| map |
 map Mr Calendar
 Posted: 23:42 - 16 Dec 2013 Post subject: Petrol in oil diagnoatic / advice needed |
Got a 'phone call from my lad. He's away at his girlfriend's house.
Seems he's got petrol in his oil. You now have as much info as I have.
Bike is 03 Varadero XL125V.
Obviously he'll have to get sorted.
However, wondered what may be the cause(s) and fix(es).
I'm not sure if this is a common fault. Although I'm surprised.
This is just so he might not get ripped off when trying to fix.
He has no tools* so hopefully will take it to someone who can help.
Thanks in anticipation
* viewers of previous posts will recall his favourite tool is a hammer and if that doesn't fix the issue it has to be an electrical fault  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| WD Forte |
 WD Forte World Chat Champion
| Kickstart |
 Kickstart The Oracle
| Fizzer Thou |
| _Iain_ |
 _Iain_ Banned
 Posted: 10:21 - 17 Dec 2013 Post subject: |
What Fizzer & Kickstart said.
Had it happen to my GS500, ended up draining a washing up bowl and a half of oil/petrol out of the crankcase. It also realy badly damaged the crank seal behind the ignition rotor so best to drop it all out ASAP and leave it dry whilst thinking of a solution. ____________________ Please be aware that the above post may be full of complete nonsense.
| STONEY! |
 STONEY! Brolly Dolly
| map |
 map Mr Calendar
 Posted: 11:46 - 17 Dec 2013 Post subject: |
Thanks for the advice.
I think he was scared it was a piston related and/or gasket/seal and it would need a costly strip down and rebuild.
I've recommended he do a complete oil/filter change and check his petrol tap (I refrain from slipping into American and saying petcock, although I do like the term ).
I'm not sure the Varadero is vacuum fed as tap has on/off/res settings. For vacuum I'd not expect on off but on/res/prime.
I'm reluctant to get him to fiddle with carbs as experience when he had a scooter was they can be fubared easily in the wrong hands. However, if needs must.
I will post the results if he tells me. No news would be good news I'm thinking. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| weasley |
 weasley World Chat Champion
| Walloper |
 Walloper Super Spammer
| map |
 map Mr Calendar
| weasley |
| Walloper |
| map |
 map Mr Calendar
| weasley |
| Walloper |
 Posted: 20:11 - 17 Dec 2013 Post subject: |
The last post was made 12 years, 74 days ago. Instead of replying here, would creating a new thread be more useful? |
