Chain rubbing, Is this normal?
evilzed
PostPosted: 18:50 - 15 Dec 2013    Post subject: Chain rubbing, Is this normal? Reply with quote
Hey,
I was adjusting the chain tension on my ybr 125 2008 model, I never tried spinning the rear wheel freely before I adjusted the tension so am not aware if it's something I did to screw the bike up or if it's meant to rub.
basically the underside of the chain rubs part of the frame you can see from the images attached the part it rubs already seems to have indents where the chain lines up but this could of been caused by chain rubbing itself. I couldn't see any real way to getting it higher even with crazy chain tension.
https://i.imgur.com/Ve83vDk.jpg
iMark
PostPosted: 18:51 - 15 Dec 2013    Post subject: Reply with quote
Would it be rubbing on the swingarm where there is a plastic type thing stuck on it that is designed for the chain to rub onto that instead of the swingarm in order to protect the swingarm?
Ah such ninja edit Razz
Yes as above... that's designed to protect your swingarm from your chain, nothing to worry about
K8 GSXR 1000
evilzed
PostPosted: 18:55 - 15 Dec 2013    Post subject: Reply with quote
Ah thanks! Yeah getting the image links to work properly is trickier than I thought lol
misscrabstick
PostPosted: 18:58 - 15 Dec 2013    Post subject: Reply with quote
Sposed to do that, protects your swinging arm, your chain looks a bit errmm neglected though, dirty and a bit rusty?
evilzed
PostPosted: 19:06 - 15 Dec 2013    Post subject: Reply with quote
Bought the bike used from a dealer, it had some very heavy dark wax applied to it so had no clue on the condition........until now
YBR Ric
PostPosted: 20:39 - 15 Dec 2013    Post subject: Reply with quote
Ah yes, ye olde dark wax trick. You'll want to know how to remove all ye olde sawdust from the engine oil next Shocked
I'd run that one through the winter and fit a decent one in the spring once the salt's gone. Always a bonus when the spring clips been fitted correctly though Smile
Ariel Badger
PostPosted: 22:54 - 15 Dec 2013    Post subject: Reply with quote
Use chain lube not human excrement on your chain.
DrDonnyBrago
PostPosted: 10:33 - 16 Dec 2013    Post subject: Reply with quote
You know you can wash a chain right?
Paraffin (4 L for £6 in B+Q, sold as lamp fuel), a bowl and a paintbrush...
Just saying.
P.
PostPosted: 14:03 - 16 Dec 2013    Post subject: Reply with quote
You missing the chain guard also?
Northern Monkey
PostPosted: 15:15 - 16 Dec 2013    Post subject: Reply with quote
When you sit on the bike, the swing arm will come up, stopping the chain rubbing there.
The chain should only rub when the rear suspension is unloaded.
YBR Ric
PostPosted: 10:53 - 17 Dec 2013    Post subject: Reply with quote
...or when all the slack transfers from the lower to the upper chain run.
The last post was made 12 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 1.89 - MySQL Queries: 13 - Page Size: 78.21 Kb
