Car question - using coolant, wouldnt start
grant965
PostPosted: 14:21 - 04 Jan 2014    Post subject: Car question - using coolant, wouldnt start Reply with quote
Hi all, my car, 2003 Peugeot 206 1.4 petrol 8 valve, just shy of 60k.
Been slowly using water for past month or two, only needed topping up like every 2 weeks.
This past week or so its been hard to start, resembles when starter went on my bike, clicks but nothing, then all of a sudden it would start turning over and start, usually would run fine but it once it spluttered and took a lot of throttle to get it to start, was running rough for first 20 secs or so but then was fine.
Wednesday I noticed temperature slightly higher than usual and it was slowly rising so I pulled over and checked water and was bottom of the coolant tank so I filled it up, turned it over and filled it as air bubbled out. When i was sure it was full and no more bubbling i set off.
Thursday night I go to nip out and it doesn't turn over, jumped it (thought maybe a weak battery couldn't turn over an ageing starter) from girlfriends 1.3 KA and on second try it turned over and started perfectly.
Friday morning, same again, only this time it didnt turn over when jumped. Took leads off as battery clearly isnt responsible, rocked in gear and tried to turn over, nothing again. Checked oil and water and oil is discoloured obviously because water is seeping through. But coolant tank was near enough empty, it took about 2L of water (less than previous times) and it started up fine but with one massive cloud of white smoke (presumably steam).
Ran fine to local shop then wouldnt start again, started after 5 mins and drove fine.
So my question is, is it likely that the starter has gone just as the head gasket has started leaking more or is there something else going on?
Ordered some K seal in the hope that it will at slow down the coolant leak till my mate (mechanic) is back from his holiday in a weeks time.
In the mean time if there is anyone who can replace a head gasket cheap and you are local to Preston give me a shout Smile
Thanks for all help,
Grant
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
Robby
Dirty Old Man
PostPosted: 14:40 - 04 Jan 2014    Post subject: Reply with quote
Quite possible that water is getting past the gasket into the cylinder. When the engine is running it will suck in a small amount of water when the piston drops and boil it, emitting steam.
When the engine is turned off the hot water is at a higher pressure than the cylinder, so pushing water into the cylinder. Water doesn't like to compress, so if the cylinder has too much water in it then you'll hydraulic lock the engine.
Try taking out the plugs and turning the engine over next time you want to start it, you may see some water coming out of the plug holes. Not a good idea to try starting an engine with water in the cylinders.
It isn't a difficult head gasket change, Iain managed it and he's 95% potato.
doggone
PostPosted: 14:55 - 04 Jan 2014    Post subject: Reply with quote
Maybe one of the cylinders is part filling with water via the duff gasket, that would make it seriously hard to turn over.
Whatever, you don't want to be driving it like that, could bend valves or something.
grant965
PostPosted: 15:04 - 04 Jan 2014    Post subject: Reply with quote
cheers for the reply guys, I was at the girlfriends whilst this was happening and so had no choice but to drive back. Back yesterday and car hasnt been used since.
Ive changed gaskets loads on a bike, how much harder/longer is it on a car? timing easy? How do I know if the head is warped?
Thanks, Grant
Walloper
PostPosted: 15:06 - 04 Jan 2014    Post subject: Reply with quote
Don't try to start with the spark plugs in. If there is coolant in the combustion space when the engine fires the force can damage the crank, con-rods etc. if the engine 'Hydraulics'.
Remove all the plugs and turn the engine over either by hand (better) or on the starter. Note if any water, spray or mist blows out the plug holes. This is the place the coolant is leaking into.
It could be a burst gasket or a cracked cylinder head/block.
Has the car ever had a roasting?
This is usually the only reason for cracks or gaskets failing.
Roasting is usually due to
Previous bodged repairs can cause it too.
If you do get water coming out a plug hole it's a benefit as you will know the head has to come off. Recording where lets you know where to look for cause which can sometimes be difficult without some clues. With the head off look for head gasket fire-ring damage, cyl head cracks on the cyl. the water came out of.
If you are adding coolant then you have a leak.
You can have a garage pressure test the system or do it yourself. If you fill up with cold water and then run till the fan/s come on shut down and go over all the hoses looking for drips. Check the rad matrix for leaks.
Walloper
PostPosted: 15:08 - 04 Jan 2014    Post subject: Reply with quote
5% ?
grant965
PostPosted: 15:38 - 04 Jan 2014    Post subject: Reply with quote
It probably will need skimming then, i first noticed it because it was running very rough and engine management light was on. Does that count?
grant965
PostPosted: 15:47 - 04 Jan 2014    Post subject: Reply with quote
_Iain_ wrote:
I suppose really it depends on how much the cars worth to you & how much the cost of skimming is.
My car was at the time worth basicly scrap value, so wasn't too bothered.
