2012 ER6f exhaust help needed
fatjames
PostPosted: 16:37 - 04 Dec 2013    Post subject: 2012 ER6f exhaust help needed Reply with quote
Hi, I've found myself with a problem and I can't work out what I've done wrong and I struggling to even describe the issue. I'll try.
I fitted an aftermarket can and downpipes from a 2008, this was fine, although it didn't sound very good. It wasn't just too loud, but the backfires didn't sound healthy at all. I took them off and installed a yoshi full system, this was fine for a week or so. Now it sounds really bad, it sounds like the bike is shitting rust through the exhaust. I thought it might be due to the PAIR valve, so I plugged this too and there is still no change. The backfires sound very loud, a bit tinny and almost a bit hollow. I worried at first that it didn't have enough oil, but the oil is fine.
It will start and idle, but it's like there is no exhaust on at all. The pipe and connectors all look fine, the exhause gas is coming out the end where it should. To top this off, it's overheating really quickly, for example after 5 mins in traffic, the warning light is coming on. If I turn the bike off, it sounds like a boiling kettle, and it's never dome that before. I can only assume that I've moved something, or broke something. My plan is to take it off and check it over, any other ideas??
Many thanks
Fatjames
fatjames
PostPosted: 17:28 - 04 Dec 2013    Post subject: Reply with quote
Kawi forums are telling me I need to get a power commander as the fueling is fucked. Does that sound right?
sickpup
Old Timer
PostPosted: 17:38 - 04 Dec 2013    Post subject: Reply with quote
The 08 downpipes I believe are different from the 12 model, thats the first thing to look at.
Did you use compressible metal exhaust gaskets as the ER6 requires these?
Do the replacement exhausts have the threaded boss for the FI sensor just before the end can?
Have you unplugged the fan and failed to plug it back in?
fatjames
PostPosted: 17:48 - 04 Dec 2013    Post subject: Reply with quote
Thanks, Sickpup.
Ok, the 08 downpipes are no longer being used, I only needed them for the cheapo can I found, the yoshi is a full system.
Didn't change the gaskets. They looked ok, and the yoshi instructions said only change them if needed. I do have some, so I'll try that.
The yoshi can didn't have a hole for the lamdba sensor, so i got one welded on and the sensor is plugged in.
THE FAN! This sounds possibly likely. Do you know where the plug is situated. I can't remember seeing it, but would not be suprised if I unplugged something without plugging it back in!
jeddy11
PostPosted: 18:51 - 04 Dec 2013    Post subject: Reply with quote
Sounds like a fuelling issue the FI should auto adjust for the new pipe what helped mine when i fitted an aftermarket exhaust as it was also running a bit rough was to block the pare valve and then pulling the fuse to the ecu and resetting so when it started up again im not if it reset the fuelling or what ever but it ran a whole lot smoother and used less fuel to boot i then wondered why i hadnt tried this earlier.. Thumbs Up
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
fatjames
PostPosted: 19:17 - 04 Dec 2013    Post subject: Reply with quote
I've plagued the PAIR valve already. Just had a look and the fan is not coming on, even with the engine hot light on, on the dash. I'm
Tempted to put the old pipe back on and see if the problem goes. Fuck knows what happened to the fan!
fatjames
PostPosted: 19:31 - 04 Dec 2013    Post subject: Reply with quote
More good news! The leisure battery I run my garage lights from is dying. I'll have drag it home and charge it before I do anything else. Evil or Very Mad
Aff
PostPosted: 19:40 - 04 Dec 2013    Post subject: Reply with quote
Check the fan first before you start assuming its all exhaust.
Have you made sure nothing is unplugged?
If so, is the fuse good?
If it is, run power to the fan directly from you battery, ground it wherever convenient. If it doesn't come on, your fan is dead. If it does then the control system is dead somewhere.
I believe the er6 only has the one CTS so if that goes it will also effect the fan, this would also have bad effects on the running and sound of the bike, as the ECU uses this to find out if the bike should be on its warm up cycle or not, this will be injecting much more fuel into the engine.
Electric Bike Project
fatjames
PostPosted: 20:02 - 04 Dec 2013    Post subject: Reply with quote
Thanks mate. I'll get the fan going first and take it from there. What's the CTS? I'm guessing something temperature sensor?
Aff
PostPosted: 20:08 - 04 Dec 2013    Post subject: Reply with quote
Yup, coolant.
