Beko washing machine fault not a review
pdg
PostPosted: 13:43 - 16 Dec 2013    Post subject: Beko washing machine fault not a review Reply with quote
We've had this Beko washing machine for just a shade over a year.
Literally days before the warranty expired it developed what I consider a fault... Others may consider it a cheap way of fitting neon underlights.
Sometimes, there will be an arcing noise when it goes onto spin accompanied by flashing/sparks from underneath. Doesn't happen every time and not always on the same cycle so it's completely un-reproducible.
We had the service agent come out and replace under warranty the motor and DC control board (but not the main control board) and the problem persists, still intermittently. Since the 'repair' we've caught it on video a couple of times:
https://www.youtube.com/watch?v=9PVExH01AHo
https://www.youtube.com/watch?v=hcA5hSCDKHU
When it's not doing this, everything is fine. When it does do it, it reeks... That nice burnt carbon/solder/metal smell. Every time the service agent has come out (3 times so far) it's performed perfectly.
I still have the old motor - no signs of the brushes disintegrating, bearings feel smooth with no play etc. and I would say it's fine. The old DC board seems fine too - the rectifier tests fine and other components test within spec.
We've spoken to the service centre again and they seem a bit 'meh' about it. Over a year old now so they probably can't be bothered. We offered to email videos which they said they'd view, and when we sent them they said they can't view them - youtube ahoy then.
So, (apart from the slack chain and twisted subframe - I've checked the powerband too, it's the right colour and not worn) any ideas?
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
CaNsA
PostPosted: 13:52 - 16 Dec 2013    Post subject: Reply with quote
Overloading the drum causing the motor to spack out maybe?
pdg
PostPosted: 13:56 - 16 Dec 2013    Post subject: Reply with quote
It's got a 7kg capacity, the sparking has happened when it's been full, also when it's been under half load.
One of the service agent's tests was to put 6 bath towels in it (which is more load than we would put in) - didn't spark......
mentalboy
PostPosted: 14:14 - 16 Dec 2013    Post subject: Reply with quote
Ain't electrickery purty!
Can you remove the top on this model? If so I'd do that to see if I could locate just where the sideshow's coming from. It's most likely fried a plastic guarded connector (or brushes have reached the end of their life - how much use since the motor was replaced?)
Make mine a Corona.
pdg
PostPosted: 14:23 - 16 Dec 2013    Post subject: Reply with quote
The only thing at all in the area of sparkage is the motor - all the insulative connectors are fine.
It's had about 3 weeks' average use since the motor was replaced.
mentalboy
PostPosted: 14:32 - 16 Dec 2013    Post subject: Reply with quote
So, assuming BEKO haven't told you that a) all their motors do it, or b) that it needs time to run in, then it would make sense that they've supplied you with a motor that's either defective or has dodgy brushes.
It's not uncommon for sparking to occur with brushes but acrid type burning smells are not normal (although a brand new motor can smell a bit odd the first couple of times it's used)
Pestering them until a resolution is achieved would be your best bet
Make mine a Corona.
oldpink
PostPosted: 14:51 - 16 Dec 2013    Post subject: Reply with quote
possibly a wire thats got loose and had its insulation damaged vibrations moving it so sometimes its arcing sometimes its not
I'd pull it out and have a good look around where the arcing is coming from and look for burn marks
angryjonny
PostPosted: 14:52 - 16 Dec 2013    Post subject: Reply with quote
CaNsA
PostPosted: 14:53 - 16 Dec 2013    Post subject: Reply with quote
Needs moar carbon, a spoiler, bodykit and some stance.
mentalboy
PostPosted: 15:15 - 16 Dec 2013    Post subject: Reply with quote
angryjonny wrote:
I read that too Rolling Eyes
The old motor may well have good brushes but it's unlikely to spark sitting in a box in the corner. The new motor will have it's own brushes.
It is not unheard of for new motors to be defective.
Make mine a Corona.
angryjonny
PostPosted: 15:36 - 16 Dec 2013    Post subject: Reply with quote
True. But ordinarily, if a fault develops and I replace a part and the fault persists with the same symptoms, I start looking at other parts.
Yes, it's possible both motors are/were defective in the same way, but it's more likely that it's something else.
mentalboy
PostPosted: 16:03 - 16 Dec 2013    Post subject: Reply with quote
Yup, hence:
Op says not, at which point I'd be doing as Oldpink suggested and looking further up the loom, failing that:
=contact manufacturer.
I have quite happily tinkered inside washing machines before but if OP has no joy and is not too sure AND machine is giving off nasty burning smells then it'd be better to play safe than sorry
Make mine a Corona.
Minty
PostPosted: 16:20 - 16 Dec 2013    Post subject: Reply with quote
Just google "Beko appliance fire". Plenty of reading to be had. I suggest you go to their web site and see if your appliance is affected by the many product recalls. Thumbs Up
In short, there is a very good reason as to why Beko appliances are so cheap.
My fingers smell of your mum.
pdg
PostPosted: 16:45 - 16 Dec 2013    Post subject: Reply with quote
I was really just fishing for more ideas because, as in the op, I am in contact with the manufacturer - it's just that they don't seem particularly bothered. While the machine is now technically out of normal warranty, the 'repair' apparently has it's own 3 month 'guarantee' - it just feels like I'm going to get strung along until that expires at which point they'll say something along the lines of " Laughing Razz Middle Finger " especially as they have already used the line "when our engineer visited the machine was working within spec". the term intermittent appears not be in their crib-sheets.
If it doesn't get fixed properly, then I'll break out my big box of modifying hammers. Say I'd bought it second-hand I wouldn't hesitate but as part of the purchase price is the assurance that it'll be reliable or repaired I don't see that I've reached that point just yet. (No, I didn't get an extended warranty.)
