tzr idle speed rises when fuel tap is turned off (running)
simon1221
PostPosted: 22:03 - 24 Dec 2004    Post subject: tzr idle speed rises when fuel tap is turned off (running) Reply with quote
this is a bit confusing, but not a problem:
i just turned the fuel tap off on my tzr while it is running to see what effect it would have (obviously it would stop) but what i didnt expect is that right at the end, the idle speed rises to about 4 - 5000 rpm, then stops
its not that it bothers me as i am not going to switch it off while riding, just curious - possibly running more lean for a last 10 seconds or so?
any real explanation?
cheers
conpants
PostPosted: 22:05 - 24 Dec 2004    Post subject: Reply with quote
my af1 does the same, i guess its a good way of knowing your out of fuel...
gsxrboy
PostPosted: 22:17 - 24 Dec 2004    Post subject: Reply with quote
Its to do with the mixture of fuel / air, when you have turned the fuel off right at end it will run lean this in turn increases the revs.
Kickstart any more info? Very Happy
PostPosted: 22:20 - 24 Dec 2004    Post subject: Reply with quote
No more info, but it does seem to be quite common.
simon1221
PostPosted: 17:59 - 25 Dec 2004    Post subject: Reply with quote
rite thanks
Smoto Bob
PostPosted: 20:40 - 25 Dec 2004    Post subject: Reply with quote
what he says my 60bhp(ish) ktm250 used to do that like crazy when it ran out of fuel Shocked
set it back to stock and start again
F'it DO WHAT EVER MAKES YOU HAPPY!!!!! Even if it screws over everyone else :p
Titz wrote: "..and my 3rd accident was when this police car....."
simon1221
PostPosted: 21:09 - 25 Dec 2004    Post subject: Reply with quote
what the mixture settings? huh?
loply
PostPosted: 22:53 - 25 Dec 2004    Post subject: Reply with quote
Yeah its obviouslly just going lean ie less fuel per air and thus revving.
Note that going lean will also make it go hot so you wouldnt want to do that too often.
Yamaha SZR660 Caution to the wind, the throttle pinned!
simon1221
PostPosted: 13:41 - 26 Dec 2004    Post subject: Reply with quote
ah rite ok then, but if i am going to run out if fuel then it is going to happen and i cannot really help it
yes i guess if i turned it off then razzled it to 12k revs then it would blow, but that isnt something im goin to do
cheers for your input
Big Pete
PostPosted: 18:40 - 27 Dec 2004    Post subject: Reply with quote
Maximum power is produced on a slightly lean mix, so for a constant throttle opening and load (idle) the revs will pick up as the mix leans out from fuel starvation.
Trust me, I`m an engineer
GarageOfPower.co.uk
The last post was made 21 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 63.28 Kb
