How long to fit a DID X ring chain?
Yamaha Jim
PostPosted: 22:21 - 25 Dec 2013    Post subject: How long to fit a DID X ring chain? Reply with quote
I've bought a new chain for the other bike but dont have the tool or exp to rivet it.
So how long should it take an experienced mechanic to fit said chain?
Just trying to make sure I dont get ripped off.
Many thanks,
Jim.
Snorty
PostPosted: 22:22 - 25 Dec 2013    Post subject: Reply with quote
About 30 minutes providing everything goes to plan. I.e. no seized bolts etc.
Depends on the bike though, and how accessible the sprocket cover is.
Put it on yourself with a clip link and ride it to the place to get it riveted. I've been riding just with the clip link for ages though with no issues.
Nick 50
PostPosted: 22:26 - 25 Dec 2013    Post subject: Reply with quote
I had a chain and both sprockets changed this time last year and was charged £25 if that is of help.
Yamaha Jim
PostPosted: 22:31 - 25 Dec 2013    Post subject: Reply with quote
I was thinking of changing the sprockets myself first, leaving the old chain on for the 1/2 mile ride to the shop, then just have him attach the new chain to the old, thread it around, take the old off then rivet the new. surely this isnt more than half hour of labor is it?
Good call on the split link but i dont have any... hmmm but the ybr does, interesting!
Clutchy
PostPosted: 22:37 - 25 Dec 2013    Post subject: Reply with quote
An hours labour which can range from
Mates rates: £10
Back street mechanic: £15-£30
Big mechanic £25-£40+
A stealership: £40-skies the limit
evoboy
PostPosted: 22:54 - 25 Dec 2013    Post subject: Reply with quote
You'll find most places don't work in 'half hour labour'. Its normally a min of an hours labour.
If you are a returning, valued customer. Or the parts are purchased from the garage, some places can be more forgiving on the labour charge.
Or, buy a chain tool yourself.
APT Motorcycles
fatjames
PostPosted: 12:27 - 26 Dec 2013    Post subject: Reply with quote
This is the answer. Get one, then post up in the workshop for some help if needed. The other option is to post in your local forum and ask if anyone can give you hand. (I've done that before Karma - Marmalade! Made for a good day out and I learned a hell of lot more than I would using a garage)
HTH
PostPosted: 12:29 - 26 Dec 2013    Post subject: Reply with quote
Fit the chain, push the link together and use a hammer, ride careful to your friendly local bike shop and they'll rivet it for free.
c-m
PostPosted: 13:13 - 26 Dec 2013    Post subject: Reply with quote
Mates rates: £10
where the hell do you go? Even the backstreet one man band mechanics start at £45 per hour here in Norwich.
Dealerships can be £75+ vat an hour.
PostPosted: 13:15 - 26 Dec 2013    Post subject: Reply with quote
Go further into the backstreets. Shocked Thumbs Up
Yamaha Jim
PostPosted: 16:06 - 26 Dec 2013    Post subject: Reply with quote
HTH
Would https://www.ebay.co.uk/itm/Motorcycle-Chain-Splitter-Riveting-Tool-Heavy-Duty-Large-Sports-Bikes-O-ring-/171079216747?pt=UK_Motorcycle_Parts&hash=item27d51dae6b be ok?
evoboy
PostPosted: 16:19 - 26 Dec 2013    Post subject: Reply with quote
YBR-Jim wrote:
Yup. That'll do the job.
Just as a note, dont go too mad when pushing the plate onto the link. You can easily crush the O/Xrings and end up with a tight link with failed rings. Some chain kits come with guides your meant to slot in where the orings sit so you cant crush them.
Seen it many times before.
APT Motorcycles
Clutchy
PostPosted: 17:47 - 26 Dec 2013    Post subject: Reply with quote
This.
You gotta go deep man, reaaaaal deep.
bikersupermot...
PostPosted: 14:51 - 27 Dec 2013    Post subject: Reply with quote
Mates rates: £10
chiswick honda is 90 quid per hour. Thumbs Up Laughing
tinybikes
Walloper
PostPosted: 16:35 - 27 Dec 2013    Post subject: Reply with quote
30 minutes my (Lavender Scented) Arse.
To do a chain normally requires a clean up of old lube.
Remove the sprocket cover.
Remove the lock from the front sprocket.
Break the nut.
Split the old chain.
Remove the rear wheel.
Remove the rear sprocket
Clean up the hub
Fit the new Sprocket (tighten all the nuts/bolts)
Refit the wheel
Remove the old front sprocket
Fit the New Sprocket (and the nut and the lock)
Fit the new chain and rivet.
Fit the sprocket cover.
Adjust the tension/slack
Lube the chain.
Take for spin.
Check adjustment and re-lube.
30 minutes?
If just bodge-ing a new chain onto old the gears then 30 minutes but then that would be a maintenance fail in any man's book. Razz
Yamaha Jim
PostPosted: 18:31 - 27 Dec 2013    Post subject: Re: How long to fit a DID X ring chain? Reply with quote
The last post was made 12 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.78 - MySQL Queries: 13 - Page Size: 98.51 Kb
