New(ish) January license law query
rhys1005
PostPosted: 12:13 - 04 Dec 2013    Post subject: New(ish) January license law query Reply with quote
Hi BCF just a quick question, my bike don't fit the bhp restriction as it's 100bhp and at 19 I need the factory bhp to be no more then 94bhp (I think).
Will an old fzx750 fit this requirement? My dad owns one and reading a few sites the claimed bhp is 94.
I think it will be ok but just want to check before restricting it (apparently they want to see a valid restriction certificate upon testing?)
Thanks.
Doovy
PostPosted: 12:27 - 04 Dec 2013    Post subject: Reply with quote
I'm unsure about that bike, but this might help in case, otherwise.
map
Mr Calendar
PostPosted: 12:31 - 04 Dec 2013    Post subject: Re: New(ish) January license law query Reply with quote
rhys1005 wrote:
...Will an old fzx750 fit this requirement? My dad owns one and reading a few sites the claimed bhp is 94....(apparently they want to see a valid restriction certificate upon testing?)...
A bit of googling found this on the FZX750, from fzx750.co.uk would you believe...
https://www.fzx750.co.uk/Specs.jpg
So that says max power 92.7hp. Not sure if they mean actual bhp though as hp may be the theoretical max. Even so on an old machine a few horses will have been lost.
PostPosted: 13:50 - 04 Dec 2013    Post subject: Reply with quote
motorcyclespecs.co.za put a 1987 model at 94 hp 68.5 kW @ 9500 rpm (rear tyre 81.4 hp @ 9000 rpm )
Seem legit.
Az
PostPosted: 14:58 - 04 Dec 2013    Post subject: Reply with quote
Providing the info' on Rogerborg's link is correct, then yes you can ride it restricted on an A2 license
PostPosted: 15:18 - 04 Dec 2013    Post subject: Reply with quote
If the person above is correct, then yes. If the person above is incorrect then no.
https://s2.quickmeme.com/img/0d/0d230efa3ba7f125da273c65180f14ff12190a1561921e35d57f996032c5f770.jpg
Az
PostPosted: 15:27 - 04 Dec 2013    Post subject: Reply with quote
I don't want to say yes it can defo' be ridden on an A2 license incase the information on that website is incorrect, as i based my reply on the info' on that site.
map
Mr Calendar
PostPosted: 15:47 - 04 Dec 2013    Post subject: Reply with quote
Brick Wall
For A2 licence...
Government wrote:
...A2 motorcycle licence: At age 19 or over, you take a test on a motorcycle without sidecar of at least 395 cc with a power output of at least 25 kW but not exceeding 35 kW. If you pass, you may ride any motorcycle not exceeding 35 kW and with a power to weight ratio not exceeding 0.2 kW/kg....
Also
Government wrote:
A2...Medium motorbikes up to 35 kW (and a power-to-weight ratio not more than 0.2 kW per kg), bike mustn’t be derived from vehicle more than twice its power...
25kW is approx. 33.5hp
35kW is approx. 46.9hp (also seen 35kW=49.6bhp).
So restricted FZX750 wouldn't be more than twice 46.9hp so okay. Confused
FXZ750 weight is quoted as 205kg dry. So add another 10kg for fluids? So 215kg at say 94bhp, so that's approx 70.1kW, giving 0.33kW per kg, so at say 46bhp that'd be ballpark 0.2 per kg (calc is approx as not got right weight/info).
HTH Thumbs Up
links to pages click in quote on Government text before wrote text.
Calculation of hp based on 1 hp = 745.699872 W = 0.745699872 kW (see here).
KymcoRatChop
PostPosted: 15:53 - 04 Dec 2013    Post subject: Reply with quote
https://www.motorcyclespecs.co.za/model/yamaha/yamaha_fzx750%2087.htm
KymcoRatChop
PostPosted: 15:54 - 04 Dec 2013    Post subject: Reply with quote
edit: double post
KymcoRatChop
PostPosted: 15:55 - 04 Dec 2013    Post subject: Reply with quote
Hey Map
"Wet" weight is 221 kg if that helps Smile
Doovy
PostPosted: 15:58 - 04 Dec 2013    Post subject: Reply with quote
Jesus, the new laws are awkward Doh!
map
Mr Calendar
PostPosted: 16:46 - 04 Dec 2013    Post subject: Reply with quote
KymcoRatChop wrote:
Hey Map
I was allowing 13 litre tank which is ballpark 9.5kg of fuel. Appears the other fluids add up to around just over 6kg then.
So 221kg at say 94bhp, so that's approx 70.1kW, giving 0.32kW per kg, so at say 46bhp that'd still be ballpark 0.2 per kg (calc is still approx).
rhys1005
PostPosted: 17:15 - 04 Dec 2013    Post subject: Reply with quote
So from replies it seems like it is a valid bike for the new tests? Very Happy
there was me thinking about buying a pos gs500 and having the hassle of selling it a week or two later.. the fact the old as shit 750 in my garage could be within the limit didn't cross my mind until today Embarassed
now to convince my dad to lend it me.. Oh and get it restricted to then un restrict it again a few days later for his use Rolling Eyes stupid laws
Cheers guys Thumbs Up
PostPosted: 17:19 - 04 Dec 2013    Post subject: Reply with quote
Well.. I think they can (whether they would or not..) refuse to do the test if they believe its over the power limit.
I'd have a tried tested cheapy bike personally.
Doovy
PostPosted: 17:21 - 04 Dec 2013    Post subject: Reply with quote
More to the point, can you actually get that bike restricted to the correct amount? Thinking
PostPosted: 21:49 - 04 Dec 2013    Post subject: Reply with quote
I'm pretty sure that you can print off a bit of paper that says that you have.
To paraphrase slightly:
GUBMINT: Are you trying to show contempt for this law?
MAE WEST: I was doin' my best to hide it.
The last post was made 12 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 101.57 Kb