Just do the things in the order I posted, If it comes to the sensor, it can be tested with a multimeter, specs will be in the manual.
:edit: Just in case:
Voltage should be: 2.80 ∼ 2.97 V @20°C
And resistance:
https://i.imgur.com/Ukqe5vI.png
fatjames
PostPosted: 21:05 - 04 Dec 2013    Post subject: Reply with quote
I just went back to the garage to get the battery and had a look. I need more light to be sure, but it looks like the wire for the fan goes under the tank. More light tomorrow and I can look properly.
fatjames
PostPosted: 14:23 - 05 Dec 2013    Post subject: Reply with quote
I think I fucked my battery. It was on charge all night and nothing! These repairs might have to wait until the weekend Sad
fatjames
PostPosted: 14:04 - 07 Dec 2013    Post subject: Reply with quote
The good: I charged up my garage battery and have light.
The bad: the fan is what's broken. I've ran 12v through it and nothing. Looking online, a new one is £240!!! I've already drained the coolant, so may as well take the fan off and see if it's serviceable. Any ideas, please let me know.
FJ
Aff
PostPosted: 15:17 - 07 Dec 2013    Post subject: Reply with quote
That Fan is used on all 2006 - 2012 er6f's and n's. Its also used on all 2006-2012 Versys.
You should be able to get it at a reasonable price off a bike being broken.
Alternatively, buy a dirt cheap fan of similar size off another bike and bodge it on, wont be hard.
Also I'm sure i've seen a pattern part for it somewhere.
:edit: just as a note, when i say used on all of them, the 2006-2009 used the exact same shape fan but with 4 mounting points, the later ones used the same fan, but with one of the mounting legs cut off, so the old fan fits but you have to either remove or not fit one of the mounting legs.
Like so:
https://i.imgur.com/7YTd2AV.png
fatjames
PostPosted: 15:37 - 07 Dec 2013    Post subject: Reply with quote
Found one on eBay for £27 and ordered it. Do you think it's a coincidence that this has happened? The fan is behind the rad, so I didn't go near it when I installed the exhaust. It was really dirty, might need a fender extender too.
Aff
PostPosted: 15:39 - 07 Dec 2013    Post subject: Reply with quote
They really don't take much to burn the motor out, Its definitely worth taking it apart to look for any obvious problems.
fatjames
PostPosted: 16:45 - 07 Dec 2013    Post subject: Reply with quote
I'll dissect it and perform a post mortem!
Apart from cleaning, is there anything else I should do while the plastics and rad is off?
Aff
PostPosted: 16:54 - 07 Dec 2013    Post subject: Reply with quote
Not really, check the rad for small leaks and bent fins, maybe get a rad comb and straighten them out.
fatjames
PostPosted: 11:58 - 14 Dec 2013    Post subject: Reply with quote
I tested the new fan before putting it. Refilled the coolant and let it hear up. The temp warning light has come on and the fan hasn't. Wtf?? Maybe the fuse. I'll check that.
fatjames
PostPosted: 12:51 - 14 Dec 2013    Post subject: Reply with quote
The fuse had blown. Phew. For anyone with a 2012/2013, the fuse box is under the plastic at the front of the tank. To the left of the ignition key hole!
Matt B
PostPosted: 13:53 - 14 Dec 2013    Post subject: Reply with quote
fatjames wrote:
The fuse had blown...
Don't you just wish you had checked that first!
fatjames
PostPosted: 13:55 - 14 Dec 2013    Post subject: Reply with quote
The fan was still fucked, so not much in it. Finding the fuse box was a bastard though!
Aff
PostPosted: 13:56 - 14 Dec 2013    Post subject: Reply with quote
The fan was still dead, just took the fuse with it when it went.
Clutchy
PostPosted: 14:22 - 14 Dec 2013    Post subject: Reply with quote
If the exhaust is still sounding bad, my friend had this exact problem on his er-6f, the exhaust wasn't sealing properly and had to use gun gum as a bodge! I know you said you checked it all, but have another look where the base of the end can is connected. Thumbs Up
fatjames
PostPosted: 14:44 - 14 Dec 2013    Post subject: Reply with quote
I think you're right mate. It's got that hollow plinking sort of sound, there is either air getting in, or it's too lean. Even with the PAIR valve plugged there is a lot of back firing, not that I mind unless its causing damage. I'll take it for a test ride and see how it behaves. Ideally, I want to avoid having to get a pc and dyno because I'm too poor!
The last post was made 12 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 130.36 Kb