The annoying thing is I only planned on having the car till my student loan was through, was gona buy a diesel then sell this to get some money back, wont get my money through for new car for another month or two so do need this fixing, I already have the parts, gasket, new bolts, oil etc so is really just the labour and any skimming I need. Think I might strip it down this week n if i cant finish get my mate to sort it for me when hes back.
Walloper
PostPosted: 16:46 - 04 Jan 2014    Post subject: Reply with quote
Doesn't necessarily need skimming. Ive fited hundreds of cyl. Heads to engines and only one was skimmed. Only skim to change compression ratio or if gasket surface is damaged. If warped a new head is the correct fix. As cheap as an engineer to skim. To skim also means all valve gear out. If doing that then valves would ned lapping. So not advisable.
PostPosted: 17:08 - 04 Jan 2014    Post subject: Reply with quote
Also possible the head has cracked. The head gasket is more likely, but Murpheys law might come into effect if you assume it is just the gasket.
grant965
PostPosted: 18:10 - 04 Jan 2014    Post subject: Reply with quote
Yea I had also thought about that, was typical that I was waiting for my pay packet on friday to get it done. I only usually work part time because of uni but got extra hours in at work, finally had the money to get it done and it breaks down on me Evil or Very Mad
poleposition
PostPosted: 01:10 - 05 Jan 2014    Post subject: Reply with quote
Skimming on certain engines is essential, otherwise premature failure will most certainly happen, wacking a new head gasket on without even checking if it needs skimming is cutting corners.
I would imagine you've cut a few corners if you've only ever had 1 head skimmed out of hundreds...
Getting back to this guys head...No you dont have to remove the valves to have it skimmed, The rockers are removed quite easily which closes all the valves.
Ride it like you stole it!
Walloper
PostPosted: 01:20 - 05 Jan 2014    Post subject: Reply with quote
If the head is good ot doesnt need skimmed if worn or 'seriously' warped then skim. As I said, I fitted hundreds of heads and none failed so I dont think any corners were cut, you cheeky cunt.
Skimming will interfere with compression ratios so who's cutting corners now smart arse?
bladerunner
PostPosted: 02:40 - 05 Jan 2014    Post subject: Reply with quote
As said sounds like head gasket failure or possibly porosity of a casting. Warping usually happens if it's overheated or leaking combustion gasses have escaped between bores/water jacket.
Checking if it needs skimming can be done with a straight edge or even a good steel rule or set square used edge on so Long as you know it's straight. Any low areas will show up if backlit by a torch or workshop light etc and those areas can be checked with feeler gauges to measure by how much.
Skimming can usually be done with the valves still in situ as it should only require a minimal amount of material skimming off....and erm guys as far as it changing the compression ratio.....that's why they make the head gaskets in different thicknesses......check how many notches are on the original and if skimmed then find out by how much and order the correct one to adjust.
Don't forget to back flush the rad and check its free flowing before you rebuild the engine just in case there is any crud build up causing restriction and the whole thing happening again.
poleposition
PostPosted: 08:09 - 05 Jan 2014    Post subject: Reply with quote
Getting back to this guys head...No you dont have to remove the valves to have it skimmed, The rockers are removed quite easily which closes all the valves.[/quote]
Skimming will interfere with compression ratios so who's cutting corners now smart arse?[/quote]
I've been a qualified mechanic probably before you were born, I've worked in more garages than i care to remember so my knowledge comes from experience, not internet forums.
Most people don't realise they have head gasket failure until the engine has been run dry..fact! If you have done "hundreds" of head gasket jobs then the law of averages would suggest that at some point you would have dealt with a "K-series" rover engine, since this engine probably has the weakest head gasket of all engines from the past 20+ years..another fact !
Of all the head gasket jobs I've done which is an awful lot and i would probably imagine more than you (but I don't know this for a a fact so I'm guessing on the basis that every garage I worked in usually gave me the big jobs as I was the most qualified to do them ) I would say at least 35 - 40% of those head gaskets were K-series engines, and anyone that replaces the head gasket on these engines without having the head skimmed is asking for trouble..another fact.
They only make different thickness head gaskets for diesel engines, (determined by the number of notches as rightly said) since the compression ratio on a diesel is a lot tighter, but this is not because it will alter the compression ratio, It will, but the effect will be negligible since we are only talking a very small amount, It is done on diesel engines to prevent contact between the valves and piston head..
You probably can get different thickness petrol engine head gaskets, but in the real world on normal non-tuned engines they are not really required or used.
Most machine shops will stamp the amount that has been removed during skimming into the head, this is to mark the history of any work done for future reference and because you can really only skim a certain amount before you start to run into problems, this amount varies with each head.
Lastly..I'm not a cheeky C***....Just someone who knows what they are talking about.. Smile
bladerunner
PostPosted: 12:01 - 05 Jan 2014    Post subject: Reply with quote
Just for info....pug would do 1.4 8v 207 under warranty if under 80k or 4 years because it was a known problem....sometimes even over these figures....your well out of the age range but quite straight forward...expect 4-5 hours if your a good home mechanic.....2.5 hours if you don't have any issues and have done it before! They like the K series don't like lots of short journeys due to gunk in the oil and coolant not being changed every couple of years!
misscrabstick
PostPosted: 12:37 - 05 Jan 2014    Post subject: Reply with quote
Remove head, clean gasket surface, get straight edge, a confirmed straight metal ruler edge is good enough, lay side of ruler across head length, and both diagonals, if you can get a 4 thou' feeler blade (approx)under at any point then it needs skimming.
