Image scaling for online gaming.
Dr. Quack This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
CaNsA
PostPosted: 21:47 - 16 Dec 2013    Post subject: Reply with quote
Disable UAC.
winkey+r
msconfig
tools
change uac settings
reboot
try accessing the file again.
CaNsA
PostPosted: 22:11 - 16 Dec 2013    Post subject: Reply with quote
Get the error message up.
press the "print screen" key
goto https://imgur.com
press CTRL + V
upload
copy bbcode link
paste then in this thread.
CaNsA
PostPosted: 22:19 - 16 Dec 2013    Post subject: Reply with quote
follow the steps above.
CaNsA
PostPosted: 22:27 - 16 Dec 2013    Post subject: Reply with quote
I googled
access to file denied windows 8
This was the first result.
https://support.microsoft.com/kb/2623670
CaNsA
PostPosted: 15:17 - 17 Dec 2013    Post subject: Reply with quote
Work left to right.
https://i.imgur.com/dC9irrs.png
PostPosted: 15:31 - 17 Dec 2013    Post subject: Reply with quote
Often to do things like this you have to run notepad as an administrator (right click on icon then run as an administrator) Then open the file using the open command from the toolbar in notepad.
James83
PostPosted: 18:01 - 17 Dec 2013    Post subject: Reply with quote
I apologise for asking a very obvious question, but I've learned that eliminating the obvious first is important, so here goes - Are you trying to save this file with COD running?
barrkel
PostPosted: 00:31 - 18 Dec 2013    Post subject: Reply with quote
Start up a command prompt in administrator mode.
Copy, paste and run these two commands in the console:
Code:
takeown /f "C:\Program files (x86)\Activision\Call of Duty 4 - Modern Warfare\players\profiles\Woznotme\config_mp.cfg"
Code:
icacls "C:\Program files (x86)\Activision\Call of Duty 4 - Modern Warfare\players\profiles\Woznotme\config_mp.cfg" /grant Users:F
The first command should take ownership; the second, grant full access to the Users group, which you're a member of.
I may have made a mistake in the spelling of the path. You might need to fix it.
ajag
PostPosted: 02:04 - 18 Dec 2013    Post subject: Reply with quote
Copy/move the file to a different directory, change it and then move it back to where it was
Street Triple
CaNsA
PostPosted: 12:34 - 18 Dec 2013    Post subject: Reply with quote
Righto....
Installed win8 on a VM, installed COD4.
The file you are after should be located in.....
Code:
C:\Users\CaNsA\AppData\Local\VirtualStore\Program Files (x86)\Activision\Call of Duty 4 - Modern Warfare\players\profiles\
The last post was made 12 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.58 - MySQL Queries: 13 - Page Size: 104.17 Kb