Well, I for one don't really consider £300~ 'cheap' for a washing machine... Especially considering what's actually inside one.
pdg
PostPosted: 16:59 - 16 Dec 2013    Post subject: Reply with quote
Minty wrote:
Just google "Beko appliance fire". Plenty of reading to be had. I suggest you go to their web site and see if your appliance is affected by the many product recalls. p.
From the Beko site safety and recalls section:
If you have a Beko Dishwasher, Washing Machine or Built In appliance you are not affected.
The whole 'Daily mail says Beko catch fire' thing was about a certain model of fridge freezer. There is also a recall affecting tumble dryers (our washing machine has no dryer function anyway) and a gas cooker that people are converting to LPG and using as a space heater...
Now go and google "appliance fire" preceeded by 'hotpoint', 'AEG', 'Electrolux', 'Neff', 'Bosch', 'Siemens', etc, etc.... See if you can find ONE that hasn't recalled an appliance (dishwashers seem particularly popular for catching fire).
mentalboy
PostPosted: 17:34 - 16 Dec 2013    Post subject: Reply with quote
300 quid may not seem cheap but all things are relative. That said I'd expect any machine I bought to last longer than it's year's warranty, when used correctly.
Get your pen and paper out and send your grievances to Beko the old fashioned way, duplicate this by email and any other form of communication you can think of, but make sure they get a hard copy - before the warranty on the existing motor expires.
Be sure to let them know that the warranty work they carried out initially (whilst within the year's warranty) did not rectify the problem - assuming that the intermittent sparking problem was the reason for their first callout and not something unrelated.
Also make them well aware that at the times you can hear/see sparking that it is accompanied by a smell that would indicate burning.
And keep pestering them. It's not your job to ensure their machines are up to scratch but the more of a pest you become, the greater your chances of a satisfactory result. Just do it nicely!!!
Make mine a Corona.
JP7
PostPosted: 18:25 - 16 Dec 2013    Post subject: Reply with quote
If they try telling you the warranty has expired and they're now not interested, I would suggest that since you reported the fault within the warranty period, and the same fault still exists despite the warranty repair they attempted, they should still honour it.
I don't have a remotely technical mind so I couldn't advise on that side, but I would be inclined to send them the videos you have to prove that the fault exists, and ask them exactly what they intend to do about it.
pdg
PostPosted: 18:37 - 16 Dec 2013    Post subject: Reply with quote
We have sent the videos to them, after discussing it with them. As to their reply, well it seems they can't view MP4, WMV, AVI............... That's why youtube, it's pretty much platform independent.
PostPosted: 18:44 - 16 Dec 2013    Post subject: Reply with quote
Could it be static?
Is your socket properly earthed?
pdg
PostPosted: 20:04 - 16 Dec 2013    Post subject: Reply with quote
It should be, there is earth continuity in the entire ring (all of them) and it's all bonded so that shouldn't be an issue.
dodgydog
PostPosted: 20:27 - 16 Dec 2013    Post subject: Reply with quote
Have you had a look at the sides of the machine? It's pretty common for them to be "clamped" in the warehouse (when gripped the wrong way by the clamp truck). That causes all sorts of problems. Sometimes it's hard to see, but they only need to be pushed in a little way. We picked one up that had burst into flames, it had been in use a good few months, but once it had worn in a bit something inside started rubbing on a wire.
Also there's a polystyrene block up inside the machine, that's supposed to be removed when delivered, (but it's a bastard to get out, so some delivery guys don't bother) amazing how often we used to go pick them up for exchange when it was just that block left inside, causing vibration and rough running, (and in one case, a houseful of smoke).
Looking at the video though, my money would be on the motor, replaced or not.
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
pdg
PostPosted: 21:12 - 16 Dec 2013    Post subject: Reply with quote
There's no deformation to the case, all nice straight and square. With 2 kids under 5 in the house (and the washing they generate) I would have expected anything 'silly' to happen well before 11 3/4 months had passed.
The poly block was removed on installation, I know this because I don't let people install things for me as a general rule (and if I really have to let them, i.e. gas, I watch them do it under the pretence of offering a cup of tea).
The back was obviously taken off when the motor was replaced - I had a good look around inside and there are no signs of smoke/soot/arcing to case or anything like that.
It's quite apparent that it's the motor doing the light show, of that I have very little doubt - it's what is causing the motor to do this that is the problem..... For a motor to go faulty is quite understandable but for a new one to be delivered with exactly the same fault is unlikely. When I've seen motors do similar in the past there has been a good reason for it - faulty capacitor, disintegrating brushes, shot bearings - but on both the old and new motors there appears to be nothing wrong.
There has so far been nothing suggested that I hadn't thought of, which is good - at least it doesn't seem like I'm missing something really stupid. Back to hassling Beko to see what I can get them to do...
mentalboy
PostPosted: 21:51 - 16 Dec 2013    Post subject: Reply with quote
A failing capacitor can give these symptoms, I would have thought that it was all part of the motor assembly but new motor with similar problem would suggest that there is one further up the line. Should be cheap and cheerful - finding it is another matter and I have no idea where it'll be in this machine.
Make mine a Corona.
PostPosted: 22:23 - 16 Dec 2013    Post subject: Reply with quote
Maybe you should strip and clean the carbs?
Robby
Dirty Old Man
PostPosted: 12:34 - 17 Dec 2013    Post subject: Reply with quote
From the video is appears that the sparking is happening near the centre of the machine, at the bottom. The motor is usually right over in one of the back corners. The only electrical bit I would expect to see under the drum in the middle is the drain pump.
The only way to work out which bit is sparking is to take the back cover off and watch it running until it sparks.
The last post was made 12 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 137.13 Kb
