zx6r forum ??
devojunior
PostPosted: 11:38 - 19 Dec 2013    Post subject: zx6r forum ?? Reply with quote
hi all ,
im after joining a forum to get best info on my zx6r j1 any recomendations would be good cheers.
preferably and english one but a yanky one will do.
clancy
PostPosted: 11:43 - 19 Dec 2013    Post subject: Reply with quote
Tried google ? Or here ?
KLX 300r
PostPosted: 11:58 - 19 Dec 2013    Post subject: Reply with quote
Its a 600cc generic sports, what else do you need to know Laughing
This is probably the most active forum I've ever seen.
devojunior
PostPosted: 12:05 - 19 Dec 2013    Post subject: Reply with quote
had a look yes but not found anything half decent, would the cam chain run of the edge of the cams on my bike or centre of the cam ?
iv never had to touch a 600 engine before touch wood, just all single lumps where the cam chain hasnt needed to be split.
i only get links to camchains for sale on ebay from the search engine on here . dont think thats right its normally good for vids and previous posts ect.
PostPosted: 12:08 - 19 Dec 2013    Post subject: Reply with quote
You say you've had a look but what exactly did you look for? https://bit.ly/IXEyHG
And MCN Ninjas.
devojunior
PostPosted: 12:20 - 19 Dec 2013    Post subject: Reply with quote
And MCN Ninjas.
yes thats exactly what i did and saw an endless list of forums so thought instead of registering on everyone of them and writing the same questions to find half of them are full of weirdos who dont own a bike id just ask on bcf and maybe just maybe somebody would reply.
i didnt need a lesson on google just a friendly reply like " eyup pal iv got a zx6 and i use "x" forum friendly and full of helfull geezas but obviously im wrong illl just join them all and see where it gets me cheers for the help lads.
PostPosted: 12:26 - 19 Dec 2013    Post subject: Reply with quote
Ste wrote:
And MCN Ninjas.
That would be my first port of call.
Joining them all might take a while cos there are hundreds. Wink There's nothing wrong with posting the same question of multiple forums, BCF or MCN Ninjas should be able to help you. Thumbs Up
MCN Ninjas should be able to help you out. And I expect someone will help you in your thread in the workshop but it might take a bit longer than 20 minutes.
leighz
PostPosted: 15:28 - 19 Dec 2013    Post subject: Reply with quote
cam chain is on the right hand side of the cams on that era zx6r
mcnninjas is the fount of all ninja related knowledge - quiet these days tho.
Can't imagine why you'd want to split it though. Only if needed replacing I would have thought?!?
PostPosted: 15:38 - 19 Dec 2013    Post subject: Reply with quote
MCN Nijas was always where I used too.
stevo as b4
PostPosted: 19:40 - 19 Dec 2013    Post subject: Reply with quote
If the suspension is all std, then they like at least 8-10mm of extra rear ride height to make the steering quicker and stop them running straight on through bends.
Ultimately if your a fast rider or want to do track days etc, then the rear shock is not great and could do with a re-build/re-valve and lighter spring or an aftermarket shock.
Paint rubs off the wheels very easily, don't use petrol or solvents to clean them.
Watch out for the 6pot Tokico's suffering with sticking pistons, they need plenty of maintenance and looking after. Use small nylon brush's to get into the caliper with brake cleaner when you wash it, and take them off and remove the pads for a proper clean at least once or twice a year.
I found mine was much nicer to ride with 2-3psi less than recommended in both tyres, but that's true of many bikes.
PostPosted: 19:47 - 19 Dec 2013    Post subject: Reply with quote
Aaa, I remember the days of MCNNinjas. Good times.
-Matt-
PostPosted: 19:50 - 19 Dec 2013    Post subject: Reply with quote
I've used this in the past https://zx6r.com/forums.php
A lot of U.S users but helpful for technical stuff particularly.
Since finding BCF haven't wanted or needed to use it though to be honest, enough knowledge here generally.
J biker
PostPosted: 00:29 - 20 Dec 2013    Post subject: Reply with quote
+1.
ws4936
PostPosted: 01:48 - 20 Dec 2013    Post subject: Reply with quote
+1.
+2
If everything seems under control, you're just not going fast enough.
The last post was made 12 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.93 - MySQL Queries: 13 - Page Size: 79.97 Kb
