinda hard to rev it much further without really pissing off the neighbours as its a rather loud bike) and it didnt drop below 15v. I'm guessing this rules out reg/rec then?
It did this with the battery in that came with it, replacing the battery hasn't resolved anything so dont think it can be rounded down to the battery.
Sorry I should have started by explaining that I'm a complete retard when it comes to these things - I'd like to test each of what you're saying but I'm gonna need step by step instructions if I'm to have any hope of taking accurate measurements/getting the right answers Thumbs Up
GhostRider
stu_m
PostPosted: 19:29 - 03 Dec 2013    Post subject: Reply with quote
first thing to do is to put NEW plugs in
these bikes are notorious for fouling them and without decent new plugs you are pissing in the wind
also get another multimeter theres no way you can have 16-17v at the battery when its not running
also the charging system on these are shite and unless its been modified the volts will drop when you rev the bike
stu_m
PostPosted: 19:32 - 03 Dec 2013    Post subject: Reply with quote
it wont be the starter clutch if it turns over theres nothing wrong with it and these very rarely fail infact I dont know of any that have failed on the S or the R
GhostRider
PostPosted: 19:42 - 03 Dec 2013    Post subject: Reply with quote
Apparently the plugs were replaced but 1000 miles ago.
Have taken the battery out to charge it overnight, will check again shortly to see what voltage is across the battery.
GhostRider
sickpup
Old Timer
Suggests the batteries in your multimeter need changing.
Lead acid cells have a nominal voltage of around 2.1-2.2v whereas according to your multimeter yours have 2.8v so something is up.
stu_m
PostPosted: 19:46 - 03 Dec 2013    Post subject: Reply with quote
GhostRider
I would replace them again
and while your at it trim the HT leads about half an inch too
do you get FI on the dash while cranking too?
WD Forte
PostPosted: 19:52 - 03 Dec 2013    Post subject: Reply with quote
16-17V?
oooh! thats not right
As said, check your meter, it may just need a new battery
you dont want even 15V across the battery terminals
about 14-14.5v is normal when running.
Trying to think of a quick and dirty meter test here
You could try it on say a new 9V battery and if it doesnt read 9V as near as dammit, the meters at fault.
You may see 8.8 ish on a used 9v battery
PC power supplies come to mind, you'll get a pretty good 5v and 12v there but if you're not happy digging about in the guts of a PC, leave it alone.
I'm afraid that until you have a meter that can be relied on, testings off the menu.
While the Tl may be heavy on plugs it should still turn over the engine smartly on a good battery even if it doesnt start.
New plugs on a machine with unknown service history is a good idea, but I kind of doubt thats the cause of your problems
bikers smell of wee
WD Forte
PostPosted: 19:59 - 03 Dec 2013    Post subject: Reply with quote
While I'm rantin on....
If you measure the voltage on a battery just off charge or on a bike just switched off, you'll normally get an artificially high reading
A healthy battery left overnight at room temperature should give about 12.65V
One thats getting bit tired may show say 12.45V like mine
As they get older, less.
These are 'no load' figures ie nothing connected to them to draw power
bikers smell of wee
stu_m
PostPosted: 20:01 - 03 Dec 2013    Post subject: Reply with quote
you wont get that from a running TL
the charging system is piss poor and your lucky if you get 13V when running and this will drop when revved!!
theres a very easy mod you can do to get 14+ volts at the battery
if your doing short runs then it could be that your battery is not getting charged enough from starting
but the motobatt should crank the TL over and fire straight up all the time! I have a motobatt on my TLS and it cranks over and fires first go
WD Forte
PostPosted: 20:18 - 03 Dec 2013    Post subject: Reply with quote
That sounds pretty dire
Dont know the TL myself so did a wee google search out of interest and found this.
https://www.tlzone.net/forums/suzuki-tl1000r-tl1000s-forum/134126-need-serious-electrical-help-98-tl1000r-please-4.html
bikers smell of wee
stu_m
PostPosted: 20:28 - 03 Dec 2013    Post subject: Reply with quote
yup it is pretty shit!
you even get as much as 4volt drop at the headlight connectors through the crappy wiring!!
the link you really want is this
https://www.tlzone.net/forums/frequent-tl-mods/111499-definitive-charging-system-diagnostic-upgrade-thread.html Very Happy
and if you do the charging system mod you need to run the headlights off relays
https://www.tlzone.net/forums/frequent-tl-mods/111776-crappy-suzuki-wiring.html
these two alone make a huge difference
also join up at tlzone.net and ask there but you will only get start with new plugs Laughing
GhostRider
PostPosted: 21:28 - 03 Dec 2013    Post subject: Reply with quote
Fuck me I wish I'd known about all these issues beforehand I'd have ran a fucking mile from buying it Crying or Very sad
GhostRider
stu_m
PostPosted: 21:39 - 03 Dec 2013    Post subject: Reply with quote
GhostRider
there not so much an issue its just improvements Wink
Ive had my TLS 7 years and love it
the S and the R inherit the same problems and if you keep on top of them they are great bikes Smile
stu_m
PostPosted: 21:45 - 03 Dec 2013    Post subject: Reply with quote
Rob Fzs wrote:
£800 quid for it taken away next week sometime if you're really stuck Very Happy
theres someone selling one for that on tlzone.net although it needs work
Fisty
PostPosted: 21:54 - 03 Dec 2013    Post subject: Reply with quote
68,000 miles on mine and the electrics have been fine.
Fatter and faster than Fret
GhostRider
PostPosted: 21:58 - 03 Dec 2013    Post subject: Reply with quote
Rob Fzs wrote:
GhostRider
I'd rather suck off 10 homeless guys with bleeding dicks in an alley.
GhostRider
The last post was made 12 years, 76 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 138.38 Kb
