Internet thermostats
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
goto10
PostPosted: 00:51 - 04 Dec 2013    Post subject: Internet thermostats Reply with quote
I quite fancy the idea of these, anyone have one or have any feedback on them?
Not sure which to go for, seems to be out of these 3...
Hive ( https://www.hivehome.com ), Salus IT500 ( https://www.salus-tech.com/products/thermostat/it500 ) or the tado ( https://www.tado.com/ )
CaNsA
PostPosted: 00:57 - 04 Dec 2013    Post subject: Reply with quote
Cant be arsed to set the heating timer to come on 30mins before you get home / get up?
Cant be arsed to turn the thermostat down/up?
I'll just sit here and wait for your forthcoming "I have been diagnosed as diabetic and morbidly obese" thread.
goto10
PostPosted: 01:29 - 04 Dec 2013    Post subject: Reply with quote
Pffffft. I'm not looking for logic - it's 55% shinier than my current thermostat and it involves internetz and appz, therefore it must be good.
I'll be bored of it within 15 minutes of installation, but it's the momentary high of a new gadget that I crave.
#consumerism
So anyway, anyone?
ScaredyCat
PostPosted: 09:13 - 04 Dec 2013    Post subject: Reply with quote
Look at the heatmeiser ones. They have wifi ones and the protocol is fairly well documented and code already exists to use them (run it on a raspberryPi)
https://code.google.com/p/heatmiser-wifi/
All the ones you mentioned rely on the company selling them continuing their service. Which means if your internet goes down, no thermostatic control. If their servers die, no thermostatic control, if they go bust... you get the picture...
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
James83
PostPosted: 11:54 - 04 Dec 2013    Post subject: Reply with quote
Heating timer? Thermostat? Whats wrong, can't be arsed to go out, chop some wood, build a fire and keep it fed?
goto10
PostPosted: 13:52 - 04 Dec 2013    Post subject: Reply with quote
Nice, looks a little clumsier to install (need a 4th wire from the 'stat for the HW switching, unless the RF version does this wirelessly, I've not researched enough yet) but overall looks like the one to go for
( https://code.google.com/p/heatmiser-wifi/
*rubs thighs furiously*)
Tarmacsurfer
PostPosted: 15:35 - 04 Dec 2013    Post subject: Reply with quote
They're a good idea for those of us who actually have a life and don't always get back/leave the house at a set time Laughing
Used a Salus setup before, wasn't wildly impressed. Currently looking at THIS, UK based company and have seen decent comments around the home automation forums.
I'm immortal. Well, so far.
There is a gap of 297 days between these two posts...
ScaredyCat
PostPosted: 22:31 - 27 Sep 2014    Post subject: Reply with quote
sorry to necropost but it's kind of important .
If you get a heatmiser wifi thermostat do not port forward your router ports to it. There's a massive* security flaw in them - Anyone can retrieve the username and password for your device and, consequentially, log in and change anything they like.
*read that as totally retarded
If you're desperate to access it over t'internet then use port knocking or a vpn or something.
PostPosted: 12:46 - 29 Sep 2014    Post subject: Reply with quote
$HOUSE#1: Possible thermal failure (on fire?)
There is a gap of 1 year, 102 days between these two posts...
goto10
PostPosted: 00:47 - 10 Jan 2016    Post subject: Reply with quote
To necropost on your necropost, the Heatmiser is now removed. Their support was non-existent, the app was useless and the inbuilt web server was a security liability and no updates were forthcoming. As a standalone thermostat it worked fine, but that was missing the point of having it.
The direct IP-connection had pros and cons, but on reflection I think relying on a 3rd party server is actually a better solution for usability (and security)*
I've now switched to a 3rd gen Nest - the hardware/software is light years ahead of the Heatmiser stuff (and it was _way_ easier to install) - the movement sensors and usage of geolocation for setting home/away status all looks good too (Google Now can estimate how long it'll take you to get home and warm the house up for your arrival, or it can detect when no one's been home for a while and set the system to 'away') - it's currently learning our routine so I'll reserve judgement on this for the moment...
*However, the Nest web service went down for two hours earlier this evening. Oh the delicious irony.
panrider_uk
PostPosted: 12:12 - 10 Jan 2016    Post subject: Reply with quote
I have the Salus IT500.
A pretty good piece of kit for the money.
Lets you have 6 time/temp settings per day.
Piece of cake to install and just works.
RhynoCZ
PostPosted: 12:27 - 10 Jan 2016    Post subject: Reply with quote
A friend of mine has a remotely controlled thermostat in his mountain cottage. His works with a GSM sim card, the only thing to turn the heating on, or regulate the temperature, he needs to send a SMS. It is pretty neat thing to have, as when he decides he wants to go there for a weekend, he can start the heating a day or two before that, so he comes to a warm cottage.
Anyone having the call number of the sim card, can set the thermostat, by the way. Wink
bladerunner
PostPosted: 14:10 - 10 Jan 2016    Post subject: Reply with quote
I fitted a salus IT500 just after Christmas to a friends boiler and it works great! Bought it from maplins for a good price and after scratching my head to figure out the quite simple wiring it was up and running in an hour. The app is pretty nice and easy to use. Shows you the current temp and if the boiler/hot water is on a burn cycle or not bla bla bla just like it should. I was glad to see the room control/remote works with the boiler direct WiFi so when you lose internet etc it still works and you can still adjust the usual thermostat temps and programs etc.........I'm actually rather tempted to get one myself!
panrider_uk
PostPosted: 21:55 - 11 Jan 2016    Post subject: Reply with quote
£123 on Amazon
bladerunner
PostPosted: 00:41 - 14 Jan 2016    Post subject: Reply with quote
Think I paid £89 at maplins with the option to return if we didn't like it!!! Bargain
panrider_uk
PostPosted: 11:28 - 14 Jan 2016    Post subject: Reply with quote
Definitely a bargain. They're charging £140 now.