Many skims we have done are down to corrosion across or on the edge of fire rings and not warpage.
Rover K series heads also get dented from the fire rings and the head wobbling about on the gasket.
poleposition
PostPosted: 15:50 - 05 Jan 2014    Post subject: Reply with quote
absolutely right, If left long enough the wet liners will form a deep groove in the head on the k-series, seen it happen a few times.
They modified the head gaskets a few years ago and decided the twin gasket and shim was the way to go..Personally I still prefer the old style gasket, If done properly they will last as long as the original.
These engines may be notoriously weak as far as head gasket failure is concerned, But as i have always told people, head gaskets don't just fail on their own, they almost always fail because of another fault, coolant leak, fan switch not working, thermostat not opening etc etc, Its worth pointing out that despite this weakness they are actually great engines IMO.
stevo as b4
PostPosted: 16:25 - 05 Jan 2014    Post subject: Reply with quote
Is one or more of the spark plugs either white on the insulator or really clean like a new plug? That's a sure way of knowing that water/coolant has been getting into the cylinders.
If your filling up the coolant expansion bottle and needing to add 2litre's a week to get the levels normal. That is a very fucked engine and it will let go at some point when your driving it soon.
My mum's old car was using water, and has the classic signs of oil spots and gunge in the coolant tank. (K-series engine). I kept topping up the coolant with say up to a pint per week near the end, and 2 non scheduled longer journey's were then driven, the second one stuck in traffic on a hot day, and well you know what happened next.
If you overheat and lose a lot of coolant to the extent that you need 2litres to re-fill, then just drive the car home and not use it until it's fixed.
It's pretty obvious that less damage is done and possibly less work is required if you sort the HGF as soon as possible. Many mildly overheated engines, may get away with a new gasket and have a nice flat head, but serious overheating will scrap a head and even a cylinder bock/bottom end if it gets hot enough, either that or if your loosing coolant into the oilways, the milky mess in the sump will not lube the bearings and seizure is quite possible.
If your all aluminium engine overheats at 80mph on the motorway, it's only fit for the bin, as it will have cooked it'self so bad everything will be warped and distorted usually.
Walloper
PostPosted: 18:43 - 05 Jan 2014    Post subject: Reply with quote
It is exactly because of tossers like you I never trust garages to do any work.
Just coz you work in a garage on little cars doesn't make you the Engineer of the last 2 Millenniums.
You are a Motor Mechanic so you stopped learning about stuff age 17 or 18.
I went a lot further than that son.
'Before I was born.'
Not only are you only a motor mechanic you're a Pontificating one too. Razz
You don't need to skim a cylinder head UNLESS it needs skimmed you mo-tard. What sort of customers do you skin then? The un-suspecting I'll wager.
If the gasket is the only thing damaged why would the head need slimming?
I'll find out where you work and report you to Trading Standards. Very Happy
poleposition
PostPosted: 20:07 - 05 Jan 2014    Post subject: Reply with quote
Idiot...
Its calling doing the job properly..And doing it only once.
Its standard practice in most reputable garages..If you had worked in as many garages as I have then you'd know that.
I don't decide whether the heads get skimmed, the garages I work for do..And i'll repeat it again since your still unclear..Its done because experience tells us its beneficial, the gasket won't fail prematurely, and ususally the job requires it.
You don't know me, You have no idea of my experience or what I can and can't do...If it makes you feel good to call me names..then knock yerself out..I won't lose sleep over it. I'm still right!
I don't just work on "little cars"..I'm a qualified HGV technician too..smarty pants...
A proper technician never stops learning..I am no exception, But what we are talking about here is college stuff..
head gasket failure usually leads to overheating...this is what causes heads to warp and why we skim them..
The majority of car owners that bring their cars in for repair have no idea what happens when the engine overheats..these are the people in the real world that pay to have their cars repaired..and they are the same people that drive their cars until it comes to a halt...you still wanna wack a head gasket on without having the head checked/skimmed/or even crack tested?
when we do a job we give a warranty, like most reputable garages do, so we need to ensure that the work we do will not fail within the first 6 months..otherwise we end up repairing it again for free, and look incompetent in the meantime.
I have no idea where you have or havent worked, I am guessing you have done a couple of cheap gasket jobs for your mates and charged them a fiver...
Your gonna report me to trading standards?..haha...go for it.
make sure you phone a few garages first and ask the qualified experienced technicians whether or not they bother skimming cylinder heads.
The last post was made 12 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.11 - MySQL Queries: 13 - Page Size: 147.37 Kb
