CG question
PostPosted: 21:17 - 23 Dec 2004    Post subject: CG question Reply with quote
Right you intelligent lot.
I got my CG brazilian back from the mechanic and its all super, but he recommended that I find a new carb as the one on it is in a bit of a state.
Could anyone inform me what carb is on this bike? (1990 model)
I've google'd it but to no result. If I can find out what make/size it is, then I'll be able to find one no problem.
Thanks in advance to any help. Thumbs Up
Merry christmas! Mr. Green
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
ts50x0
PostPosted: 23:11 - 23 Dec 2004    Post subject: Reply with quote
you need to go to your local breakers and ask them if they have one for it it. theyll know what carb it is,
i wouldnt buy new as they are really expensive, were talkin half as much as the bike is worth mate.
PostPosted: 23:20 - 23 Dec 2004    Post subject: Reply with quote
Yeah. I will. But I need to find out what carb it is and whether its different to any of the more modern versions. I've been looking around breakers web sites and most of them only have carbs for the CG CDI model. Confused
I think I best consult David Silver spares, or my friends Haynes manual.
K!K @
PostPosted: 00:29 - 24 Dec 2004    Post subject: Reply with quote
Contact Honda and they will tell you where to find one or how much it will be from them.
Suzuki AY50 Katana
~Elite~Knights~
RS1Banger
PostPosted: 19:33 - 26 Dec 2004    Post subject: Reply with quote
may as well fit a bigger carb
if its possible
mattsmith95
PostPosted: 20:02 - 26 Dec 2004    Post subject: Re: CG question Reply with quote
Could you explain WHY you need a new carb, I wouldn't change it just on the say so of a mechanic.
PostPosted: 23:33 - 26 Dec 2004    Post subject: Reply with quote
Because its a big blob of corrosion. Laughing
Dont worry, he's a reliable mechanic. Wink
Besides, carbs arent expensive and come by quite often on ebay and breakers. I just need to know whether one from a newer model will bolt into my old Brazilian.
Thinking
bikedudextrm
PostPosted: 23:51 - 26 Dec 2004    Post subject: Reply with quote
Why not just have a good look at the carb, it must have the name of the manufacturer on it somewhere and a part code.
Police Tut Tut
https://www.bikepics.com/members/bikedudextrm/
mchaggis
PostPosted: 04:00 - 27 Dec 2004    Post subject: Reply with quote
I can go and look at my Mums '93 Brazilian model in the garage outside tomorrow (later today, why am I up at this time? Confused ) Failing that, we've a Haynes manual for it somewhere in which I can have a gander.
No guarantees that the '93 is the same as the '90, but I don't see too many reasons why not at the minute.
I must not be a troll...
Mmmm, Guinness
PostPosted: 12:01 - 27 Dec 2004    Post subject: Reply with quote
if its possible
Trouble with doing that is that you will then have to try and jet it up to work, which is difficult to do properly. Likely that he would just land up with a big flat spot in the power delivery somewhere, at best.
PostPosted: 16:15 - 27 Dec 2004    Post subject: Reply with quote
Would be grateful if you could check the Haynes manual for the make, type and size of the carb.
Would be much appreciated. Thumbs Up
I'll probably take the Carb off at some point to strip down and give a good clean. I think a friend of mine has the Haynes manual so all the stock settings should be in there. Will ask him next time he's online.
Claud 14.7 to 1
PostPosted: 16:43 - 27 Dec 2004    Post subject: Reply with quote
Get carb/take apart, put in Coke (as in a-cola coke) Laughing , wait a few hours. Good for cleaning.
More cleaning and put it together. Done.
mchaggis
PostPosted: 19:48 - 28 Dec 2004    Post subject: Reply with quote
From the Haynes manual:
Carburettor
Machine: CG125 (BR)-E/F, J
ID number: PD47C-A or D-A
Main jet: 90 (95*)
Pilot (slow) jet: 38
Needle jet: E2052J (E2352H*)
Needle jet clip position - grooves from top: 4th (2nd)
Pilot screw - turns out from fully closed: 1 3/8
Float height: 14.0 mm (0.55 in)
Idle speed: 1400 +- 100 rpm
Machine: CG125 (BR)-K
ID number: PD47F
Main jet: 95
Pilot (slow) jet: 35
Needle jet: not available
Needle jet clip position - grooves from top: not available
Pilot screw - turns out from fully closed: 1 1/2
Those are directly lifted from the Haynes manual. The asterisk refers to the section of the manual dealing with the carburettor overhaul, so it'd be easier just to see the manual for those.
If you go to a decent spares place and tell them exactly what you want (a carburettor for a '90 CG125 (BR) -?) then they should be able to work out exactly what you need. I was mistaken saying that it was a '93 model apparently, H is '91.
Mmmm, Guinness
PostPosted: 22:34 - 28 Dec 2004    Post subject: Reply with quote
Thanks for the above. Thumbs Up
Mines also a H reg, but on the frame, I believe it says "BR-J."
I may take the carb out through the week, give it a thorough cleaning then try get it back to its standard settings.
Thanks for the information though, much appreciated. Very Happy
The last post was made 21 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 83.77 Kb
