| GhostRider |
 GhostRider World Chat Champion
 Posted: 18:36 - 03 Dec 2013 Post subject: Tl1000r electrical issues |
So bought a TL1000r couple of weeks ago, 2 days later try to start it up after work and it wouldn't fire up, had to get Tarmacsurfer to come rescue me giving me a jump start from his robin reliant
So anyway I figured it was simply a case of worn down battery, bought a Motobatt to replace it, fitted that in this Saturday just gone, have used the bike perhaps 5-6 times since then travelling 6-8 miles each time, finish work today and again will not start, it tries to turn over but seems just not enough to get it going. I tried bumping a few times then retried electric start and fortunately it fired up this time.
My limited knowledge suggests probably the Reg/Rec is fucked and so isnt recharging the battery whilst its in motion, either that or the Datatool alarm is sapping all power from the battery - though I'd be suprised if it could drain a brand new battery in 3 days.
Is there a simple way to test the Reg/Rec? What else could it be?
The cheaper the solution the better, this bike is rapidly turning into a blackhole for money, so I just want to get the issue sorted so I can sell it on, and since I will no doubt be making a loss when doing so, I've no interest in spending a lot of money sorting this problem out.
Cheers,
GhostRider ____________________ I have all the characteristics of a human being: blood, flesh, skin, hair; but not a single, clear, identifiable emotion, except for greed and disgust. Something horrible is happening inside of me and I don't know why. My nightly bloodlust has overflown into my days. I feel lethal, on the verge of frenzy. I think my mask of sanity is about to slip. |
| Hetzer |
 Hetzer Super Spammer
| N cee thirty |
 N cee thirty Banned
| sickpup |
 sickpup Old Timer
| GhostRider |
 Posted: 18:55 - 03 Dec 2013 Post subject: |
| Hetzer wrote: | Could it be the sprag thingy? It firing up after you tried to bump it suggests something might have come unstuck and I've read the sprag thing can cause problems as it's related to the clutch/starter in some way.
V-twins have sprags...your bike is a v-twin? |
Yeah its a V-twin, any ideas where I might find said Sprag or how I would identify if its the issue?
| Quote: | Multi meter on the battery when its running and see if it goes to around 14v when revved, if it does then the reg/rec is ok, but something has to be really wrong for a mottbatt to go flat, so my moneys on the shitty alarm.
Also lulz @ robin reliant. |
At the risk of sounding stupid is there an easy way to stop the fucking alarm from working, I need to be able to ride the bike daily for the rest of the week and theres every chance at the moment that every time I stop, I have no guarantee it will start again so could be stranded in the middle of fucking nowhere, so will happily tear the thing out if I can do so in a way that will leave the bike working.
| WD Forte |
 WD Forte World Chat Champion
| N cee thirty |
 N cee thirty Banned
| GhostRider |
 Posted: 19:16 - 03 Dec 2013 Post subject: |
Checked voltage across battery before starting, was at 16-17v. Started up bike and revved up to 5k (kinda hard to rev it much further without really pissing off the neighbours as its a rather loud bike) and it didnt drop below 15v. I'm guessing this rules out reg/rec then?
| WD Forte wrote: | Assuming the battery being new isnt the cause
and as its a new to you machine. |
It did this with the battery in that came with it, replacing the battery hasn't resolved anything so dont think it can be rounded down to the battery.
| Quote: |
I'd start by testing the stator first then the rectifier and
then when its running, the regulator to know if the battery is getting properly charged when running.
I reckon its a good idea to check these from time to time anyway
plus all related cables and connectors.
If they all check out OK, I'd get a meter set to read current and with the bike turned off, remove the battery positive lead and see how much, if any, current is flowing with or without the alarm connected.
I wouldnt want to see any more than say 100mA running through the alarm in its standby state.
If the battery looks OK but the starters lazy
its possible the starter brushes are worn or it has poor grounding
Dont know the TL personally but some bikes suffer from a poor grounding on the brush plate inside the motor.
Power gets down from the battery and in via the positive brush and through the armature and commutator OK but the negative brush often relies on physical contact from the brushplate to the starter body for a ground and any poor connection here can lead to arcing which develops a higher resistance as it worsens.
This can cause erratic starting. |
Sorry I should have started by explaining that I'm a complete retard when it comes to these things - I'd like to test each of what you're saying but I'm gonna need step by step instructions if I'm to have any hope of taking accurate measurements/getting the right answers
| stu_m |
 stu_m Crazy Courier
| stu_m |
 stu_m Crazy Courier
| GhostRider |
| sickpup |
 sickpup Old Timer
| stu_m |
 stu_m Crazy Courier
| WD Forte |
| WD Forte |
| stu_m |
 stu_m Crazy Courier
| WD Forte |
| stu_m |
 stu_m Crazy Courier
| GhostRider |
 Posted: 21:28 - 03 Dec 2013 Post subject: |
Fuck me I wish I'd known about all these issues beforehand I'd have ran a fucking mile from buying it
| stu_m |
 stu_m Crazy Courier
| N cee thirty |
 N cee thirty Banned
| stu_m |
 stu_m Crazy Courier
| Fisty |
 Fisty Super Spammer
| GhostRider |
| N cee thirty |
 N cee thirty Banned
The last post was made 12 years, 89 days ago. Instead of replying here, would creating a new thread be more useful? |
