Removing white alloy corrosion (car related)
Nope.
PostPosted: 18:15 - 31 Dec 2013    Post subject: Removing white alloy corrosion (car related) Reply with quote
Hi All,
So I recently acquired a 1.7 16v Alfa Boxer from a 145 as an upgrade for one of my Minari's.
The airbox (And other alloy parts) are all covered in this horrible white aluminium corrosion:
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-ash3/1517571_10203096783919798_1562370532_n.jpg
https://scontent-a-lhr.xx.fbcdn.net/hphotos-ash3/1524755_10203096783959799_1926338192_n.jpg
https://scontent-a-lhr.xx.fbcdn.net/hphotos-prn1/1555538_10203096784039801_1702280319_n.jpg
I've tried vinegar and a tooth brush to little avail. It removes the top coat of white powdery stuff but not the ingrained corrosion, I used a test patch on the back to try my dremel with it's sanding cylinder on, it did remove the powder but I had to go quite far to falt the metal down and this won't work on the written detail on top.
Will soda blasting it work? Can I soda blast with my shot blasting gun?
Thanks all!
Copycat73
PostPosted: 18:57 - 31 Dec 2013    Post subject: Reply with quote
one of these
https://i867.photobucket.com/albums/ab232/copycat73/cottonwheel.jpg
some buffing soap
https://i867.photobucket.com/albums/ab232/copycat73/buffinsoap.jpg
then this stuff
https://i867.photobucket.com/albums/ab232/copycat73/allsorts/solvol.jpg
its hard work though & takes a lot of time..
the finish will be as a mirror
caveat emptor
PostPosted: 19:10 - 31 Dec 2013    Post subject: Reply with quote
Vapour blasting will probably sort it out cleanly (although make sure no debris is still in the manifold afterwards).
What ignition system are you using with this engine? Have you got any cams from a non cat 33 to go on it?
Nope.
PostPosted: 19:58 - 31 Dec 2013    Post subject: Reply with quote
Yeah I'd considered vapour blasting. I'll see how much my local place wants to do it (along with the throttle bodies).
It's the standard Bosch ignition system at the moment, but I'll probably switch it to Megajolt and Megasquirt injection simply to make it more tunable.
The engine is from a 146 so I don't have any non cat cams for it, it's just the inlet cams that are different right? Am I right in saying that the non-cat 33 doesn't have a Lambda probe?
I don't want to polish it, I just want to prep it for painting.
Shaft
PostPosted: 02:27 - 01 Jan 2014    Post subject: Reply with quote
You could spend a month of Sundays scrubbing it with a toothbrush, but if you want to paint it and you expect the paint to stick, get it blasted.
Suntan Sid
PostPosted: 12:32 - 01 Jan 2014    Post subject: Reply with quote
I managed to get rid of the same corrosion using diesel and a scotchbrite kitchen scourer, for the initial clean, then used the scourer with WD40 for the final clean.
All done by hand, didn't take too long and it's as cheap as chips.
If there's any pitting you're not going to get rid of it, with this method. However, as you don't want a polished finish it should work!
Walloper
PostPosted: 14:09 - 01 Jan 2014    Post subject: Reply with quote
To remove white alloy corrosion you can use ebay.
Some daft fcuker will buy it off you.
Very Happy
Copycat73
PostPosted: 14:12 - 01 Jan 2014    Post subject: Reply with quote
caveat emptor
ZRX61
Victor Meldrew
PostPosted: 04:41 - 02 Jan 2014    Post subject: Reply with quote
Soda blasting would have those parts looking like new in mere moments. Don't bother fucking about with buffing wheels, grinders, wire wheel's etc.
As they are Alfa parts they will actually end up looking better than the day they left the factory.
They're not one night stands, they're auditions.
Robby
Dirty Old Man
PostPosted: 09:57 - 02 Jan 2014    Post subject: Reply with quote
Soda blast. I would then be tempted to leave them unpainted and give them a rub with ACF-50. Soda blasted alloy looks good and will take a while to start corroding again with a bit of anti-corrosion coating.
If you're tight and have a compressor, you can make a soda blasting rig for next to nothing and do it at home. Wear a good mask, and just hose down the working area/garden afterwards to get rid of the white powder.
Walloper
PostPosted: 15:35 - 02 Jan 2014    Post subject: Reply with quote
Vincent wrote:
What sort of pressure are we talking about here? 'Wouldn't mind setting something up myself Thinking
I would guess not much more than shop pressure 80-90 psi.
The only real issue is volume. A wee tank won't give you much time to work. Unless the compressor can keep up.
Normally wee compressor sets have wee compressors so cant run a sprayer as the compressor is too small.
It would be possible but may be a drag to set up and find you only get about 30 seconds of blow. Which would be dropping every second.
If alloy is blasted or the surface removed it should be protected by painting, lacquering or wax. It will oxidise in days and the bright finish, if desired, will be lost.
ZRX61
Victor Meldrew
PostPosted: 05:03 - 03 Jan 2014    Post subject: Reply with quote
Depends on where ya live. I have some '70's Kaw parts (steel & aluminium) that were bead blasted about 16 years ago that still look like I did them this morning.
Walloper
PostPosted: 08:35 - 03 Jan 2014    Post subject: Reply with quote
Sorry, what I should have said is, if you live in an oxygen free environment then......
Rolling Eyes
Very Happy
The last post was made 12 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 92.31 Kb
