| Mikeyspike |
 Mikeyspike Derestricted Danger
 Posted: 15:42 - 29 Dec 2013 Post subject: Starting problems - 07 CBR125 |
Hey guys, Having a bit of a predicament with my bike.
Went to go ride it the other day, hopped on it in my garage and tried to start it but she wouldn't fire.
Tried to give it some gas as I pressed the button, still nothing.
took it outside and tried once again. Managed to start it however the engine cut out shortly after.
By this point the battery was fairly drained so I tried to bump start it. Managed to start the bike, but any time I'd'd give it any throttle, it would cut out.
So I put the bike back in the garage and left it for a bit. Came back later and had another go. Thought it could be a knackered battery as it actually started when bumping it, but just would hold out.
Later on the night, tried to jump start it from my mothers car, still no dice. Now I thought it had to be something else.
Next day, I went into my local mechanics and told them my situation, they said it could be the sensor for the FI has gotten damp or there could be some form of fuel starvation.
Can't take it to the mechanics as they're technically not insured to work over this time period and the earliest they could take a look would be the 6th of Jan.
Went out earlier and tried once again, just in case it was just some damp problem. still nothing.
Check the oil, level seemed a tad high, also smelt a little like petrol although looked relatively clean.
so yeah. I'm a bit stuck as of what to do. I plan on going to the local Honda dealership tomorrow and speaking with them to see what they say (apparently they have had a few people go with with the same model of bike and have this sensor issue). However, I'd like to see what you guys think.
TL;DR:
-Bike wouldn't fire on button
-when it did, it would cut out
-battery's now drained, so can't start from button any more
-bump starting it had more success then the button, but again, wouldn't keep at idle
-giving it any throttle would make it cut out when it did start
-mechs say possible sensor failure in FI system or fuel starvation.
-oil level a little high, smells like petrol a bit too.
Thanks guys! |
| Northern Monkey |
 Northern Monkey World Chat Champion
| Mikeyspike |
| Copycat73 |
 Copycat73 World Chat Champion
| Mikeyspike |
| Copycat73 |
| Northern Monkey |
 Posted: 17:46 - 29 Dec 2013 Post subject: |
| Mikeyspike wrote: |
I assume there is as spark as she will fire up and idle for a few seconds, but then cuts out. Any throttle and she cuts out too.
Fuel should be fine.. well... I hope, The last place I filled up was a random garage, not like a BP/Shell or even Texaco one.
She was running fine a couple of days ago. This is what I don't understand "/.
But yeah. I'll change the oil in the next couple days. Thanks  |
Are you using the choke? |
| Walloper |
 Walloper Super Spammer
| Mikeyspike |
| Mikeyspike |
| Walloper |
 Posted: 18:06 - 29 Dec 2013 Post subject: |
Iridium electrode plugs are better. I have them fitted to all my bikes and starting performance is notably superior to the 'standard' copper core. Never had any problem with fouling.
Some interesting Guff on here. Cheap plugs too.
https://www.gsparkplug.com/shop/ ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Copycat73 |
| Walloper |
| Copycat73 |
| Walloper |
| Copycat73 |
| Walloper |
 Posted: 11:52 - 30 Dec 2013 Post subject: |
| Copycat73 |
| Walloper |
 Posted: 15:13 - 30 Dec 2013 Post subject: |
| salem1987 |
 salem1987 Scooby Slapper
| gavcarter |
 gavcarter Could Be A Chat Bot
| MartQ |
 MartQ Two Stroke Sniffer
| Walloper |
| MartQ |
| Walloper |
The last post was made 12 years, 202 days ago. Instead of replying here, would creating a new thread be more useful? |
