| evilzed |
 evilzed Scooby Slapper
 Posted: 18:50 - 15 Dec 2013 Post subject: Chain rubbing, Is this normal? |
Hey,
I was adjusting the chain tension on my ybr 125 2008 model, I never tried spinning the rear wheel freely before I adjusted the tension so am not aware if it's something I did to screw the bike up or if it's meant to rub.
basically the underside of the chain rubs part of the frame you can see from the images attached the part it rubs already seems to have indents where the chain lines up but this could of been caused by chain rubbing itself. I couldn't see any real way to getting it higher even with crazy chain tension.
https://i.imgur.com/Ve83vDk.jpg
| iMark |
 iMark World Chat Champion
 Posted: 18:51 - 15 Dec 2013 Post subject: |
Would it be rubbing on the swingarm where there is a plastic type thing stuck on it that is designed for the chain to rub onto that instead of the swingarm in order to protect the swingarm?
Ah such ninja edit
Yes as above... that's designed to protect your swingarm from your chain, nothing to worry about ____________________ K8 GSXR 1000
"G" : you got him to have a look at a forum which seems to have established a picture of an erect penis in a cat's mouth as it's mascot and thought he might consider it ok? |
| evilzed |
| misscrabstick |
 misscrabstick Crazy Courier
| evilzed |
| YBR Ric |
 YBR Ric Spanner Monkey
 Posted: 20:39 - 15 Dec 2013 Post subject: |
Ah yes, ye olde dark wax trick. You'll want to know how to remove all ye olde sawdust from the engine oil next
I'd run that one through the winter and fit a decent one in the spring once the salt's gone. Always a bonus when the spring clips been fitted correctly though  |
| Ariel Badger |
 Ariel Badger Super Spammer
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| _Iain_ |
 _Iain_ Banned
| P. |
 P. Red Rocket
| Northern Monkey |
 Northern Monkey World Chat Champion
| YBR Ric |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 10:59 - 17 Dec 2013 Post subject: |
you gona die
https://i.imgur.com/eRhV8so.png ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
The last post was made 12 years, 58 days ago. Instead of replying here, would creating a new thread be more useful? |