Jayy
Mr. Ponzi
PostPosted: 12:42 - 14 Jan 2016    Post subject: Reply with quote
I don't trust all this stuff. I can never see myself going all hi tech for the house, I don't trust it.
Oh, you can open your door over the internet? Turn the heating on? Set the coffee machine on? ... so can someone else if you can.
James83
PostPosted: 19:09 - 14 Jan 2016    Post subject: Reply with quote
Not if you secure it properly they can't. In the same way that if you lock your door, people can't just walk in and turn on your coffee machine manually.
Jonathan A wrote: tart.
bladerunner
PostPosted: 00:54 - 16 Jan 2016    Post subject: Reply with quote
I bet jayy also snorted at remote central locking for cars...I mean what's the point? Its not like I need the door unlocking Untill I'm stood close enough to use the key! Need to unlock other doors? Then reach across and unlock the passenger door its not hard eh! Laughing Laughing its not a must have thing but if your used to just having a time programmer like I am then its nice to have a remote thermostat that's able to regulate the room temp....whichever room your in and not just turn the boiler on at x time till y time if its needed or not. The fact its for the same price as a basic programmer is a bonus but not a must have but deffo a money saver
PostPosted: 01:25 - 16 Jan 2016    Post subject: Reply with quote
Once the novelty value of turning your heating on before leaving work to go home has worn off, you're then left with a complicated heating system with weaknesses such as it getting a software bug and you being left with no heating.
Remote central locking has vulnerabilities but you still need the key to get past the immobiliser and start the thing. Keyless cars aren't the most theft proof vehicles right now.
What do you do when your smart house gets a virus, locks you out (or possibly in), gets your fridge to order millions of things you don't want, tells the coffee machine to keep brewing and spewwing out coffee until the house is ankle deep in caffeine, disables the flush on all your toilets, etc etc etc?
Sounds like a lot more fun than just being able to fuck around with someone else's webcam or printer. Laughing
Jayy
Mr. Ponzi
PostPosted: 03:23 - 16 Jan 2016    Post subject: Reply with quote
You're kidding me, right? If someone wants to come and turn my coffee machine on, they need to break the door / window to gain access. Any piece of kit that's connected to the internet is vulnerable and exploits will be found and will be used. Even more worrying, used remotely by people nowhere near your house.
You'd have lost that bet then, as I post more in this section than anywhere else, it's safe to assume I'm in to tech, specifically web development.
Cars can be hacked now, as they become "smarter". The internet of things is gaining serious momentum and the plethora of devices now connected, it's a security nightmare. As we've seen from some of the most high profile companies who've been hacked recently, some of them can't even store a password in an encrypted format, you really thing your new fridge that orders stock directly when it's low is going to have bank level encryption?
Nevermind finding generic exploits, we've seen stupendously complex malware written specifically to target machines that control industrial level infrastructure and turn it in to melt down mode. How hard is it going to be for people to exploit a fridge, coffee machine, thermostat, etc?
I know my fridge and coffee machine are safe from being hacked, why? Because they aren't connected to the fucking internet. Not only have I got to worry about open source software vunerabilities and zero day exploits on a daily basis, now I have to worry about whether some Asian kid has set my fridge to 48 degrees and cooked all the food in it, whilst making my internet connected oven burn the house down Laughing
Let's not forget about the heartbleed bug which we thought SSL/TLS encryption (which protects the internet basically) was keeping us safe, when infact was being exploited and there was no way of knowing if it had. When fundamental things can be exploited / cracked / reverse engineered, you have to question the need of some of these internet connected devices.
You just need to read them links that Ste posted, which is what I was originally getting at.
James83
PostPosted: 03:44 - 16 Jan 2016    Post subject: Reply with quote
The chances of an exploit being discovered are tiny. Despite what you have read, exploits for well developed systems crop up very infrequently. And when one is discovered, so what? The chances that someone will use it to fuck with you are slim to none. Even if they did decide to start on you, all they can do is turn some appliances on, at which point you'll realise somethings up and disable the automation until the vendor fixes it.
You are, literally, more likely to have your heating turned on by a burglar who is chilly than you are to have it turned on by a 'hacker'.
If you dislike the tech, don't trust it, then thats fair enough. But you state "... so can someone else if you can." like anyone could do it if they wanted to, so no, I'm not kidding you.
ScaredyCat
PostPosted: 10:54 - 16 Jan 2016    Post subject: Reply with quote
Except if it's a heatmeiser. There are hundreds of them still accessible via the internet all of which can be accessed by even the most useless people.
bEN_
PostPosted: 11:24 - 16 Jan 2016    Post subject: Reply with quote
I just don't see the point in these. Just another thing to go wrong and waste your time with. Or you'll end up in a constant battle with the mrs because you both keep fucking about with it.
If i get home and i'm abit chilly i put my comfy clothes on, bang the thermostat up by pressing the button a few times ( bang it up to 23, it gets hotter quicker Laughing ) and in 10 minutes i'm all good.
The only thing i've done recently to 'update' my house is replace some plug sockets with ones that have usb ports in them.
2010 Ducati 848 Dark
Lamp Post Enthusiast
Going
PostPosted: 13:08 - 16 Jan 2016    Post subject: Reply with quote
Talking about that, I've just finished a book about it Smile
The biggest problem with the "Internet of things" they won't get patched or updated.
The last post was made 10 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 135.21 Kb
