Suzuki DR125S regulator problem...
krisply
PostPosted: 19:14 - 03 Jan 2014    Post subject: Suzuki DR125S regulator problem... Reply with quote
hello folks,
I 'believe' my bike is a DR125S circa 1980 (V5 is not specific AND I cannot find it to confirm the reg date!)
the battery wasn't charging so I started to look at the regulator/rectifier and
found a load of corrosion but inadvertently broke off one of the five copper spades.
F*&K!
So I don't know whether I just had a connection issue or not.
Then I went looking for a replacement reg and found none looking exactly like it (no markings to go by) - it
has 5 copper spade connectors lined up flat along an edge, and bolt lobes projecting away from body of reg ie. the reg is not square but has these lobes either side of the cooling fins.
Could I replace with just about any 5-wire motorcycle reg/rect?
Does the order of the 3 phase wires from the stator matter to a rect/reg?
ie. can they be plugged in any which way?
your help is appreciated!
thanks,
kris
WD Forte
PostPosted: 20:09 - 03 Jan 2014    Post subject: Reply with quote
I've patched in various Rectifer regulators to other bikes without tears.
the order of the AC input wires isnt important.
So yes, its quite doable
I wouldnt use one from say a 50cc bike, one from a same size or bigger bike would be best
If you get one with no leads and just pins from a different bike,
Its wise to check the pin out to get all your existing leads going to the correct pins.
If it has 6 pins it may use an external sense wire.
A check with a meter will usually tell you what does what.
bikers smell of wee
pepperami
PostPosted: 20:22 - 03 Jan 2014    Post subject: Reply with quote
Suzuki DR/gs 125 regulator from the breakers yard.
All the 125 four-stroke singles that are around at the moment, something must be compatible?
krisply
PostPosted: 09:30 - 03 Feb 2014    Post subject: Reply with quote
thank you WD - a 5-wire type from ebay did the trick.
So the bike is up and running ... but almost limping along!
It's reasonable going down a very slight incline, will get to 60mph eventually, but the other way it has to crawl along in 2nd gear
and I can feel the engine lose power in hesitating steps.
I have already cleaned up the carb. Did not come across
any adjustment other than idle though, no air mixture screw for instance. Have I missed it?
Other than that I thought of just replacing the piston/ring/sparkplug.
Any ideas?
cheers,
kris
krisply
PostPosted: 07:44 - 01 Mar 2014    Post subject: Reply with quote
I've got hold of a compression tester !
but the instructions talk about turning the engine over for 10 seconds.
presumably this is assuming an electric start.
I only have the kick-start - will I get a different result?
ta
kris
robocog
PostPosted: 09:01 - 08 Mar 2014    Post subject: Reply with quote
Hold throttle wide open (or remove carb)
make a note of the compression it gets to after a few kicks
If the reading is much lower than expected
pour a tablespoon of oil into the spark plug hole and repeat
If the compression is the same or very similar - the rings/piston/bore are possibly OK and its more likely a top end seal issue
If it makes a massive instant improvement the issue lies more likely in the piston sealing
(not 100% conclusive and they have to be seperated anyway to sort either end out)
Regards
Rob
Needs a bigger garage...
The last post was made 12 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 57.07 Kb
